Large Light Up Flexagon
Introduction: Large Light Up Flexagon
And for it i wanted to Do something special. So, in this instructable I am taking the large flexagon up a level and making it illuminated. Originally I had hoped to enter this into the make it glow competition but it had a few set backs. these have been ironed out now and I know self praise is no praise but i am pretty happy with the finial product.
Its a pretty straight forward instructable, relatively cheap and, in my opinion, looks pretty damn good
Lets get started...
Step 1: What You'll Need
2 sheets of A2 frosted acetate
Coloured cellophane. I'm using 3 colours and keeping one plane but you can do more. or less :)
Double sided tape
Duct tape
1 set of plain colour LED battery operated fairy lights
Craft knife
Cutting mat
Glue dots (not pictured)
Step 2: Template
Measure out the dimensions of you battery pack and adjust the template so that it fits in the rectangle
Print it out or trace it off screen and cut it out
Step 3: Mark It Out and Cut It Out
Lay your acetate out in landscape and mark off your triangles in 3 lengths of six and one of seven
Cut the lengths out.
Step 4: Stick It Down. Cut It Out.
One on of the lengths with six in it stick double sided tape along each edge and then on both sides of each triangles "diagonals"
Peel of the backing, lay out your cellophane and lay your length of triangles on it.
Using the craft knife trim off the excess cellophane.
Cut out the triangles.
Repeat with your other colours
Step 5: The Extra Triangle
Take the extra triangle from the row of seven and cut a triangle out of the center
you want it to be big enough to allow you access to the battery pack.
Step 6: Layin' Them Out. Taping Them Up.
IMPORTANT NOTE! If you have a cat you may want to put them out of the room as chances are as soon as you have all the parts laid out it will decide to walk over them. mine did. Twice :\
At this point you need to decide what part of your flexagon you want outside. I opted for keeping the frosted side to the outside as i wanted a softer glow.
What ever side you want to the outside lay facing upwards as shown in the picture above trying to keep a couple of millimeters between each triangle.
Note that i kept the triangle with the "door" in it to the one end.
Place duct over the edges of the triangles, half and half on each edge.
Trim off any over hanging bits of tape
Step 7: Lightin' It Up.
Flip over your assembled shape.
Place the battery pack at the end with the door and lay the lights out making sure there are a couple in with the battery pack. This string was long enough to double back on itself.
Use a glue dot to hold the lights in place at each end
Step 8: The Fiddly Bit.
Starting at one end pull in the edges so it forms a "pyramid" and use a small bit of tape to hold them in place.
Using a longer length of tape cover the entire edge.
Its a lot easier this way than trying to tape the whole edge at once.
Continue down the line until its like the shape in the picture above.
Step 9: Making a Door
Take your last triangle and fold tape over the shorter edge and one of the long edges.
On the other long edge place some tape but dont fold it over.
Used this tape to stick it to the rest of the flexagon like a hinge
Use a smaller bit of tape to hold the door shut and act like a latch
Step 10: Bringing Together
Bring both ends round to meet each other and tape them together on both sides of the joint
Be sure that the tape doesn't interfere with your door.
Step 11: Finished
And your done!
Not much else to say except that I really enjoyed the outcome of this and thing that it looks quite contemporary as well as soothing to play with.
I hope you enjoyed this instructable as much as i did and as always thoughts/comments/criticisms and even pictures of your own Light up flexagons are welcome in the comments below :)
    • Epilog Challenge 9
      Epilog Challenge 9
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    looking very nice
    Very nicely done, and nice color choices too! I had this drawn out in my sketch book too. :)
    Thanks. I would love to do one on an even larger scale but alas i dont have the space currently to build/store it
