Laminated Wood Bicycle Mudguards by adie.mitchell
Contest WinnerFeatured
Step 5: Advanced Laminating
This section will cover a couple topics. the first is what to do if you have made your form, but you decide you want to make mudguards that are longer than your form. the second is all about getting fancy. Not satisfied with just a racing stripe? i'll show you how to do some more interesting patterns.
Over-sized Mudguards
I'm only including this section because this happened to me. after making my first mudguard and test fitting it on my rear wheel, i figured out a way to have my mudguard go as one piece all the way around my rear wheel. but now i have made my forms too small for a mudguard that long. not to worry. there is no need to go and make a new one, and in some ways this way works better than when the form is the "correct length." however, this method does require at least one very long bar clamp.
Essentially,  i did everything exactly the same, except had the ends of the mudguard stick out on either side of my form, and then used one long clamp to pull both ends
towards each other, following the curve of the form. one thing to note is that the mudguard aught to be centered on the form, i.e. with the same length of fender sticking out beyond the form on each end.
Getting Fancy
I decided to make one fender with a more complex pattern. the top layer will still be a racing stripe pattern, but it will be interrupted by slanted dashed lines composed of alternating light and dark parallelograms. (pics coming soon if you cant visualize it).
This is where you an get really creative, and come up with something unique and tailored to your tastes.
If you end up with a complex pattern that is hard to keep organized, you can stick all of the pieces onto a piece of tape for the entire lamination process.
As far as i know, this has never been done before! so i have no idea about how well the lamination will stay together with all those separate pieces. i made this with bits of extra wood, after i had made all the fenders i needed. so if it breaks, i have a replacement anyway.
nduetime says: Dec 28, 2010. 9:09 PM
How did the parallelogram pattern strength hold up once finished?
adie.mitchell (author) says: Sep 27, 2011. 1:32 PM
strengthwise it seemed ok, it just didnt end up very tidy, i never used them because i had enough of the normal pattern.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
