3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laminated salt and pepper shakers
  • last photo ←
I laminate various types of exotic or New zealand wood to form a sculptured piece, in this case a set of salt and pepper shakers. The process is quite complicated but easy to follow, The biggest criteria is accuracy in cutting the timber to the correct sizes. Here are the steps for a set of Salt and pepper shakers. First you start of by cutting a 2 blocks of timber [ main body ] 100mm x 50mm x 50mm lets say this is Walnut, Then 2 blocks of timber lets say Mulberry [ yellow ] [Top] 50mm x 50mm x 40mm. The 50mm x 50mm x 40mm block is glued to the top of the main block, This is then sanded on All 4 sides to remove any excess glue. The next stage is to draw two lines on one of the flat surfaces with a jig [piece of wood 8mm thick] draw a line each side of the jig at a random angle. Make sure when cutting this out on the bandsaw that you cut on the inside of the pen line [ This is very important step ] Once this is cut out you have to sand both surfaces on a 6" bench sander to the pen line [ Again this is very important for accuracy ]. You then machine two slithers of a different kind of timber say [ yew ] This must be 100mm x 50mm x 9mm thick, This will be glued in between the two blocks you have just cut. This is to be glued with Epoxy resin [ HT9000 ]is mixed with HT 110 glue powder to form a glue mix, Apply the glue to both surfaces and glue the two half together, No clamps are needed as friction will hold them together. When dry this will be a 1 ring Salt and Pepper shaker, Repeat the process up to 4 times if you want a 4 ring Salt and Pepper Shaker set, Just remember that the more laminations that go into these sets the harder it gets to make ALL of the glue lines be inline and NOT staggered.
Step 1
17 comments
Sep 23, 2008. 7:36 AMoilpaint2 says:
They are definitely phallic in their shape, they look like sex toys not salt and pepper shakers
Dec 21, 2010. 5:32 PMrendermatt says:
hahaha they are definitely phallic, but I think they look like salt and pepper shakers just as well
Oct 11, 2008. 12:11 AMVidar_76 says:
Glad to see I'm not the only one who thought so... think its the tip that makes it. A few years ago i was teaching woodshop (or slöjd as we call it) When we started using the turner in the fifth grade one of the lads wanted to make "a present for his mom" :-)
Sep 16, 2010. 6:58 PMtim13211 says:
Would you be able to post more pics on gluing for more than one ring?
Jul 30, 2010. 11:25 AMryangranado says:
Beautiful job but what did you do to use as caps for the spices? rubber stoppers on the bottom?? I'm a builder and haven't gotten the courage to try turning yet but after seeing this I am seriously thinking about getting a starter lathe. Any suggestions on one for me?
Jan 3, 2009. 9:18 PMmynameisjonas says:
these shakers are awesome! but I would like to see some more detailed instructions
May 9, 2010. 8:53 PMERCBIENG says:
 I agree
Jan 3, 2009. 9:14 PMmynameisjonas says:
THUD! (jaw drops onto the floor)
Sep 27, 2008. 8:23 PMsoulwood says:
fantastic, beautiful, amazing, total genius, i've been making wood jewelry for 25 years, these things are to die for do you have a web???, would you like to share pics i have some real hot stuff but not at all similar to yours, god i love them
Sep 30, 2008. 7:45 PMcorey_caffeine says:
looks like it would make a nice knife handle but i like stacked leather (could i use this for a steampunk bike grip?)
Sep 23, 2008. 7:30 AMxxgemini says:
wow those are beautifull.... do you sell them? looks like you have a neat little business going. if I had a lathe i would prob try. thanks for sharing .
Sep 23, 2008. 4:20 AMpipeski says:
Not entirely clear on how this is an Instructable, as it doesn't give instructions beyond cutting and gluing some blocks of wood. Also, have you looked into the toxicity of Yew wood? I really wouldn't recommend its use in anything that's going to hold a food product.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:4mem8(clw woodcraft)
a busy busy man with his hobbies lol.
