loading
Step 3: Creating the Application
Once you've finished editing the python script save it and then close xcode. On your desktop, right click or control click the script (ScreenshotTaker.py) and under "Open With >" choose "Build Applet". An app called ScreenshotTaker should appear in the next couple of seconds on your desktop. This is the final app that we're going to have launch at startup.
Only thing that would make this better is if it uploaded an image from a webcam as well<br />
Do you know if there is any way to do this on windows. I already have and ftp server but dont know how to do the equivalent of the python script on windows<br />
&nbsp;Hey scytheon-<br /> There is a way to do it on a windows, but it's slightly more complicated. Python does work on windows, you just have to install it first (I'm not sure if it comes pre-installed). Anyway, once you've installed it, the script should work fine, but it's harder to get it to run automatically in the background. You could look into cron and automated task scheduling - I tried to do it with the osx equivalent but my computer was not cooperating. Let me know how it turns out
ill try it out and thanks for getting back to me so quickly<br />
&nbsp;No problem. One more thing, though - in the script, I use the os module (os.system, specifically) to run a command as if I was running it from the terminal, basically. But the screenshot command I used does not exist on windows. Apparently, there is no standard screen capture command in the windows terminal, but you might try installing&nbsp;<a href="http://www.mailsend-online.com/ScreenKapReadMe.htm" rel="nofollow">ScreenKap</a>&nbsp;and seeing if that works. Also, you'll have to change the path to the screenshots - I'm not sure what it is on windows. I hope this helps - if you get it working please let me know!
About This Instructable
1,711views
11favorites
License:
More by thedownsmeister:Laptop Recovery Cassette Tape Wallet / Money Clip
Add instructable to:
