Hello All
here is my first Instructable, It’s a beautiful Nixie Lantern clock, A little steam punk and a bit Victorian, made up of mostly of found components
I tend to communicate better when there is something to show so please look at the images and tags, they sometimes will hold more info than the body of text.
Here is a parts list....
-large slab of walnut 2" thick by 36" long and 12" wide
-large slab of maple 1.5" thick by 30" long and 12" wide, both found on eBay
-2" diameter clear acrylic tubing .125" wall about 12" long, any plastic store and eBay.
-an assortment of gears and gauge faces / bezels, knobs and metal bits,
- A nixie kit, I highly recommend a seller on ebay who goes under the name...petes_kits,  here is a link...  petes_kits, http://shop.ebay.com/petes_kits/m.html?_trksid=p4340.l2562
he has to my knowledge the only nixie prototypers board out there that gives the experimenter options of screw terminals, solder pads and designated nixie patterned mounts for leads, not to mention he always answers and is there to help you out.
-you will need some basic electronic skills
-a multimeter with a continuity function (prefer an audible function).
-3 Blue leds
-A mill and lathe for custom parts, machining skills are very helpful
-lots of brass and aluminum
-all sorts of hardware and locktite
-12 conductor 28AWG ribbon cable
-9VAC transformer, wall wart
-assortment of gears, shafts and collars
and finally... lots of imagination.....
Step 1: Finding the way
first step was to gather all your resources and mix and match, try to figure what works and which direction you are willing to head in.
my original concept was to have each Nixie in it own chamber. but through trial Realized I did not want the clock to be lengthy.
after finding the diameter i was going to work in, i made sure the 2 Nixie tubes would fit side by side within the acrylic tube, this required a custom circuit board to be made to not only physically hold the nixies in place but to allow all the terminals to be easily soldered to, this also allowed me to place where I wanted the wires to terminate into the circuit board, out of site.
for the circuit board you will need....
-copper clad single sided circuit board material
-etching solution http://www.allelectronics.com/make-a-store/item/ER-3/DRY-CONCENTRATED-ETCHANT/1.html
-circuit board transfer http://www.allelectronics.com/make-a-store/item/TEK-5/TECHNIKS-PRESS-PEEL-PC-BOARD-KIT/1.html
all materials were purchased here http://www.allelectronics.com/
etch cut drill mount.....
Step 2: Direction found
figured out all the components.
the hub of the thinner gear was cross drilled and a steel shaft  was inserted as the swing pivot (pic 2), same thing was done in the above attachment using an assortment of gears and spacers, a woven wire protective sheath was used to hide the 24 conductor ribbon wire harness.
Idea was to have the fixtures swing, have a friend who owns a yacht and the clock rocks perfectly with the motion of the ocean
Step 3: The wood
found some great slabs of wood on ebay, bought some maple and walnut.
I planned on sandwiching the two contrasting colors of wood.
rough cut the shapes I needed, using a disc sander and a spindle sander I shaped the outside and inside curves.
I registered and drilled some through holes common to all the slabs, Inserting  all thread rods, with washers and bolts allowed me to mechanically tighten and physically lock the slabs together so they can be mounted together into the mill and machined as one piece later to have the ability to disassemble and wire,
components are temporarily mounted on pegs and posts and the clear coat process begins.
make sure you are in a well ventilated space
I brushed on 1-2 coats of clear catalyzed lacquer (cardinal), letting it all soak in. after it hardens start the exhausting sanding process
be cautious not to use a heavy grit, the rule is not to sand through your clear coat layers, if you get to wood you have gone too far.also be carefull not to let clear drops harden, dont spray too heavy, to spray I used a cheap ($14) harbor freight HVLP spray gun and it worked as good as one of my Binks guns.
I used 400 -1500grit through the sanding process.later used automotive polishes of varying grits, hand and machine buffed parts
2 coats brushed- sand- spray -sand -spray -sand -spray -sand -spray -sand -spray- polish buff.
very time consuming took me days to complete but the more work you put into this step the better it looks in the end.....keep it up
Step 4: Electronics, buttons and stuff
using a 3mm led, each acrylic tube is edge lit, the fact the tube ends above the bottom of the bezel allows me to hide an led here (see pic).
painting edges white allows for a uniform bounce for the light.
make sure to insulate the led conductors due to the brass gear that sits above it
getting things together, here you start sorting and testing all the leads coming to the electronics compartment, using spacers for the circuit board, mounting the switches
Step 5: Closing her up
The components are now together,  using a multimeter check continuity from tube circuit board to wire end.
circuit boards (seen in step 1 pic 4) have a lot of traces in a small are, each tube has 12 terminals, the old board i had from pete required all 12 wires to connect to the board, his new prototype board has GREATLY simplified this, cathodes all tie in to the corresponding number cathode across the set of nixies for example cathode 1 tube 1 connects to cathode1 on tube 2 and so on, only the anodes (6 one per nixie) have to be connected one by one, not that hard at all
in picture 3 you will see the three pairs of wires to power the blue leds used for tube illumination, since the clocks board has a power in range of 9VAC to 15VAC. I chose a 9VAC transformer, allowing me 3VAC per led, so I wired the leds in series and connected the two wires directly to the AC input jack. since with AC polarity isn't an issue at 60 cycles they illuminate the tubes perfectly....
try and find an adapter with a 90 degree plug so you can drill and mount the power input plug facing down on the bottom cover plate.
the cover plated can be any thing from plywood to fiberglass circuit board material, i chose the later.bear in mind the recess you milled this depth will be your material thickness for the cover plate.
Step 6: Here it is...
this first picture is the correct color, in my other pictures tubes look a little more violet, this is due to the lit digits of the nixie and their  contrasting orange color.
Pete has included about 28 user settings, you can cycle through them using the adjust buttons, my favorites are the fading digits setting where all digits fade to the next instead of switching, the other is the slot machine function where user can set all digits to cycle every minute, hour or 12 hours..
If you have gotten this far I thank you very much.
and appreciate all your input.
1-40 of 161Next »
hilukasz says: Apr 28, 2013. 7:28 AM
wow that is beautiful. great job.
Evinfire says: Feb 5, 2013. 12:36 PM
Awesome work with high-detail, amazing!
Sacchi-Moto says: Feb 28, 2012. 10:56 PM
This is just absolutly amazing. Your skills and craftmanship show true dedication. Let them get dizzy looking at your work space - "An unclutered desk is a sure sign of a sick mind"... :-)
hellboy (author) in reply to Sacchi-MotoFeb 28, 2012. 11:28 PM
Thanks Moto, just slightly sick, I mean neat......who am I kidding........did you check out my other clock?
electridanger in reply to hellboyJan 8, 2013. 8:09 AM
You have another clock..... O.o
Vibetrippin says: Nov 1, 2012. 12:31 PM
That's awesome and I want to make one similar to it myself. Where did you find the "assortment of gears and gauge faces / bezels, knobs and metal bits"?
hellboy (author) in reply to VibetrippinNov 1, 2012. 1:50 PM
Some of them I salvaged from old instruments and clocks and I have an assortment of custom gears left over from the other projects I design and build
thumper1102 says: Oct 30, 2012. 9:44 PM
How much for you to make me one?
Tek909 says: Oct 10, 2012. 6:02 PM
I created an account just to comment on this project.
Stunning!!!! Can I ask where you sourced the tubes from?
hellboy (author) in reply to Tek909Oct 10, 2012. 7:29 PM
Hello
Thank you for the compliment, I first found the nixies on eBay, a guy named Pete sold them to me he expanded his business over time so now I get them from his site.
http://www.pvelectronics.co.uk/index.php
He is very helpful and always responds quickly to any issues, which is why I buy from him....
Let me know if there is anything else I can answer and thanks again
Jack E
Tek909 in reply to hellboyOct 10, 2012. 9:41 PM
thanks for your reply on this. i havent done anything with electronics for years but your clock is just amazing.
i really don’t like clutter or things that can gather dust but for the first time ever i actually grabbed my wallet instantly and didn’t really care about the cost in the hope that you were selling these.
As your not I will have to make something myself. Do the tubes give off heat. I am thinking about pulling the housing off my pc screen and replacing it with something more steam punk. Nixie tube clock running down the side would look awesome.
hellboy (author) in reply to Tek909Oct 10, 2012. 10:37 PM
The tubes give off very little heat, however they are running anywhere from 70-150 volts AC, I'm not sure but this might cause some distortion on a screen if not properly filtered, if you are hung ho about modifying your monitor I suggest building the kit then holding it near your screen prior to modifying it, to see if it screws with your monitor. Personally I would rather build anything build able by your own hands, it gives one pride when you can point at something and say I built that....
Good luck...
Hithorable says: Sep 23, 2012. 8:34 PM
That's just amazing! i totally love it!, i could pay to have one of those =) congratulations!
waterlubber says: Sep 3, 2012. 11:15 AM
Wow. Just wow.
What are nixies?
EPICNESS-O-METER-OMETER:
_ _ _ - - - ` ` ` ☺
1 2 3 456789 10
LEVEL: 11-TOO EPIC TO RATE!!! BZZT!!! *explodes*
hellboy (author) in reply to waterlubberSep 3, 2012. 12:26 PM
LOL thank you.....
gor82 in reply to hellboySep 6, 2012. 11:00 AM
How much would it cost to buy one of these?
hellboy (author) in reply to gor82Sep 6, 2012. 2:07 PM
There is only one and it's not for sale.....working on an exhibit and this is one of the pieces in said exhibit.....
waterlubber in reply to hellboySep 9, 2012. 5:15 PM
If you had a time machine and brought this back to...oh, say the Victorian Era, the people would explode.
dada11 says: Sep 5, 2012. 12:37 AM
AAAMaazing!.. this guy is an alien. =)
57ub31 says: Jun 27, 2012. 7:51 PM
Where did you get all your brass hardware? I'm having trouble finding parts, especially the gears.
radioman673 says: Apr 15, 2012. 8:42 PM
Hellboy this is "hellagood" =) how much for a kit? im great with electronics and would love to build one while im here in Kuwait but have limited access to any thing other than hand tools and a soldering iron dale.l.allred@gmail.com
Screwpa in reply to radioman673May 31, 2012. 1:03 PM
Me Too, Me Too!
thejunkmonger says: Mar 3, 2012. 12:35 AM
Any chance of getting a pdf template of the base/arcs this is one awesome clock
hellboy (author) in reply to thejunkmongerMar 3, 2012. 1:51 AM
There were no spec drawings generated for this or most of my pieces, I do a conceptual drawing, keeping in mind what I have, during the illustration, then just build...
A company has already approached me about this and I gave the same response,
I am very grateful for your appreciation...
Jack
thejunkmonger in reply to hellboyMar 3, 2012. 2:10 AM
Thanks, great work
You could always scan the template you used to cut the wood.
longwinters says: Jan 24, 2012. 6:44 PM
This has to be one of the best projects I have seen here or anywhere, I gave up trying to count the different skills used to construct it.
I love the wood work as I have done much furniture building, but the brass work puts this over the top, thank you so much for posting this, my poor old NIXIE clock will never be the same, in a some what grumbling tone, thanks for raising the bar so high, off he goes pondering the quality of his next project.....
chvdwalt says: Jan 16, 2012. 4:03 AM
This is truly awesome! I'm blown away!
DaPope says: Jan 9, 2012. 7:22 AM
What was the total cost of this project? It looks AMAZING and I would love to build/buy one.
electronfan says: Jan 5, 2012. 7:25 PM
I thought to have seen really cool things, but this really blew my mind! Truly an amazing piece of art!
electridanger in reply to electronfanJan 8, 2012. 7:36 PM
I wouldn't classify this as art...I would classify this as pure epicness
GASSYPOOTS says: Jan 2, 2012. 4:47 PM
how do you read it!?!?!?
hellboy (author) in reply to GASSYPOOTSJan 2, 2012. 11:26 PM
As you would a digital clock, left to right, first cylinder has 2 nixies for the hour
Second is for the minutes and the last the seconds...
ReplyFeature Commentflag[delete]
GASSYPOOTS in reply to hellboyJan 4, 2012. 4:10 PM
uhhh i dont seee and #
tlynch1 says: Dec 26, 2011. 9:46 AM
ok that is one amazing clock you're work is top notch!!
THEORANGESNOWFROG says: Dec 26, 2011. 8:12 AM
You have done an amazing work! Nice instructables!
kgroce says: Oct 7, 2011. 11:59 PM
can you make me a clock .. i'll pay :() Jepito@Gmail.Com
ithi in reply to kgroceDec 25, 2011. 3:56 AM
can you teach me.. i love to do new things like that m.ibthisham@gmail.com
Llamarama says: Dec 23, 2011. 2:23 PM
This is easily the most beautiful Nixie clock I have ever seen, in my opinion. Simply wonderful! Well done!
hellboy (author) in reply to LlamaramaDec 23, 2011. 5:35 PM
I can't express how good a person feels after receiving reviews like these, I thank you very much....
Llamarama in reply to hellboyDec 24, 2011. 9:44 AM
It's just such a beautiful object! Nixie tubes are almost hypnotic all of the time, this brings it up to a whole new level! :)
1-40 of 161Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
