Laptop Cooling Pad
Published
Introduction: Laptop Cooling Pad
Maker name : Shivaraju. R
I lived in a rural area outside of Bangalore,which is called Banjarapaly village.
where I see my friend´s are using Laptops more then 6 To 7 hours daily. But all of friends laptop getting very heat, after that they are going to shut down the laptop for few hours for cooling purpose. And they are loss mere then 2 to 3 hour daily. Hence, I made this Laptop cooling pad it is cooling very quickly, and its very cheep. I spend just $1.5 only.
Step 1: Materials Requirement
Materials :
  1. DC motor 2 or 3
  2. Wire
  3. Cardboard box
  4. Turbines 2 or 3
  5. LED
  6. Straw
  7. Switches 2
  8. 5v charger
  9. Connector
Tools :
  1. knife
  2. hot glue
  3. soldering gun
  4. marker
Step 2: Take All Components
Take dc motor and wire make sure you should solder each them as shown in the image. After that fix the turbines,and place the left end side of the cardboard box with the help of hot glue gun.
Step 3: Fix the LED
Take one LED make a solder and put inside the straw, after that take your laptop measurement how much space it required then fix the straw on cardboard box .
Step 4: Make a Connection
Take a connector to connect the motor and led +ve wires on switch and -ve wire is to connect to the connector finely take +ve wire to connect the connector. After that connect the 5v dc charger as shown in the image.
Step 5: Finell Step of the Project ...!
Make a small hols on the cardboard box. after that your LAPTOP COOLING PAD is ready to use.
Step 6:
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
