Remove these ads by
Signing UpStep 1CONTRIBUTE !
It's just a concept for now, it will need to be legally determined and protected for it to remain unlabelled in the public domain ... Please be carefull while spreading this concept (don't talk to fat businessman before it's all cleared up, it wouldn't work anyway ...)
I just bought http://www.lifecable.org as a first contribution to the project.
PLEASE CONTRIBUTE !
inspired by Tetsuo Harada "Earth Weaving", after the pure water project success.
It sounds pretty ambitious. You want to redesign/combine several technologies and the economy? All via one multi-conduit? Why not take one element, get good at that, then proceed? I don't mean to be a wet blanket here, but it seems like you're biting off way more than you can chew. People are having trouble (see the Full Belly group on this site) , IMO, in large part due to over-ambitious thinking that is not necessarily appropriate to the environment.
Static has a point; there are some pretty good, time-tested reasons why utilities are kept separate from one another. That's not to say there isn't room for improvement. Plumbing has not changed all that much since the Romans invented it.
GAZ = is also probably necessary... and cheaper as you mentionned.
DATA = right. I heard fiber optic is expensive, but it would be the optimal solution hhuh ? Maybe even a small diameter would be enough for an individual house ...
GARBAGE = oh of course hahaha ! i forgot ! ok, mmm ... maybe the hardest. What do you think of the toilets destroyers, you know in some toilets, there is a mecanical blender or chemicals to prepare waste to fluidification ... i have to study how it works, maybe it's a good solution for "regular" item in particular organic waste.
The more I think about all the transformations necessary (filtering air, water, pressuring gaz, a valve and a control panel for everything) the more it seems necessary to have a furniture designed especially to host all those technologies (computer control, sounds like domotics!) => see sketch.
This furniture sounds like an energy terminal with a pump for waste maintenance....
i need to build a model of the cable and the terminal ....
