Step 6Stacking the records
Before we get there we need to drill holes in the base. I started with the threaded rod and acorn nuts all in the three holes drilled through the stack. Once you have that you can remove the clamps.
Mark where the holes need to be on the base. I suggest using a considerably larger bit for this hole. It won't be noticeable under the record and will make threading all the records on a bit easier.
Now move one threaded rod from the stack to the base. switch the acorn nut for a fender washer and a hex nut. Put the drill bit back in that empty hole. Remove the other two threaded rods and put them in the base. keeping your stack of records oriented take one, and flip it over and onto the rods. Put washers on the rods and then take a next and flip it over before putting it on. Keep doing that until you are out of records, you are tall enough for your light bulb, or you like the look of it.
Put the acorn nuts on and gently work the rods back down into the base. Tighten the hex nuts and then use the bolt cutters or a hacksaw to trim any excess threaded rod.
Add Comment
