3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lady Gaga Soda Can Rollers (Telephone Video)
Step 8Applying zee eyeliner
applying zee eyeliner
You can use a pencil, liquid liner, whatever you feel most comfortable with.  For Christina, I used a cream liner.
Using a clean liner brush, I dipped my brush tip into my cream liner, and took the excess liner off on my palm, and ensured that I am starting with a sharp brush.
I know its tempting to start drawing a line in, however you wanna avoid this.  Instead, press the brush into the lash line, lift, and do this all across the lash line.  You want to connect many short lines together rather than trying to paint on one giant line of eyeliner.  You want to have a thin line at the inner corner of the eye, and thicken the line as you reach the outer corners of the eye.
When you get to the outermost corner, create a crisp winged line that extends straight out.  If you wanted a more "cat eyed" look, bring that line up a bit at a slight angle.
Line the bottom lid the same way.... For this look, I stopped at the middle of the lid, rather than line the entire bottom lash line.
Once the liner is applied, I used a shimmery ivory cream pencil and applied it to the inner corners of the eye. This brightens the eye and also creates a little bit of depth.   Blend in  around the corners. You can use a brush or your fingers
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:angelabchua
Did you know that sewing needles are sharp, and that hot glue from a glue gun really is hot? ouch! I never learn. i should be an honorary spokeswoman for Band-Aid brand first aid products consideri...
more »
