loading
Step 11: Final Assembly
1 | Begin by fitting the LCD panel into the screen pack. Secure the WiFi Card, and the menu board.
2 | Add the logic board & Bluetooth. I have secured the HDMI cable with a ringed Tie-Wrap. Plug the Wifi Card & Bluetooth into the harness. Check all the connections. I have folded the IDE cable so it will sit comfortably in the space provided, and pass through the panel without snagging.
3 | Fit the screen pack into the upper case.
4 | Plug the harness into the USB Hub, & the Raspberry Pi. I have secured the cable with a Tie-Wrap and sticky block.
5 | Fit the speakers into the upper case. I had originally planned to use the grills to hold the speakers in place, but I decided against this and drilled out holes for screws.
6 | Wire the speakers wires into a 3-pin DuPont connector.
7 | Add the slide switch, and screw into place.
8 | Put the GPS in.
9 | Mount the panel mount USB socket.
10 | Check everything is as it should be and that you haven't lost the keyboard.
11 | Wire the top wood panel into the lower case.
12 | Secure the panel with counter-sunk screws.
13 | Make sure it closes properly.
<p>This is cool, i want to do the same but with a solar charged 7Ah lithium pack.<br>I also have a 15&quot; lcd in the parts bin and a wireless keyboard/touchpad, only need the raspbi and alu case :D</p>
<p>With the New Raspberry Pi 3, Wifi and Bluetooth are a Lot cheaper! But I still want Something I can charge with a MicroUSB. Anybody know how to do it?</p>
Question: Is it possible to use a bigger keyboard?
<p>Hi, I've added your project to the <em style="">&quot;</em><em style="">8 Impressive Raspberry Pi Laptops</em><em style="">&quot;</em> Collection</p><p>This is the link If you are interested:</p><p><a href="http://www.instructables.com/id/Awesome-DIY-Raspberry-Pi-Laptops/">http://www.instructables.com/id/Awesome-DIY-Raspbe...</a></p>
Hehe, here in Finland we call the lapland lappi :)<br>But very cool project!
<p>One very cool project - I can see customization of the this project to suit the individual's needs. Could be made into a kit form and marketed or it could be cottage industry for PC enthusiast. I have been in the electronics/PC industry 47 years and this project as I said before has great potential.</p>
I made mine out of lego. I used an odroid x2 board. I powered the screen from an external phone battery charger, and the board from a 12v battery supply. The 12v supply was connected to a car usb charger.
<p>What keybord did you use???????</p>
<p>im making one! this is great!!!it is AMAZING!!!!!!!!!!!!!!!!!!!!!!! </p><p>im soooooooooooo happy that this does not have a 3d printer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!</p>
<p>Great! I noticed your Pi looks different than mine. What kind is it, and will this work with newer versions of the Pi? Also, since you put the &quot;Fixing things that were wrong&quot; Does that mean the whole Tutorial has mess ups in it? Very Confused</p>
<p>Hi SilverJimmy! I am Sahas. I made My own version of the raspberry pi laptop. You served a great inspiration! Thanks... Check it out here: </p><p><a href="http://www.instructables.com/id/Pi-Berry-Laptop-The-Classic-DIY-laptop/" rel="nofollow">http://www.instructables.com/id/Pi-Berry-Laptop-Th...</a></p><p>Also I have entered it into the Remix Contest, Raspberry Contest, Epilog Contest. </p><p>Thanks Again!</p>
<p>How long does the Raspberry Pi last on battery power with the 15w 3amp converter. and 8 1.5v AA batteries. I am looking at a portable project. A very low budget project.</p>
<p>In the process of building my own! This project Rocks!! Thank you for some great ideas! I love what you did here! </p>
<p>Is there an alternative to the raspy juice expansion board? They are currently out of stock</p>
<p>something like this would probably work | https://pi.gate.ac.uk/pages/mopi.html</p>
<p>I have a project of a small computer but with a DVD\CD Player. I know <br>that it's impossible to use a CD player with an Android Tablet so my <br>question is : Is it possible ? How ? (Hardware and Software ?)</p>
Would it be practical to make the case water and or air tight?
<p>Wifi, GPS, &amp; Bluetooth you decided the hard way. You can just use mini dongles.</p>
<p>Exercise me, how big the Aluminum Case should I buy?</p>
<p>Also keep the shields (wifi, gps, bluetooth..) in your mind. They all must be fit into lower area.</p>
<p>Depends on your screen size. You'll need to match it to your LCD.</p>
<p>about 7 inch lcd. A <a href="http://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.4.26gwB9&id=20379451332#" rel="nofollow">25.5X16X8CM</a>(XxZxY) Aluminum Case? </p>
<p>So long as the internal space is large enough for the screen you'll be fine. Remember to account for a border around the edge to mount the LCD.</p><p>I no longer have the LapPi in my possession, or a 7&quot; LCD so unfortunately I can't take any measurements for you.</p>
<p>Oh too bad :(</p><p>I think 8cm whole tall and 4 cm per side tall is OK</p><p>Should I use bigger case like 9.5cm whole tall ?? </p>
<p>Approximately how much does this all cost? </p>
<p>from what I remember it was about &pound;200. I built it from spare parts so I can't give an exact figure. I imagine you'll be able to build it for a little less than that now.</p>
<p>make a larger keyboard and a thinner case. seriously. also polish the wood or replace it with plastic, doesn't fit well.</p>
<p>can you make me one? how much</p>
Sir, I recommend a larger keyboard.
<p>Hi,</p><p>Check this shop out for the amp kit, </p><p><a href="http://www.rkonlinestore.co.uk/" rel="nofollow">http://www.rkonlinestore.co.uk/</a></p><p>Laters</p>
This is one of my first instructable but the battery is connected to the what
<p>Great project! I love homemade raspberry pi laptops ;)</p><p>Here's is a good webstore to buy the parts that you are using in your project: <a href="http://voltatek.com/en/7-raspberry-pi" rel="nofollow">http://voltatek.com/en/7-raspberry-pi</a></p>
I also am in need of a screen or a power source for my screen
how curious I am currently working on a raspberry pi laptop I call it the pi-top
Cool!
I'm been thinking about making a raspberry pi umpc using a sylvania 7 inch laptop like the ones you can get at cvs pharmacy as a case. Does anyone know if the rpi will fit and if the circuitry such as the screen, battery pack, keyboard, ect. would work? <br> <br>UMPC stands for ultra mobile personal computer. (kinda like the open pandora) <br> <br>with that said please dont tell me about the red and black 3d printed cased one else has made, because that one is bulky and doesn't fold. i would try to build something much sleeker and more expensive looking.
Something like this?<br> <br> <a href="https://wiki.openjdk.java.net/display/OpenJFX/DukePad" rel="nofollow">https://wiki.openjdk.java.net/display/OpenJFX/DukePad</a>
Awesome! <br> <br>&iexcl;Alucinante! (In spanish)
What is this capable of? How much can it handle? Btw nice design mate.
It can do whatever a Raspberry Pi inside an aluminium flight case can do. Really it's a case of what can you do with it.
mate I will pay you cash + your time can you please make me one absolutely amAZING
How big and how heavy is the final product? <br>
Can you make me one? I will pay US dollars, name your price, I will pay for shipping and handling, I you want to make it! Thanks for listening, and bless your face! If you sneezed while reading this bless you, email me at nicholaslupo1@gmail.com <br> <br>
I scrolled already trough a billion pages on all diffrent sites how much did you pay for the case?
&pound;24.99 for 3 cases of different sizes. They were from Maplin.co.uk, but I can't find them listed any more.
Where can i get a cheap aluminum case
eBay?
What is the weight with everything in it
how much does this cost overall in $
About This Instructable
423,417views
1,102favorites
License:
Bio: A passionate make of things. Chief engineer for the BigBox 3D printer and inventor of the MicroSlice Mini Laser Engraver & Cutter. I spend my time ... More »
More by SilverJimny: Astrophotography with the Raspberry Pi Zero. Glow-In-The-Dark Nuclear Bomb Night Light. 3D Printed In-Dash GPS Navigation - Raspberry Pi 3.
Add instructable to:
