LIGHT ON BEAT
20
Posted
Introduction: LIGHT ON BEAT
THIS A PROJECT BASED ON THE APPLICATIONS OF HOME AUTOMATION AND ENTERTAINMENT PURPOSES . THIS CONTAINS A HC-05 BLUETOOTH FOR CONNECTIVITY WITH OUR OWN APP ,
A MIC/SOUND MODULE FOR SOUND INPUTS ,A RGB(RED,GREEN BLUE) FOR COLORS AND ARDIUNO Uno for computing the all the activity of this project
Step 1: CIRCUIT DIAGRAM OF LIGHT ON BEAT
Step 2: DEMO
CODE FOR LIGHT ON BEAT
//code by jasnoor singh
#define REMOTEXY_MODE__HARDSERIAL
#include
// RemoteXY connection settings #define REMOTEXY_SERIAL Serial #define REMOTEXY_SERIAL_SPEED 9600 #define REMOTEXY_ACCESS_PASSWORD "rgb"
// RemoteXY configurate #pragma pack(push, 1) uint8_t RemoteXY_CONF[] = { 255,4,0,0,0,53,0,8,24,2, 3,3,86,29,11,29,8,5,19,52, 2,26,6,0,7,26,33,33,33,27, 27,27,2,26,129,0,32,4,18,6, 2,77,59,8,17,82,71,66,32,67, 111,110,116,114,111,108,108,101,114,0 }; // this structure defines all the variables of your control interface struct {
// input variable uint8_t select_1; // =0 if select position A, =1 if position B, =2 if position C, ... uint8_t rgb_1_r; // =0..255 Red color value uint8_t rgb_1_g; // =0..255 Green color value uint8_t rgb_1_b; // =0..255 Blue color value
// other variable uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY; #pragma pack(pop)
///////////////////////////////////////////// // END RemoteXY include // /////////////////////////////////////////////
int brightness = 0; // how bright the LED is int fadeAmount = 5;
void setup() { int sensorValue = analogRead(A1); RemoteXY_Init (); // TODO you setup code pinMode(A1,INPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); pinMode(11,OUTPUT);
void loop() { RemoteXY_Handler (); if ( RemoteXY.select_1==0) { analogWrite(9, RemoteXY.rgb_1_r); analogWrite(10, RemoteXY.rgb_1_g); analogWrite(11, RemoteXY.rgb_1_b); } else if ( RemoteXY.select_1==1) { int sensorValue = analogRead(A1); Serial.println(sensorValue); if((sensorValue>11)&&(sensorValue<=16)) {digitalWrite(10,HIGH); delay(20); } else if((sensorValue>=16)&&(sensorValue<=200)) {digitalWrite(11,HIGH); delay(20); } else if((sensorValue>=200)&&(sensorValue<=800)) {digitalWrite(9,HIGH); delay(20); } else {digitalWrite(11,LOW); digitalWrite(10,LOW); digitalWrite(9,LOW); } } else if(RemoteXY.select_1==2) { digitalWrite(9,HIGH); delay(2000); digitalWrite(9,LOW); digitalWrite(10,HIGH); delay(2000); digitalWrite(10,LOW); digitalWrite(11,HIGH); delay(2000); digitalWrite(11,LOW); } else {
digitalWrite(9,LOW); digitalWrite(10,LOW); digitalWrite(11,LOW); }
Step 3:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
3 Comments
very good...................
Very nice...keep it up...
That's a fun simple setup to go with the music :)
