3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laptop look dead? Try to change the BIOS battery
  • last photo ←
Hello
A friend gave me an laptop that the motherboard was dead.
This friend contacted HP,they wanted 400$ for reparation
Just repair it in 5 minutes
Step 1Tools needed
Tools needed
- One philips screwdriver
- One dead computer
- VERY IMPORTANT: One 2032 3V battery
- Optional: Multimeter
27 comments
Mar 21, 2011. 5:45 PMbuddy03 says:
I have an old HP xh485 and there is no sign of a CMOS battery, even after opening the top and removing HD and KYBD. Help me find that little guy!
Mar 22, 2011. 7:56 AMbuddy03 says:
I don't have a manual.
Mar 12, 2009. 9:59 AMgmjhowe says:
Good and simple, i suggest changing your title to 'swapping out a motherboard battery', or something along those lines. It would seem that the laptop is running mac os x?
Mar 12, 2009. 10:19 AMJoe Martin says:
No, thats xp! I highly doubt that the CMOS battery would stop the computer from booting. The CMOS battery powers the internal clock of the computer and that alone would not cause a complete breakdown, Maybe some errors due to the time being incorrect but NOT broken.
Jan 4, 2011. 9:09 AMDaniel Deacon says:
It does stop it its happend to me
Mar 12, 2009. 5:23 PMaloneonafriday says:
Actually I have seen a bad battery stop a laptop and desktop from booting properly
Apr 15, 2010. 6:55 PMhody1953 says:
I was just going to say it is one of the troubleshooting questions on the A+ computer certification exam. The CMOS is required or the computer cannot boot, the battery does not just power the clock, however, without a clock the computer cannot run either.  The start up settings are stored in EPROM, which is maintained by that same battery. The computer needs those setting to boot also.
Mar 12, 2009. 6:25 PMNachoMahma says:
. I've only run into one computer that wouldn't boot with a dead battery and that was ~15 years ago; but I don't see many computers with dead batteries. I think that happens when the HDD params get erased or scrambled (I could boot the computer if I set the drive params after the POST). Most, if not all, recent BIOSes will auto-detect the drive params, so it's not usually a problem nowadays.
Mar 12, 2009. 11:04 AMgmjhowe says:
ah yes, i thort it was a hackintosh, but on closer inspection i see the windows quick launch.
May 27, 2010. 10:26 AMCombine Clite says:
Hi,i have exsacly the same computer as u..
its dead to
*thx for making this tut
Mar 22, 2010. 10:57 PMzack247 says:
will a general CR2032 work? or does it have to be specific? they are both 3 volts...
Mar 23, 2010. 3:28 PMzack247 says:
i checked the battery on my multimeter, (on 6v, it doesn't hav a 3v option) and it tested out just fine (the needle was at the halfway mark) should i replace it anyways? or is there something else wrong with my laptop?
Jan 21, 2010. 8:21 AMdrewwwski says:
Could you desribe the symptoms prior to changing the battery? I've got a Compaq laptop of the same form factor that won't boot into Windows. I had also suspected a bad mobo so thanks for this suggestion, I'll give it a try...
Mar 22, 2010. 10:56 PMzack247 says:
is it a presario v4000 by any chance? i have one, and i am going to try this. i can at least get it to boot up, i can ten get all of the other parts.
Mar 23, 2010. 3:04 PMzack247 says:
mine looks just like yours, the battery is different though, it has wires coming off of it onto the mobo. hopefully (since compaq and hp are one and the same) this will work. i have wanted a laptop for as long as i can remember. wish me luck!
Apr 28, 2009. 5:34 PMPatented says:
Yo, je presume que tu parles francais pcq ton bios est en francais.. mais merci beaucoup je vais essayer sa jai un vieux laptop IMB pi le probleme c le motherboard donc je vais essayer de changer la batterie! merci
Jul 16, 2009. 7:40 AMPatented says:
Ouais ben je lai changé mais non sa a rien changé malheureusement... Merci quand meme pour lidée!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tututu
