Lampe De Chevet CNC Radial
1,021
11
7
Posted
Introduction: Lampe De Chevet CNC Radial
This is the different steps to realize the "Lampe de Chevet" designed with radials and done with the CNC router
What you need is some pieces of MDF wood in 3mm
* Circle parts: 1 sheet of 25cm * 25 cm
* Profil parts: 16 Radials made of 8 sheet of 25cm *25cm
* Electrical parts: you will need an electrical socket of less that 5.4cm diameter
This design is to be sitting next to you bed having the same volume than a classical Chevet Lamp
Step 1: CNC the Different Parts of the Lamp
Please find the plans for the CNC machine, this can also be done with manual equipment if you do not have the required equipment
This can be realized in any material that is 3mm thin
I have realized that with the Zmorph SX 2.0, do not hesitate to tell me if this could be done with other equipment too
Step 2: Assemble the Different Parts All Together
To assemble the parts you will need first to sand a bit all the parts and then fix the electrical support on the middle circle. once this is done then start turning around and assemble the profile one after the other.
Please note that I didn't use any wood glue for this lamp as the bulb need to be accessible in case of replacement
but this is up to you to glue for example half of the profiles
Step 3: Enjoy the Segmented Light Generated When the Light Is On
The once everything is assembled you will be able to enjoy a segmented light that would give the best ever effect in the room.
As this is MDF do not forget that you can easily put some paint on it and have some fun with a colorful lighting too
  • Sew Warm Contest 2018
  • Minecraft Challenge 2018
7 Comments
I love the style. If I get ambitious one day I want to try it with aluminum. Just the top part, and use it as a pedant lamp.....
Hi Rjkorn,
Have been ambitious? I would love to see it remixed with yiur idea... hope you cab make it!
This is a great idea for a remix ... tell me when you have done it and share some pictures
This is a cool project and all...
But since when is MDF cardboard?
Is MDF considered cardboard now? Why is this in the cardboard contest?
Hi Mark,
The reason why I posted that in that contest is that regardless of the material if you follow the same steps with a cardboard of 3mm thin. You will be able to make it.
But you probably better use a laser cutting tool or hand cutter to do so.
Do you agree with that?
Amazing job - congrats!
