3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LM3915/LM3916 VU Meter
Step 2Wire the LM3916 Circuit
You will wire up the circuit following the diagram attached. For a bigger version you can check out the page at N.S..
I skipped two things, I did not use the capacitor as it is only necessary if you have more than 6" of cable between the LEDs and the chip, and I also did not use the 7.5k resistor in the diagram going to pin 6/7. your mileage may vary.
8 comments
Nov 22, 2011. 11:10 AMMathieu5555 says:
Since co'callaghan1 have not been answered, I still do not know what is the Vref, so I put a 10K potentiometer in place of 2 7.5K and 1.3K resistor.
Now I Can ajust the VuMeter. If the sound is not very loud I can raise the level. So its work perfect.
Pot 10K, first pin go to #7
Second to #8 on chip
and third on ground.
Jul 8, 2011. 5:16 AMco'callaghan1 says:
Sorry about those last three posts. I've only got one question. Can you please explain what Vref is and what I'm supposed to do about it? Do I connect it the way it describes or what? It's just confusing because it does not appear to be connecting them. Do I have to do that?
Jul 6, 2011. 3:01 AMco'callaghan1 says:
(removed by author or community request)
Jul 6, 2011. 3:09 AMco'callaghan1 says:
Jul 22, 2009. 3:40 PMWerewolve says:
I have 12V car battery. Where can i get the 3V for the Led's? or can i use 12V with a 620Ohm Resistor? Led: 2,25V 20mA
Apr 19, 2011. 5:42 PMreverser514 says:
OH THANK YOU FOR ASKING THIS QUESTION!
I had a couple of tweeters left over from a sub box I scrapped awhile ago. I took some good old wood, cut a circle out of it for the speaker, and left room for LEDs. My only problem is I don't feel like running a wire from the front of the car to the trunk.. maybe I'll just splice it in with my trunk light... :D then it will only turn on when the trunk is open!!! and the crowd goes wild on the thought!!!
Aug 9, 2009. 10:01 PMlikeastone9999 says:
you can use 12 volt... but use a 330ohm 1/2 watt 5% tolerance... they work great for led's
Jul 28, 2009. 4:00 AMcharlieb000 says:
get a 3v (or so) regulator..
Oct 15, 2010. 6:05 PMwootwootman says:
is it possible to add a potentiometer in there somewhere to vary the sensitivity of the input?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
