Large Bread Board from IDE Cables, breadboard on the cheap
This was inspired by the original ide bread board by stone3408ide bread board by stone3408 I thought it was such a simple idea to recycle the mass of old ribbon connectors I had laying about.
Sorry in advance about the image quality, I must get a proper camera & stop using the phone
What you will need
3 IDE hard drive cables depending on the number IDC of connectors (SCSI or FDD cables could be used for a different sized board)
This uses 8 IDC connectors.
A small flat screwdriver to take the connector apart
A vice or something to apply pressure when re assembling.
Step 1Disassemble the IDC connectors
Use the flat screwdriver to ease off the cable grip, conductor cover & lift the wires slightly from the cable.
Pull the ribbon cable off by folding it back; this helps to keep the pins in place.
14 comments
Jul 30, 2011. 6:04 AMKevinAlien26 says:
I just finished one using 4 of the connectors. Great Ible it's surprise what a bit of innovation and creativity can do
Feb 6, 2010. 9:04 AMRayzor910 says:
 Great idea.  Question - Can you expand on the 'Squeez Together' part as I am a little confused.
Also, drinking coffee while trying to put the wire in each pin is not a good idea.  Serious coffee jitters....
Jul 30, 2011. 6:03 AMKevinAlien26 says:
I think by squeeze together he means to try to keep them close together so there is little to no gap between them. Not necessary but does make it look a bit nicer.
Dec 12, 2010. 9:52 PMratgod says:
I just published a similar instructable, but mine requires you to solder wires onto the spikes at the bottom to configure your connections.
I didn't see this instructable until I had published and saw the "related" list on the side.
Yours is an excellent instructable, I've never thought of doing it like that.
I put a link to this page on my instructable to inform people of the alternate way of doing it from mine.
Peter
May 11, 2010. 6:51 AMstone3408 says:
I like the idea of jumping the pins with the left over ribbon wire.  Great for when your in a bind.
Apr 27, 2010. 4:42 PMbalno says:
A very useful instructable ! Many thanks for sharing. Squeezing metal grips is not easy... For my next project I guess I'll strip a small portion of the ribbon and wrap the cables two by two before soldering them rather than using this method. Anyway, a very nice work and a great idea.
Jan 22, 2010. 6:56 PMb2gills says:
Just pull out half of the connector pins, and put them in the other way around, to connect the even numbered pins to the odd numbered pins.
Jun 19, 2009. 9:08 AMjuggler4real says:
WHERE CAN I GET IDE CABLES FROM
Apr 9, 2009. 1:37 PMjohnfromnj says:
Good move ! Bigger is always better, size does matter !
Mar 6, 2009. 11:44 AMDerin says:
XD EXPENSIVE CARDBOARD BOX Sorry,I just had to do that.
Feb 22, 2009. 3:03 PMobj126 says:
u should have negative on 1 side and positive on the other
Feb 21, 2009. 2:07 AMtrialex says:
This is actually a really clever idea. Not the most practical in all situations, but excellent reuse of materials.
Nov 6, 2008. 2:53 PMbaneat says:
Damn I thought you mean a geeky toast rack XD
Oct 24, 2008. 8:13 AMkillerjackalope says:
To make the power rails easier a piece of magnet wire with coating removed or something else like a small metal rod would allow you to solder all the pins together without fiddling with jumper wires. Nice job overall, I always wondered if this could work after seeing someone I know do the opposite.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:guinness0001
