Laminated Plyboard Bar Counter and Tv Stand
Published
Introduction: Laminated Plyboard Bar Counter and Tv Stand
this method is really cool and hard wearing if you make it right
Step 1: What You Need
plyboard offcuts if possible to suit your size and shape
50-75 mm self tapping screws 2-300
a strong waterproof fast setting glue
good quality drill with pozi bit to suit screws
a table saw to cut angles and sizes
decent sander or grinder with sanding disks
a range of sanding disks to smooth and finish
clamps if necessary
i used an environmentally friendly exterior matt clear varnish from harlequin paint in south africa
Step 2: Prepping to Build
decide the size of your item you are going to make - in my case it was 1m wide by 60cm deep by 75 cm high for the tv table
the bar counter is 2,4m by 8cm thick by 60cm wide
the bar stools can be made at any size or height but be careful on the back rest and make a foot rest if needed
make sure your screws can go through at least 3 pieces of board
pre cut the pieces you need
for angles use your table saw at different angles to test the best curve for your item
then its as simple as glue and screw and clamp if necessary
Step 3: Finishing
once your product is built fill any cracks with glue and some excess saw dust lying around
then take your grinder or sander and smooth off the rough edges , using smoother paper as you go.
once smooth clean the surface and varnish at least 3 times with a light sand in between to avoid stickyness
or paint a funky colour
Step 4: Thanks
i hope this instructable - my first of hopefully many - will inspire you to do great things
i will update once the pics of the bar counter are downloaded to pc
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    4 Discussions
    mdredd
    2 years ago
    i will add more info if anyone wants any as well as more photos if i have
    I would love to see more detail on how you made these. The flowing curves are impressive, and I'm very curious the methods you used to achieve them. Got any in-process photos? :)
    i never took in process photos sorry
    in order to make the curved cuts we used a table saw that can cut angles and cut the angles as we progressed
    the flow is important - we started at the bottom and built our way upwards
    i will make a small item like this and take pics for everyone
