Lady GaGa 'Video' Glasses
142,540
279
118
Posted
Introduction: Lady GaGa 'Video' Glasses
Halloween Contest
Third Prize in the
Halloween Contest
I made these quick and easy glasses for my Lady GaGa Halloween costume. They use 2 digital picture frame keychains on a slideshow setting to replicate the effect seen in her performances (here is a video of her glasses).
Note:
* You cannot see through the glasses, so I don't recommend walking around with them on.
* The individual keychains are not synced. I just practiced pressing the 'ON' buttons simultaneously.
DIY Lady GaGa Video Glasses from Angela M. Sheehan on Vimeo.
Step 1: Materials
You will need:
* Sunglasses (that you don't mind destroying)
* 2 digital picture frame keychains -
They retail for around $20 but I found some on ebay for around $6 each. I used a 1.5" screen because it was a good size to attach to my glasses.
* Hot glue gun & glue
* Pliers (to remove the keychain from the picture frames)
* Paint (to cover the glue and blend the picture frames in with the glasses better)
* A computer (to download the images to the picture frames)
Step 2: Prep Glasses and Digital Picture Frames
Pop out the lenses on your glasses. This will make it easier to attach your digital picture frames.
I had to crack the lenses with a hammer in order to remove them because they did not pop out easily. If you need to crack the lenses please be careful and wear gloves and safety glasses.
Use pliers to remove the keychain clasps from your digital picture frames. There is probably a metal ring that you can unbend where it attaches to the plastic.
Step 3: Load Images & Test
Before you do any gluing, load your images onto your digital picture frames and test them out. They should come with a manual to tell you how to do this. Also set the slideshow time to the fastest setting to make it more 'video'-like. These particular models only have options for 5 second, 10 second, or 30 seconds.
While you are at it, charge up the devices (mine came with a USB cord for loading/charging).
I had to find a Windows machine because the brand I had was not compatible with Macs.
I attached some images you can use. The animation in her video is just the words "Pop music will never be low brow".
Note:
Because the picture frames I used were thinner on one side, I installed one upside down so they would mirror each other (see picture). I had to upload the images for that frame upside down so they would display correctly. You can flip them in any image editing software before loading.
Step 4: Attach to Glasses
Using a hot glue gun, attach the digital picture frames to your glasses. I worked my way around the frames a few times, layering up the glue to make a sturdy connection.
Be sure to leave room between the frames to plug them in if needed (as you can see from the pictures the USB connection is right across the bridge of the glasses, that's not a lot of space to work with).
If you want, use some paint to cover the hot glue and make the digital frames blend in with your glasses.
And that's it. Try them out and impress your friends!
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    118 Comments
    Who wants to make me a pair of these? I'll pay for them.
    Thanks for this great idea! I ordered two keychains today. I think I might make one with just one "eye" side of the glasses so my kids can see out the other. I think a digital "wandering" eyeball might be fun. I'll try to remember to post something when I get it done. Great job!
    http://lh6.googleusercontent.com/public/ElzZYCI-8WMA6gy8xUSsNKz0adSS1cno3bJPJURtyJQAvtwBeEKW-cBHK3xgYRLHxdIe2j9Y2bdrylf0w6Gs19RAlq8FL_oI38DY_k_lf7cEWbgQ50pVcM3j2VWnI8M
    I USED THESE
    i just have 1 question. how do u charge the frames?
    You can use the usb cord to plug them in and charge them.
    ohhh nvm I SAW SECOND PIC
    BUT, HOW CAN U PLUG THE USB TO IT, TO CHARGE/ CHANGE PHOTOS?
    Wouldn't be so cool if it could play music too like just as the slide show was playing lady gaga song played too or any song
    i found some on ebay for 3.47 each
