3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laptop Screen Replacement HP DV6000 series
There are plenty of laptop screen replacement instructables here, but I did not find one specific to the HP DV6000 series. It's possibly overkill, but if this helps one user, it's worth it. I was quite surprised to discover how easily it was accomplished and with very few tools.
It might be a good idea to remove the battery and press the power button to discharge any stored power from the system. There's little risk of electrostatic damage in this repair, but if you're prone to generating sparks in your environment, take suitable precautions.
Since the removed screws are quite small, consider to have a piece of stiff paper stock or light cardboard stock nearby, to serve as a keeper. The advantage of paper or cardstock is that you can pop tiny holes into the cardboard in the same placement as the original screw locations, to make it all the easier to put it back together without missing anything. I also write notes on the card, if there's a possibility of error.
This replacement turned out to be easier than replacing a mainboard in a laptop, so the notes aspect wasn't really necessary. If you are interrupted in the replacement process and can't return for an extended period, the notes and card stock would be more useful.
Step 1Screwy
Screwy
Remove the screws holding the plastic frame (bezel) together.
Begin by prying off with a small screwdriver or similar tool the rubber bumpers that also serve as cosmetic screw covers. Place each screw in the appropriate relative location in the cardboard organizer. The last image showing the button removed and the screw head is out of focus because the camera is having a very difficult time with the reflective surfaces.
7 comments
Mar 3, 2011. 12:08 PMnc_tz says:
Hi thanks for the advice here. I had cracked my screen on my hp laptop and was at a loss, I called hp and they wanted 395.00 (are they totally off their rockers?) anyways , I took your advice and got a laptop screen replacement from http://www.laptopmart.ca and they installed for almost half the price with 3 years warranty. So my advice to anyone out there - it will save you money at this repair shop. Thanks once again , you saved the day.
Jun 22, 2010. 4:53 PMdogofwar says:
how much would it cost to replace a screen like that and where do you buy them this was one cool way to fix a problem that I am sure I will face in the future lol I hope not
Jun 22, 2010. 9:16 PMdogofwar says:
ya it will be a daunting task but I shall try I shall try.if I need help I know where to turn to and thanks
Jun 24, 2009. 1:51 PMdrew4824 says:
Did this model include a web cam or mic? Reason I ask is because I have to replace one with those and wondered what effect that may have.
May 1, 2009. 3:14 PMsirgregory1st says:
Thanks, great help!, great ideas too about the screw holder
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fred_dot_u
