3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Large Jacob's Ladder
Large Jacob\
High voltage plasma arc!
Thanks to ewilhelm for the original instructable and Prometheus for the tips. This is my version of the Five foot tall jacob's ladder. I changed/replaced some of the parts for better insulation and ease of building.
Step 1Parts
Parts
The main component of a jacob's ladder is some source of high voltage. For this you need to find a neon sign transformer (NST) that has a 8 - 15 kV 30mA output. I got a Franceformer 15 kv 30 mA NST on eBay for $50.
Other things you will need:
  • 2" ABS pipe (30")
  • 2" ABS female T-joint (x2)
  • 2" ABS male adapter (x2)
  • 14 gauge copper wire
  • .5" acrylic rod (x4 in 6" lengths)
  • can of expansion foam
  • hot glue
  • small rubber bands (x2)
34 comments
Sep 26, 2011. 6:06 PMTimmyMiller says:
i want to add a tube over it to give it a little more mad scientist look to it,
any suggestions?
Sep 26, 2011. 5:44 PMTimmyMiller says:
i found one i like at partsforsigns.com
they have a lot of brands there so it might prove useful to go there
sincerely
timmymiller
p.s. BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
Jul 13, 2010. 11:54 AMthatinventor1 says:
would spreading the leads apart make the arc move up faster?
May 15, 2009. 9:14 AMinkjacket says:
LOL this is hilarious.
THIS IS INSANE! so awesome and so beyond my comprehension lol. may one day get up the guts to try my hand with voltage i'll most likely kill myself with HAha. Hot stuff- love it:)
Aug 13, 2008. 1:46 AMneardood says:
lol like the photo
Aug 6, 2008. 1:29 AMthermoelectric says:
Can I use a flyback transformer out of a 15" colour crt monitor with a appropiate driver as the power supply?
Aug 6, 2008. 2:30 PMthermoelectric says:
Your franceformer is $99 when i looked today here's the link
May 16, 2008. 4:59 AMtech-king says:
nice. though in the video, the arc seems to snuff prematurely a lot. also, near the top, the arc seems to wobble; one side rises, then the other side rises past the first side and stops, then the first side rises again. i beleive this problem can easily be solved with a higher amperage transformer.
Jul 28, 2008. 7:12 PMduckythescientist says:
And you can put the copper in a clear tube or in a closed room with no ac/fans to keep drafts down. Drafts kill more arcs than arcs kill humans.
Jul 1, 2008. 12:57 PMrealcelestialphoenix says:
(removed by author or community request)
Jul 7, 2008. 10:30 PMRadioactive_Legos says:
Probably something like this:
<http://youtube.com/watch?v=4RCI8D8avGI>
May 28, 2008. 9:43 PMEnigmaMax says:
do you think if you got the arc moving fast enough and you placed something like a metal bb in the arc, the arc will act like a electro-magnet and launch the bb? in short, a jacob's ladder gun?
Jun 12, 2008. 12:54 PMGoedjn says:
No. What's happening here is that, down at the base of the ladder, where the two rails are closest together, the voltage gets high enough to jump from one rail to the other. When this happens, ionizes the air along that path. The ionized air is light (partly because it's hot, and starts rising, but since ionized air is a better conductor, the arc follows it up. When it runs off the top, the arc eventually gets long enough so that the short air gap at the bottom is again the path of least resistance. You should be able to trap the arc and collect the ozone by sticking a glass jar over the top of the ladder. --Goedjn
May 29, 2008. 11:32 AMEnigmaMax says:
well, yeah, but still, it could work.
Jun 12, 2008. 12:49 PMccolasont says:
NICE!!!
May 24, 2008. 2:04 PMskimboarder33 says:
Is there a way to have more than one arc going at once? you may be able to make it do tricks by positioning plastic on only one side about halfway up so that it will leap back and fourth?
May 17, 2008. 4:45 PMGorillazMiko says:
Aw, man, sweet! When I was at the Instructables' previous HQ in Alameda (the old naval base), Eric showed me this. He has 2 or 3 of them, but they're awesome. I kind of wanted to make them, but now, wow, awesome Instructable, I feel like doing this now. :P +5/5 stars.
May 16, 2008. 5:02 AMtech-king says:
heres another interesting idea: turn off the arc, saturate water with salt, dampen a rag with the mix, rub it on the ladder, let it dry and try the ladder. if it works, the arc should change color.
May 17, 2008. 4:08 PMBran says:
Flames are blue/green colors due to burning copper sulfate and copper chloride.
May 16, 2008. 2:28 PMtech-king says:
oxidation. as the deposits burn off, some give off color.
May 16, 2008. 12:36 PMNorwat says:
How many watts ?
May 16, 2008. 5:52 AMewilhelm says:
Nice work! I like your adjustable gap built with acrylic rods.
May 15, 2008. 5:29 PMmspark400 says:
pretty sweet and nice job i like the improvements in the name of ease its on my to do list +1
May 15, 2008. 5:30 PMmspark400 says:
sorry i meant five stars not plus one ...whatever it is now lol
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Zorink
