Lantern Torch LED Conversion
 by x2Jiggy
Featured
Harness the power of modern lighting technology by converting a standard lantern torch into an LED torch. LEDs provide the advantage of longer bulb life, reduced power consumption (originally 750mA, now 320mA) and reduced heat. This project uses 32 LEDs which provides slightly more light than stock while using under half the juice. I've made a video showing the basic steps involved in making the project. You'll be building a small LED light and installing it in the reflector. This light is then connected to the circuitry in the torch so it operates as per normal. If you're keen, take a few minutes to view then continue on to the detailed instructions. If you enjoyed the video, please consider subscribing to my youtube channel as this helps towards producing more videos and projects.
Step 1: Equipment
Parts:
- 1x 6v Lantern Torch / Flashlight (Amazon)
- 5mm White LEDs ( Amazon / DealExtreme ) Any multiple of two. I used 32 LEDs for this one.
- 1 Ohm 1/4W Resistors ( Amazon ) One resistor required for every two LEDs used.
- Disc shaped wooden or plastic object that fits inside the reflector to mount the LEDs. I used a jar lid that I trimmed down.
- Thin gauge wire.
*Affiliate links provided to suitable products on Amazon.com and DealExtreme.com
Tools:
- Soldering equipment
- Drill, tape and stationary
Step 2: Disassemble Reflector
Remove the lens from your torch. You may need to remove the bulb before you can get the reflector out. Ensure nothings securing the reflector in as it can be a bit delicate and may break if removed with force. In my case, the lens was attached directly to the reflector and had to be removed also.
Find or make a circular disc like object made from a thin wood or plastic that will fit in the reflector. I used a jar lid with the threaded section trimmed off for some bonus kludge points.
Step 3: LED Mounting Holes
Apply a layer of masking tape over your disc and rule a grid that will evenly space your LEDs over its surface. Keep in mind that you need to have an even number of LED mounting holes. Once you're happy with your measurements, use a small drill bit to drill pilot holes. This helps to accurately reproduce your grid on the disc. Drill out the pilot holes with a 5mm bit. I used some sand paper to clean everything up afterwards.
Step 4: Install LEDs
LED pairs are going to be connected in series with a resistor. Each pair will then be wired in parallel. Install a pair of LEDs and bend the legs to connect the positive leg of one LED to the negative leg of the other creating a pair with a single positive and negative leg. Apply some solder to the join to secure the pair together. Continue until all the pairs are installed.
A resistor will be added to limit the current applied to each LED pair ensuring only a safe amount will be supplied. This will ensure your LEDs lives are not tragically cut short and you can enjoy the LED benefit of longer lamp life. Clip the negative leg and resistor leg to around 5mm in size and solder. Repeat for each pair. Although it doesn't matter which way you attach the resistor, I'm a stickler for installing them all in the same orientation. You can now test each LED pair using the 6v battery for the torch.
Step 5: Complete LED Light
We now need to connect each LED pair in parallel which basically involves soldering all the positive legs together to make a single positive leg and the same for the negative. Bend each positive leg over to connect to the one next to it, clip them to size and solder them together until only your single vertical positive leg remains. When connecting the negative legs, ensure you're making the connection after the resistor so you don't bypass it. Adding the resistor raised the height of the negative legs allowing you to make connections over the top of your positive ones easily. Be careful not to accidentally connect any of the negative and positive legs together as your light won't function.
Once all your pairs are connected in parallel and you have a single positive and negative, connect a wire to each and extend these connections. It's not a bad idea to insulate the solder points for these two wires with some tape or heat shrink tube. Test your light with the 6v battery and ensure all the LEDs light up. If they don't, examine the connections to the LEDs that didn't light. Run the two wires through your reflector and secure the disc in with some glue. You now have a completed LED lamp ready for installation.
Step 6: Install Lamp
We need to wire our new LED lamp into the current circuitry of the torch. A standard lantern torch simply has the battery connected to the globe through a switch. We're going to connect the lamp in the globes place. Cut the wire between the switch and globe terminal as shown in the attached image.
Solder the positive lead from your lamp to the wire connecting to the switch and the negative lead to the wire connecting to the globe terminal (I soldered my to the terminal directly). The globe used to make a connection between the globe socket and terminal (see images) however as he's absent we need to bridge this connection with a piece of wire to complete the circuit. Install your reflector and assemble the torch. Push the button and be smug, you have the Prius of lantern torches.
More projects and videos at x2Jiggy.com. You can also follow my twitter feed @x2Jiggy.
1-40 of 57Next »
LP2 says: May 14, 2013. 10:11 AM
This will definitely help me with my Boat spotlight.
Thanks !
sbdash11391 says: Nov 17, 2012. 3:15 AM
but does it boast the same focus as it had previously....i don't think so....i would consider the same task being done with 26k cmd leds in a tighter arrangement so that it fits deeper down the reflector...also you have a plane reflector...not the ones with tiny individual rectangular reflectors arranged within the reflector surface ...i aave one and will modify it but with some design inputs from my side too...
krstn1 says: May 6, 2012. 9:29 PM
If I wanted to run a configuration of this off the 12 system on my truck, what kind of resistors should i use so not to blow the leds?
profpat says: Nov 27, 2011. 3:04 AM
nice idea,
i have an old rechargeable lantern that has busted 4.8volts halogen light bulb, i think i can convert it to this kind of design.. i want to use a smd hi intensity single led bulb the one used for gun flashlight!!
レレイ says: Oct 12, 2011. 7:03 PM
Is it still possible without the reflector? Cause when I opened my old flashlight, it was broken. Is there anything I can do? In exception of getting a new reflector or buying new one.
Dipankar says: Sep 25, 2011. 5:10 PM
Are you using a rechargeable 6volt battery or Alkaline Battery?
See my POWER PACKED LED FLASHLIGHT
which uses a rechargeable 6 volts 4.5 Amps leak proof lead acid Battery. The Charging is done outside the light casing with a 6 volt charger. Published:Aug 8, 2010.
Its the same game with a different name?
x2Jiggy (author) in reply to DipankarOct 5, 2011. 4:55 AM
Just a standard 6v spring terminal lantern battery. You weren't kidding, that flashlight is power packed! Plenty of LEDs there. Nice touch with the rechargeable battery.
smalcolm says: Sep 22, 2011. 10:56 AM
Nice work, looks like a project for me.... but I wouldn't be smug about owning a prius lol
Kusunoky in reply to smalcolmSep 30, 2011. 6:46 PM
lool True good project. wish one day I can make one I love LEDs things this for me as well look like a project specially because I dont know NOTHING about electrics lol. Good Work! May be one day I will try this.
radracer says: Sep 28, 2011. 10:37 AM
Now this is a sexy flashlight.
robertblacksmith says: Sep 22, 2011. 10:16 AM
I've noticed that allot of the tail lights in cars are LED. how hard would it be to us one of them in this manner?
x2Jiggy (author) in reply to robertblacksmithSep 23, 2011. 3:32 AM
Yep, micahd02 makes valid points. Anything designed for automotive use is designed to handle input voltages of 12v and up as a cars electrical system doesn't provide a stable source of power.
If you wanted to salvage LEDs from something and use it with this project, it would have to be designed for an input voltage of 6v as this is the voltage of a standard lantern battery.
pcooper2 in reply to x2JiggySep 28, 2011. 8:02 AM
The one advantage of the lantern battery is that its voltage will never be higher than when it is fresh and fully charged. If the current limiting resistor value is chosen on this basis, the life of the LEDs will be maximized.
Using LEDs salvaged from an automotive lighting system carries no disadvantages whatsoever. One must simply adhere to their maximum current rating. Finding out what that rating is could be problematic, though, if the part number and manufacturer can't be identified, which one would need to get the specification sheet.
micahd02 in reply to robertblacksmithSep 22, 2011. 10:56 AM
Those are designed with built-in current regulation to run on the output of a rectified alternator, where the input voltage CAN'T go below 12 Volts for more than a couple of minutes, and, depending on the car, routinely go anywhere from 13.8 volts up to around 27 volts, with spikes into the 10s of thousands of volts. The lower "running" voltages alone make it expensive to design and build them, and make them cumbersome for a light-weight application like this, but the fact that they can't run on less than 12 volts means you would have to use TWO 6 volt batteries to drive them, and those would be heavy for a hand-held torch.
In addition, the voltage spike protection further increases the cost, and isn't necessary at all for this application. I doubt that it would be worth even considering using one of those for this.
jonpersonals in reply to micahd02Sep 25, 2011. 1:57 PM
Yes I see car voltages from 11. to 14.5 at least. So I am thinking a voltage regulating system using a 555? chip, they were used to regulate V. in several circuts I believe. It seems this would be perfect and maybe eleminate the resisror? ....
HELP please! I need to put in lots of lights in my camper; and cant handle the heat and huge power drain of regular lamps. Thanks.
pcooper2 says: Sep 28, 2011. 7:38 AM
x2Jiggy, LEDs come in all kinds of body styles and lens configurations. Did you choose narrow-angle LEDs, wide-angle LEDs, or just-any-old hobby-grade LEDs?
medionlvr says: Sep 22, 2011. 9:56 AM
I'm looking at www.superbrightleds.com and there are white led's that have a luminous Intensity of 18,000 millicandelas. They have a typical forward voltage of 3.4 volts with a max of 4 volts. Would a resistor still be necessary ? I don't pretend to understand this but it seems to me that a pair of led's in series that operate at 6.8 volts each and i'm only providing 6 volt to the pair i should be under the typical voltage and surely be under the max voltage of 4 volts.
keithwd in reply to medionlvrSep 23, 2011. 11:40 AM
I have found through testing that all my LEDs (superbright and standard) work off of 2 standard D cells or alkaline batteries at approximately 3 volts--but will not work off of most rechargeable batteries which usually output less than 1.2 volts each for a max voltage of 2.4 volts
Some LEDs have a max of 4.5 volts like mine. But when I tried 3 D cells per superbright LEDs they were brighter--but not that much (to the naked eye anyway). Therfore I decided to use 3 volts because that was as bright as I needed and power consumption and heat generated was a lot less.
A second advantage of using 3 volts and alkaline batteries was that the lights dimmed noticeably BEFORE it drained the alkaline to the point that it could not be recharged with my "ReZap Battery Engineer" alkaline battery charger.
micahd02 in reply to medionlvrSep 22, 2011. 10:49 AM
It might work. But LEDs are constant CURRENT devices, and working with under-voltages may not generate enough current to drive the LED into conduction. In which case, it won't heat up and burn out. But that's not much use since it also won't light up. And the discharge curve on your battery is such that as soon as you hook it up, the voltage starts to droop, so it's touchy how much time it would be at 6 Volts, anyway.
Since there seems to be a fundamental lack of understanding about this, Voltage into a load (the LEDs and any resistors) generates a current THROUGH the load proportional to the voltage applied. And as long as the voltage is somewhere near (say, no more than three times the rated voltage of the load) but higher than the rated minimum voltage of the load, internal battery resistance doesn't affect the equation, so the formula for current becomes Voltage (in Volts) divided by Resistance (in Ohms) equals Current (in Amperes) (or Amps). And for those of you who are accustomed to the metric system, milli-amps is, as you would guess, thousandths of amps. So one milli-amp is one-thousandth of an amp. You can figure the rest. And, yes, milli- is also applied to volts and ohms.
pcooper2 in reply to micahd02Sep 28, 2011. 7:35 AM
Your statement about LEDs being constant-current devices is correct. Excess current will kill an LED far short of its expected 100,000 hour life, like Chinese-made LED night lights that fail in just one year, when they should last 7+ years. Most LEDs run on 20 mA to 25 mA, and the current needs to be properly controlled by use of a regulated DC power supply and current-limiting resistor or a constant-current power supply.
gbevilacqua alen in reply to medionlvrSep 22, 2011. 10:24 AM
You must ALWAYS use a resitor with LEDs, or it'll burn itself with time (or very fast).
I recommend you to use an online tool for the design, and try different (parallel and series) setups:
http://ledz.com/?p=zz.led.resistor.calculator
shocker187 in reply to gbevilacqua alenSep 22, 2011. 10:35 AM
Hmmm, I am lead (led) to believe otherwise, by persons that know on various 12v and electronics forums,that is one DOESNT always need to use resistors...but hey ! tell me Im wrong , I like to learn !
x2Jiggy (author) in reply to shocker187Sep 23, 2011. 3:55 AM
One of the big benefits of LED lighting is long life and LEDs are very sensitive to increases in current. Unless you can guarantee the current supplied (usually by building or purchasing a regulated driver) it's good practice to add a resistor or risk an early death for your LEDs.
Some people choose not to use a resistor when their input voltage matches the LED forward voltage, however without a resistor a small change in voltage can produce a large change in current. Resistors are cheap, easy to install and when you add the resistor a change in voltage will produce a proportional change in current protecting your LEDs.
shocker187 in reply to x2JiggySep 23, 2011. 5:35 AM
In-ter-esting ! As a digression , the situation I had in mind was a string of leds that were to be fitted to a car as day running lights . I inquired about resistors and was told that since the forward voltage etc ,blah,blah, (what you said above !) I didnt need resistance added.
I have been worried that the current change produced by the voltage range on a 1990s land rover, roughly 12 and a half to 14 and a half volts dc would indicate the need for a resistor and since I cannot find out what even using online calculators I havent fitted them.
keithwd in reply to shocker187Sep 23, 2011. 11:56 AM
If you have a source of power (like a D cell battery) that never exceeds the max forward voltage of the LED you can do without the resistor.
But a automotive electrical system has a constantly varying output as noted in other post here. If I wanted to use LEDs from a automotive electrical system I would buy or build a circuit that limited the voltage and as well preferably limited the current going to the LEDs and included spike protection.
Years ago I connected an oscilloscope to a car battery and noticed that the ignition coil was inserting high voltage spikes into the 12 volt systems of over 1K volt every time the spark plug fired. This was in the days where they used "points" before they switched to electronic ignition systems. So an older car could be really rough on LEDs and other electronics. Most car radios and common auto electronics have built in spike protection to prevent this problem.
Has anyone ever connected an oscilloscope to a modern electronic ignition car to check things like this?
medionlvr in reply to keithwdSep 23, 2011. 3:23 PM
thanks for all the replies. as this project uses a 6 volt DC battery i guess my question was answered.
shocker187 in reply to keithwdSep 23, 2011. 3:03 PM
Diode for spikes, cap across neg/pos supply for smoothing ? In my case Im talking diesel,traditional diesel,always diesel.Not common rail or electronic injection . And yeah , the current variation caused by that 2v range....well,doesnt sound a lot until you look at it as a percentage of total.
keithwd in reply to shocker187Sep 28, 2011. 9:17 AM
To respond to your situation, yes I think the diode and cap would work for a diesel.
But I "think" it would NOT be enough for a gasoline engine (of any type). Spikes and short over voltage situations often only "weaken" the transistor based components like IC chips and diodes which then fail after some unknown time period. That is why that after lightning damage to your home, your home electronics continue to fail for months afterwards.
The more times the electronics are subjected to surges the weaker they become. Since a "spark ignition" system, if in bad condition, "could" hammer the diode and other electronics in you car thousands of times a minute I think I would install 24 volt MOVs to reduce the strength of any surges before they reach your surge protection circuitry in this type of car.
MOVs are devices that short out above a specific voltage and revert to a high ohm resistor when the voltage drops. They look like large (even giant) ceramic disk capacitors. They also wear out after X number of high power spikes and have to be replaced. In the case of an ignition system I don't think the power would be high enough to make this a problem.
The time the MOV conducts is limited to the duration of the spike plus a few milliseconds. In the case of spark ignition caused spikes, these only last for a few milliseconds and the voltage during that spike is limited to 24 volts.
Normally 24 volts would "burn out" any 12 volt electronic component. But because this "burn out" is caused by heat generated relative to the duration of the over voltage--"usually" the heat generated by this over voltage during the few milliseconds or less that the spark induced voltage is over 24 volts is not enough to damage the device. But given the thousands of times a minute that your electronics could be subjected to this over voltage it could be possible that the heat build up over time could destroy the LED or other circuitry.
I don't think this would happen in a car where the ignition system was in good shape, but if it had problems and was feeding large spikes back into the 12 volt system it could. Also late model cars (which are dripping with electronics) must have installed something to prevent this or designed it in such a way that this was not a problem.
stuuf in reply to shocker187Sep 22, 2011. 11:48 AM
If the power supply outputs less than the LED's maximum voltage, you don't need a resistor. But if the voltage drops too much you will lose a lot of light. So it's best to use a higher voltage supply and drop the excess voltage through resistors. The more voltage goes through the resistors compared to the LED(s), the wider voltage range it will tolerate without changing brightness too much. But you waste more power and dissipate more heat that way.
pcooper2 in reply to stuufSep 28, 2011. 7:55 AM
Resistors or a constant-current source are ALWAYS needed with LEDs. They are current-controlled devices and a have a fairly sharp turn-on "knee" in their V-I curve. Too little voltage means they don't turn on. Slightly more voltage means they turn on and allow too much current to flow, destroying the LED in a matter of seconds, if that long. Relying on the internal resistance of the supply is a bone-headed approach and would get your fired if you were designing such things for a company.
stuuf in reply to pcooper2Sep 28, 2011. 8:10 AM
there seem to be plenty of "bone heads" building $4 LED flashlights with a PCB full of white LEDs running directly from 3 alkaline cells with no resistor :P
shocker187 in reply to stuufSep 23, 2011. 3:55 AM
Thanks Stuuf - good stuff ! Makes sense.
To lead on from your post, I have always thought that the main point of using leds (to me at least) was the lower power consumption......so the need to use resistors to up the load suggests that one would be in a situation where the power consumption was similar to incandescent luminaires , so making it a pointless exercise.
However, with the emergence of better spectrum and brightness of leds maybe the cost/benefit scales begin to swing back to favour them. Maybe.
So I think with my limited understanding, anyway !
Richone says: Sep 22, 2011. 10:36 PM
I have also used tihis method of replacing the bulb in lanterns.One thing I did different was to point the outside bulbs toward the reflector so I got a better light spread.It works great!
keithwd in reply to RichoneSep 23, 2011. 11:23 AM
That works...
Another solution is to use larger diameter LEDs. I have been experimenting with 10m,m superbright LEDs which have the same internal sized and power as the smaller diameter ones. (Bought from American Science and Surplus)
The difference in the size allows for a larger lens which spreads the light more giving you a wider and more diffuse pattern.
x2Jiggy (author) in reply to RichoneSep 23, 2011. 3:06 AM
That's an interesting idea. Will have to give it a test in future LED projects. Although 5mm LEDs can provide a strong light source, it's more focused compared to the stock bulb and reflector.
x2Jiggy (author) says: Sep 23, 2011. 4:08 AM
Really pleased with the positive responses and suggestions for improvements to this project. Looks like a version 2.0 with some additional features and refinements could be the go in the near future. Thanks and happy tinkering!
Richone says: Sep 22, 2011. 10:39 PM
Also,Go to your local recycling places and look for the Walk and dont walk signs.They will sell them to you,because they are plastic and can't recycle the plastic.
-max- says: Sep 22, 2011. 7:56 PM
to make the torch super useful, stick a power led in it. i recommend cree t6! that thing is super bright! (its 100 lumens per watt @ 1000 lumens [max] )
ijakidi says: Sep 22, 2011. 12:02 PM
Muy bueno el proyecto, lo tendré presente para cuando reúna los materiales, creo que podría mejorarse la luminosidad si se tapara la parte trasera de los led, para que no escapara luz para el interior de la linterna. y como ya se dijo mejorar el reflejo la base de los led con pintura o papel aluminio.
Kiteman says: Sep 18, 2011. 3:55 AM
Nice job.
Next challenge: replace the lantern battery with a re-chargeable battery and a winding charger.
1-40 of 57Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
