Step 8Final Tips
Try raiding any construction site for any neon signs you can find, or try dialing up some demolition companies to see if they have any jobs going for places that might have such neon signs such as bars, supermarkets, or just about any commercial property you can imagine that might have any permanent neon-sign fixture (bars are a sure-fire hit)...Fluorescent fixtures are not worth anything to you for this purpose, so don't even try to seek them out. A parallel-series hookup will just blow them all out as they are only "hi-pot"-ed to 5kV...Neon is the only way to go...
The more archaic the transformer, the better, oddly enough...Older ones were more "overbuilt" for durability with the low-tech methods of the day....Just make sure it works before you invest too much in it though...
You can also try E-Bay, a hobby/salvage shop, or even craigslist.com...In desperation, you can use the transformers for the portable "OPEN" signs when the glass has been broken, don't feel above going that far....I got lucky with my latest haul of three identical heavy-duty neon-sign transformers from a previous demolition nearby....patience might give you the same fortune as well eventually...keep your eyes open...
Assuming you find two or more, never attempt to hook-up the secondary outputs in series with the primary inputs in parallel in an attempt to double the voltage, or you may fry both of them. Don't parallel them either, even if they seem to be identical, as some may have a different impedance than another in the line, and the one with the lesser impedance will work alot harder and possibly fail, and cause the other to fail as well...
If you get really lucky, you might find a 60kV transformer for really large neon signs that still works, and that is a major score.
When making a Jacob's Ladder, *always* start with too-large a gap and narrow it little-by-little....30kVDC jumps about one inch in dry air...AC jumps a little less...Too short a gap and the transformer overheats....run a 'Ladder too long and it overheats...I suggest no more than 5 minutes at a time, with a 20+ minute cool-down afterwards....
If using coat-hangar wire for your electrodes, scrape a line through the coating on the inside (where the spark will travel) for optimal spark performance. Brace wires at the top as the magnetism generated will alter the spark-gap as the spark climbs, resulting in a risky wobble in the electrodes....try folding a drinking straw at the top to brace them and keep them safely separated (DO NOT USE CARDBOARD OR ANY OTHER WOOD-PRODUCT, NON-SILVERIZED/METALLIZED-PLASTICS ONLY!).
Good luck, you will find a neon transformer soon,. just keep your eyes open....and remember, these can kill you, so respect their power as a potential human-cooking-device....
Double....*triple*-check that it is unplugged before you even get near any electrode. Wrapping a miniature neon bulb on either electrode (can be shorted, it'll glow if live and does not need current *through* it to light; just tie it on to either HV electrode to stay put ACROSS THE TERMINALS). Alternately, you can use a miniature fluorescent tube as well (it'll light up if live, will REALLY light up if you touch it when live without delivering a dangerous shock when charged under 30kV....just touch it and you'll see)...
Be safe....check terminals for live with a "backhand" motion, so that if you get shocked, the stronger muscles will pull you away from it instead of making you grab it harder. Grab your wrist with the other hand to resist current going through your heart and causing cardiac-arrest...better through your feet than through your chest...
Good luck...I hope you can find the transformer you need and that you don't get hurt by it....Electricity is a harnessed form of nature....never underestimate it...
comments
Add Comment
Add Comment
