Lampshade for Livingroom
4,612
232
15
Posted
Introduction: Lampshade for Livingroom
Hello Everyone
This little instructable took place at my house
The living room
Step 1: Build Process #1
Drive to the nearest wood store and buy the desired size and diameter of the Plywood
Cut it the size you want
Make sure the Plywood are smooth and good looking
Step 2: Cutting
Cut the Plywood you desired size
Step 3: Gather the Frame
Take the Plywood , and attach it to each other , so you have a nice shape like the one above
Strengthen it with Aluminum angles
Step 4: Strengthening the Structure
Strengthening the structure
Step 5: Create the Cube Shape
Attched the two square shapes together so you have a nice cube
Step 6: Attaching the Outer Cover
Take the outer shell and cut to fit the size of each rib
Take a clear and strong adhesive, and paste the cover on each side of caution
Step 7: Pasting
Paste the cover frame with adhesive tape
Just to keepmit tight
Step 8: Wrap the Whole Structure With Wallpaper You Desire
Take a wallpaper the color you want, and cut it to fit the ribs
attached it to the the ribs and make sure you stick it well enough
Cut the excedded wallpaper !
Step 9: Peal Off the Leftovers
Step 10: Prepare the Needed Materials for the Lighting Fixture
Step 11: Lighting Fixture Installation
Lighting Installation is pretty easy.
It needs to be on top of the lampshade , so you only see beneath the lights it self and not the structure
Step 12: Adding Chains to Hang the Fixture
I used very regular , thin chains to hang it .
Make sure it is tighten securely to the upper base of the fixture
Step 13: Hanging the Lampshade - Finally
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    15 Comments
    Great Idea!!! next week i'll do it!!! :-)
    Great!
    Post some pics , i would love the see the results!
    Goooood Luck
    Nice Ible ....
    Nice, I like it too much and I think I will try it and make one at my kitchen soon...
    Go for it!
    It would be nice to see the result
    In step 3, how did you attach the pieces of wood together to make the frame? Is there a specific glue you'd recommend?
    Nice laconic design I love.
    I wold like to make almost the same but turn bulb(s) into ceiling in order to achieve soft diffused light that fill the room without any sharp and annoying shadows. In other words I gonna cancel diffusing SCREEN in favor ceiling as a diffusing REFLECTOR. In this case ceiling must be as WHITE as it possible to minimize light losses. And certain chandelier design should be applied as well...
    Thank you for nice ible!
