Laptop Bubble Stand
Laptop Bubble Stand
Everyone is always making laptop stands that, albeit functional, are rather hideous to look at. This becomes less than ideal when you consider that typically, when the laptop is not on the stand, you have to look at it. I wanted to fix this problem by making a laptop stand that was sleek, stylish, inexpensive and kept my laptop cool. With this in mind, I arrived at wicked cool laptop stand that can be made for under $10. The best part is that not only is it cheap, but it's also dead easy to make.
Main image courtesy of Sarah.
Step 1Go get stuff
Go get stuff
You will need:
A 16" x 16" sheet of 1/8" acrylic (this leaves a little room for margins/scrap)
A heat gun
A ruler
Oven mitts
Two table clamps
A workbench
Some plywood scrap
A laser cutter
(if you don't have a laser cutter, you can download the file in the next step and have a service like Ponoko cut it for you.)
117 comments
1-40 of 117next »
Dec 28, 2011. 12:13 PMMRedu says:
This is by far the best laptop stand on instructables (there's a lot of them).
Dec 12, 2011. 6:31 AMmvan heemst says:
Can I buy one from you? I would like a clear one (not clear blue, just plain clear) I would buy one for $30 including shipping. You are right! No one else makes one that looks as good as yours.
Dec 30, 2010. 8:01 PMKlayton Kress says:
What does the red button on the wall do. It makes me curious and I have the urge to press the button. On a side note great instructable
Mar 7, 2011. 5:28 PMpingo6 says:
do you mean in like a tech ed room? do not push the button!!! it is an emergency elctrical button that if pushed will shut off power to the WHOLE room. like if someone gets their arm stuck in a woodchipper
Mar 13, 2011. 8:59 AMostomesto says:
my school's workshop has that. It reminds me off the game dont press the red button. BUT ITS SO TEMPTING TO PRESS THE RED BUTTOM
Sep 22, 2011. 5:11 PMThe nerdling says:
my school's workshop has one too, but it is so crap, you don't need the key to turn it on; you just push it down then pull out and hehy presto power!!
Aug 16, 2011. 9:22 AMDONALDTMCKINNEY says:
Has anyone used Ponoko to do the laser cutting yet? What kind of a price?
Oct 17, 2010. 8:52 PMmg0930mg says:
To everyone complaining about not having a laser cutter. Ask around, your local high school or college may have one, and cut it for you. Also search for laser cutting business on google. You may be able to find one near you. Good luck.
Randofo, great instructable, I love how it looks.
Jun 27, 2011. 5:10 PMtheawesomeninja says:
Not many laser cutters where I'm from, surprising considering my proximity to silicone valley!
Jun 27, 2011. 5:52 PMmg0930mg says:
Then it looks like you should go to ponoko or some similar service.
Jan 31, 2011. 10:30 AMthepelton says:
I have one. I'm in Colorado Springs. My Email is donaldpelton@gmail.com
Jun 13, 2011. 1:16 PMBBurak says:
Really perfect. Good luck with your works.
Mar 7, 2011. 5:25 PMpingo6 says:
i dont think a laser cutter is under 10 bucks
Mar 12, 2011. 4:10 PMpingo6 says:
why would i? i dont really need one. plus you cant cut stuff too thick.
May 20, 2009. 6:59 PMultrauber says:
If you didn't have a laser cutter, you could just use gigantic drill bits, right?
Mar 12, 2011. 6:36 AMsethcim says:
You could probably use hole saws.
Jul 23, 2009. 12:15 PMItsTheHobbs says:
Yes, but be REALLY careful... Don't want it to crack...
May 14, 2009. 2:57 PMbig-jamie says:
i just have one question...where did you get a laser cutter and how much are they ? =)
May 15, 2009. 8:25 PMthetech101 says:
Check the epilog site linked above. Around 3,000+ dollars. And that's cheap for most lasers.
Aug 2, 2009. 2:51 PMAlyakpink says:
(removed by author or community request)
Oct 17, 2010. 8:54 PMmg0930mg says:
You can't spell...or read.
It said for most lasers.
Oct 27, 2010. 6:52 PMAlyakpink says:
ok well im sorry. all i said was: "ya, $3000, real cheap!" u ddnt need 2 comment on tht at all.
PS: i accidentally clicked remove above 4 the comment so ya thts y it says "removed by author or community request"
Oct 28, 2010. 12:35 PMmg0930mg says:
You didn't need to comment on this either, then why did you? That's a stupid point to bring up.
Aug 8, 2010. 5:12 PMj03tv says:
Please put "Using a laser cutter" in the title of your instructable. Most people dont have a laser cutter which makes this project far from affordable and nowhere near $10/
Sep 15, 2010. 6:10 AManres321 says:
I aggree :D
Aug 22, 2009. 4:18 PMTemplarix47 says:
Under $10? How bout the laser?
Mar 16, 2010. 12:22 AMx z i t says:
nobody has a laser cutter!
Aug 22, 2009. 8:17 PMTemplarix47 says:
Nope! That's just me but how bout everybody else who doesnt have those things? Just buy those just to make a laptop stand and then never use them again? But still cool instructable.
Dec 24, 2009. 3:11 PMstephenniall says:
Ive been looking at laptop stands and ive had the same problem as you there all ugly !
Im going to cut one like this but at the back im going to cut room for 4 usb ports (from a usb hub) a fan and a wireless card antenna Hopefully !
Now to bribe our schools Technology teacher to let me use the laser cutter , Shouldnt be too hard
Jan 17, 2010. 8:52 PMbowmaster says:
How to persuade a tech teacher.
Pick one:
A: $500 cash.
B: Give them the latest piece of Japanese tech.
C: Hit them with a $10 wrench.
Feb 4, 2010. 4:03 PMEnder Wiggin says:
 Sounds like C is the most effective (and cheapest) option!
Feb 4, 2010. 4:33 PMbowmaster says:
Actually, a is most likely to work, C is the least.
Sep 25, 2009. 10:04 AM323maderas says:
If you bent/folded in 3/4 inch or 1 inch at the bottom of the back of the stand, it wouldn't cut into your legs when you put it on your lap. Also would be very easy to velcro-mount a usb hub to the backside of that, keeping it handy without flopping around. Or a couple of small clips to run your wires (power cable, network cable, usb cables) together to one side. Just ideas...
Sep 14, 2009. 2:43 AMporcupinemamma says:
wondering the same thing as cmyk
Jun 4, 2009. 12:10 PMimmadoc says:
seriously, you could start an ebay store with this...
Jul 30, 2009. 9:57 AMki10 says:
Or Etsy. Great work. I would totally buy this, since I'd have to get the holes done anyway.
1-40 of 117next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1968
Author:randofo(Randy Sarafan loves you!)
I am the author of the book '62 Projects to Make with a Dead Computer' and Community Manager here at Instructables. I'm always sharing tons of awesome projects. Subscribing to me = fun and excitement!
