3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Large Photography soft box on the cheap
Here is a oldie but goodie from my podcast MechanicalMashup. You can view the video below on the build...
 I was in need of a couple of large soft box lighting systems for my podcast MechanicalMashup. Now going out and seeing how much these cost caused me a nearly catastrophic tube failure in the brain. I knew that I could build these for around 50 dollars a piece with stuff from the hardware store saving me thousands of dollars, yes thousands!
Tools:
-Hand saw
-PVC cutter (If you dont have one of these see the item above? It will do)
-Utility knife
-Drill or screwdriver
Raw Materials:
-4'x4' black coroplast (From HomeDepot)
-Aluminium tape (In the heating section of HomeDepot)
-6 3/4" PVC 'T's
-8 3/4" PVC caps
-2 8' lengths of 3/4" PVC
-2 1" PVC 'T's
-2 1" to 3/4" reducer
Note sometimes you can find a PVC 'T' that is 1" and 3/4" combined so you can forgo the reducer
-2 6 plug power bars
-6 Plug in light sockets (You can get these in the electrical section at HomeDepot)
-1 3 to 1 plug socket
-2 coat hangers
-3 DuckTape (what would a ible be without the handy mans tape?)
-1/4 or 3/8 plywood 12"x3'
-Screws 3/4 to 1 inch long and #6 size
-PVC hangers
-CFL lamps (all spectrum 23 watt preferably)
The 3D CAD model for this in the free CAD package Sketchup is here:
Sketchup
Files for the 3D model
Oh and here is a pop out reflector and or chroma key you can use in conjunction with this LINK
AHHH HA! so to play the movie on my computer you have to click on the movie and then hit the space bar. No idea as to why you cannot just hit play. So for those not able to view the video try that first.
Step 1Reflector
Reflector
The reflector is just the coroplast, and aluminium tape.
-First cut out the coroplast (in this case 3'x2') so that the flutes or the tubes run along the 3' lenght (This is very important)
-Now using the aluminium tape cover one side of the coroplast
7 comments
Jan 6, 2012. 7:16 AMArkusM says:
Awesome.
Have you tried spray gluing Alum foil as opposed to using tin-tape, as tintape is pricey? should get the same results...
Great job though added to my to-build list....
Apr 8, 2010. 1:02 PMSnoopy101x says:
Sadly I could not find any coroplast at any local hardware store :(.  So I settled on 1/4'' ply, making appropriate cuts, and using door hinges :).
Jan 15, 2010. 10:40 AMnathangill says:
Works fine for me. Thanks for the Instructable.
Definitely grabbing the supplies for a couple of them on payday.
Jan 14, 2010. 10:49 PMmikeasaurus says:
looks fun, you should include a picture of your finished product and some comparison lighting shots.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:MechanicalMashup(MechanicalMashup)
