Step 20Reducing FTDI Serial Latency
Start the Windows Device Manager while your FTDI USB->Serial cable or Arduino Duemilanove is attached.
Look for its corresponding USB Serial Port under Ports (COM and LPT).
Right click on it, and select Properties from the popup menu. Next, click the Port Settings tab, and click the Advanced... button.
In the dialog which pops up, change the Latency Timer (msec) value to 1, and click OK.
After you disconnect/reconnect your device, the new Latency Timer value will take effect.
I am not sure if there are similar settings in OSX or Linux. Hopefully, someone can dig up a similar IOCTL to achieve the same effect.
Add Comment
