Large Upright Dustpan Aids Lawn Cleanup
Introduction: Large Upright Dustpan Aids Lawn Cleanup
I am not as bendy as I used to be, and this pan allows me to pick up gravel from my lawn while I remain standing upright. I wanted a large bin that could catch gravel as I flick it from the grass using a garden hoe, not because I need to collect a large volume of material, so I made one. Every time I shovel snow from my driveway, some gravel goes with it, so this is a recurring winter chore. Circle of life.
To see my related Instructables, click on "unclesam" just below the title above or in the INFO box to the right. On the new page that appears, repeatedly click "NEXT" to see all of them.
Step 1: Components and Tools
1 Tall plastic kitchen trash bin, typically 24 inches tall, rescued from roadside
pvc plastic or plywood, 1/2 inch thick, for making four disks, four inches in diameter (four square pieces will work as well as disks, but will not look as elegant)
1 handle formed from metal electrical tubing, one half inch diameter, length determined by user's preference; mine reaches 24 inches high when the bin is in its horizontal position.
12 #6 drywall screws, one inch long
2 screws 1/4-20, 2 1/4 inches long, for attaching handle
4 flat washers, 1/4 inch hole
2 1/4-20 nuts having nylon locking insert
2 5/16-18 hex head bolts, 1 1/2 inches long, for handle stops
electric drill, bits and countersink
tin snips for cutting plastic bin
jig saw; or band saw; or hole saw; or rotary hobby tool having router base and spiral cutting bit, for cutting plastic or wood disks
adjustable wrench, small
screwdrivers: phillips and straight blade
5/16-18 starting tap and tap handle
tubing bender for shaping handle
Step 2: Cut That Out
I marked one wide side of the bin for cutting at 20 inches from its bottom, the other at 10 inches. I connected these with diagonals along the narrow sides, rounded all the corners, cut with tin snips.
Step 3: Going in Circles
I cut out pvc plastic reinforcing disks using Dremel tool. Its router base has a 2 inch radius, and the spiral cutter is small. I drove a nail into the center mark of each disk and just rotated the tool around the nail. Next I used a roundover bit in the Dremel to trim one edge of each disk. I marked one disk for six drywall screw locations, then drilled a quarter inch diameter hole through the center of each disk. I stacked the disks facing the ways they would be attached to the bin and clamped them with their center holes aligned, made a match mark across the stack to define "up." I drilled the six holes with bit suitable as pilot for the drywall screw threads and unclamped the stack. I enlarged the six holes in the two disks that would be on the outsides of the bin with a bit to clear the screw threads and countersank those holes.
Step 4: Assembly
Each of the outer disks is clamped to the the bin, with their match marks "up," as a guide for drilling holes through the bin, then six screws attach each disk pair. The handle is drilled with a 1/4 inch hole 1 and 3/4 inches from each end and attached using long screws, washers and nylock nuts. A hole is drilled (undersize for 5/16-18 tap) into, but one quarter inch short of going through, each pair of disks in location suitable for a handle stop. The holes are tapped and a bolt screwed into each until it jams into the tapered bottom threads. Alternatively a hole could be drilled and tapped through each disk pair, a longer bolt screwed through and a nut tightened onto its end.
Step 5: In Use
The gravel ends up too far from the edge of my driveway for it to be pulled back using a lawn rake, so I must go retrieve it once the snow melts. I do not need to always pick up and carry my pan across the lawn, I can just push it around with the hoe then lift it only when I have collected enough gravel to dump back on the driveway. The big pan is also handy for cleanup tasks on the patio and in garage and shop.
U. S.
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    This is a great idea! Thank you for sharing it. I had back surgery not long ago and have been wondering how to make something like this. I live in a windy area and get alot of dead weeds and debris in my yard and this will com ein handy in more ways than one. I'll have to make one for my husband's shop or he'll be stealing mine to sweep sawdust into. :)
     Cool idea.  It reminds me of my grandma's pooper-scooper-picker-upper.  She had time bending down (all those years of gardening), but she was stubborn enough that she wouldn't let anyone else help her with her yard maintenance, including cleaning up after the dog.
    Bless her stubborn heart.  You gotta love a woman like that.
    This would probably work really well for cleaning up after my 3 large dogs... GREAT IDEA !
    I8nite, if you make one for that purpose, you are required, in accordance with Instructables Terms of Use, to label it in recognition of its sturdiness and durability thusly: HEAVY DOODY
    U. S.
    Nice design!  Think I'll have to make one for a poop scooper.
    knife141, if you make one for that purpose, you are required, in accordance with the Instructables Terms of Use, to label it in recognition of its sturdiness and durability thusly: HEAVY DOODY
    U. S.
    We make these out of empty metal balut cans.
    The handles are mostly wood stick attached to the bottom of the can that is cut pretty much the same way you cut your plastic can.
    I like your design better.
    I have a couple of these trash bins around the house. I guess one of them is getting moded soon!
    Thanks for your Ible!
