3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laptop Power Socket Repair
Step 2Making the cuts
Making the cuts
I've marked on this laptop where you'll make the cuts. Using the razor saw cut at a shallow angle on either side of the power socket, then continue the cut onto the bottom of the laptop, cut there at a shallow angle. The cuts should be about 1-1.5 inches long and just through the plastic body.
Now cut back and forth between the cuts at the transition point to produce two separate tabs.
1 comment
Jan 11, 2008. 9:06 PMtresho says:
I don't have a saw like this in my toolkit, but I do have a small "rotary tool" such as Harbor Freight sells for about $8. These tools are also called "Dremel tools." Its cutoff wheel will do the same job. The diameter of the cutting wheel is about 1 inch. The tool here is shown cutting off a defective DC power jack from a printed circuit board.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
