Laptop Cord Repair
75,265
22
23
Posted in TechnologyLaptops
Introduction: Laptop Cord Repair
Once again I came home to find my laptop power cord with teeth marks near the end and it crackling with electricity every time I moved it.  It seems that my mother's cat just loves to chew on this thing leaving me without a way to charge my laptop. This is the second time I've repaired it, so I figured I'd make an Instructable to help any other poor souls with a cord loving cat.
WARNING!  You are dealing with a power adapter which can cause fires if wires get crossed in the process.  Please use caution, make sure the cord is unplugged before starting, and don't blame me if it doesn't work.
Step 1: Cut Out the Badness
This whole process should only take about 10 minutes or so.  Begin with plugging in your soldering iron and unplugging the laptop power adapter.  Start looking at the cord and see if you can find the problem section, in my case it was pretty obvious (See picture).  Then take a pair of scissors or a cutting tool such as tin snips and cut out the problem section.  You will want to cut as close to the problem as you can so that you don't lose too much cord length.
Step 2: Begin Stripping
 So now you should have two cut pieces of your power cord.  Slide a piece of heat shrink tubing down onto one of the pieces of wire and move it out of the way for later on.  Take a wire stripping tool or a pair of scissors and begin peeling back the insulation from the wires.  Be very careful not to cut too deep as you'll have to cut the cord down again.  If this is your first time stripping wires I would even recommend practicing on a cheap extension cord you don't mind loosing.  As you get through each layer, twist the inner wires together in order to keep them all together.  In my case I had two outer layers and then a center wire.
Step 3: Add Some Heat
So now you should have both sides stripped and the individual strands twisted together.  Take the center wire from both sides and twist them both together.  Then add a bit of solder with the now hot soldering iron (It should still be plugged in from step 1), and tape off the wires with electrical tape once it cools.  Make sure that the inner most wire is completely covered with electrical tape or it could short circuit and start a fire!  Do the same thing for each layer working your way up to the outer most layer.  I've found that alternating sides that you connect the wires up on helps to keep the cord looking a bit straighter.
Step 4: Finally!
Leave your last connection without any electrical tape on it to make sure everything works.  You may want to carefully test your adapter now in order to make sure that all the connections are secure.  Plug the adapter into a surge strip and keep your hand on the power switch to make sure you can kill power quickly.  If everything works, move the heat shrink tubing up over the connection and use your soldering iron or a hair dryer to shrink it up.  Keep moving the heat source so that the tubing doesn't melt apart. You have hopefully successfully repaired your laptop power cord for now.  Hopefully the cat won't eat it too many more times!
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    23 Comments
    is it possible to use plastic gun or super glue instead of soldering?
    I wouldn't recommend it, there's a great chance of arcing/short circuiting which could cause a fire if you're not careful to fully cover the exposed wires. Also, since hot glue and super glue could act as an insulator, your connection might not work and your laptop wouldn't charge.
    is there any other things that i can use instead of soldering
    You could use wire nuts (assuming you can find some small enough), but it would not look anywhere as nice as this.
    Another drawback to wire nuts is that they would not hold up anywhere near as well as solder and shrink wrap.
    Nothing I would recommend. A soldering iron is only ~$10-20, solder is ~$5, knowing how to solder is priceless! If you don't want to learn because you're scared you'll mess something up then practice on something else first.
    Thanks for sharing! I fixed up my girlfriends power cord after her evil cat chomped almost half of it. I didn't added any solding but I twisted it a lot and used electrical tape pretty tight so I think it will be able to work until I can get other one!
    Glad im not the only person who's cats wreak havoc on cords.
    No, not really...it would fall apart too fast. Sorry!
    Thanks for the help save me some $ they wanted $45 for a new cord
    hi im trying to cut the original cord and put a replacement charger wire to it... but im in a fix because cutting open the replacement wire i found out that the wires are different... they are blue red and black..... don't know which goes where... can anyone help wit that...
    If you still have the original charger, use a multimeter to find out what voltages are coming from the wires. Black will most likely be negative and the other two will most likely be positive voltages of different levels. After you know what the voltages are, go to the new charger and find out which voltages come from each wire. Then match up the wires that are the same voltages.
    help =) so what do we have to do with the outer gray wire,i mean the ones that are left after putting tape to the center one. Do we have to twist all of the four ends (like the pic above,like the four gray thingys hanging)?or we have to twist them by pairs?or does it matter??xD thanks!..BTW you are a genious!
    well i figure it out myself!and the SOLUTION IS,,,YES!you have to take all both pairs of cables and twist them up!and walla!!!you are done!wohooo!!i save about 40 bucks!! :P
    Excellent! Sorry I couldn't reply and help you out faster, but I was away from my computer for a little while. I think I just replied to you in my inbox as well... Oh well, glad you got it fixed and saved some money!
    hahah yeaup!!thanks man!!u are a genious!
    Thanks for helping me "dive in" to my repair. My break was RIGHT at the join of the cord and the three-prong head into the power adapter. Messy, and ugly, but now it works! Yaaayyyyyyy!
