I decided to build my own, needless to say, for much cheaper.
What you will need (and probably have lying around):
- old desktop DVD player or something similar with a metal housing that fits under your laptop
- smaller CPU fan
- some usb cable (can be anything, we only need the plug)
- electrical tape, glue, solder
Tools:
- small metal saw (or dremel if you are into that kind of thing)
- soldering iron
- knife, screwdriver
Remove these ads by
Signing UpStep 1Remove the guts
A cooler from a dreamcast, well that would look funky, please post a picture if you do it :)
choice of location for the fan is everything, for a laptop cooler.
looks like you choose the hard-drive cooling location.
good choice,
usb is DESIGNED for 5 volt under load.
in actuality, poorly regulated usb ports can pump out 7 volts or more, under dead short.
the other half of why it works is, the 12v fan can start on lower voltages, and run on even lower voltages.
In my testing, MOST smaller 12V fans can start on around 5 volt, and run down to around 3.
The higher power fans, like case fans that "ratchet" when you spin them by hand, tend to need higher starting voltages. usually, 7 is a minimum, and 5 is the low end running voltage. anything less, and you tend to get stalling.
Well yes actually the TJ65 blows out air at the back, and has two grills for sucking air in on the bottom, so I put the fan to the further one with face up so it blows air in.
As for the fans yes, absolutely true...
For me it was either this or two chipset/graphics card fans in parallel (those run on 5V). I chose this one because it has more than the average blades and makes a decent airflow, plus I only needed one :).
