Large portable wood gasifier stove
 by KoffeeKommando
Featured
My YouTube channel HERE
*New* video of large gasifier operation HERE
Poor man's large gasifier Instructible
MIDGE small tin can gasifier Instructible
This is the documentation of my largest gasifier experiment so far.
This unit costs about $50 to make.
After building a MIDGE stove, I wanted to design something with bigger,better performance.
It also needed to be a design that could be copied easily. All parts must be commonly available. Tools should be kept to a minimum.
This gasifier can be built in two quality levels. The prototype is identical to this silver aluminum model but is made from a large popcorn can using no power tools.
The output of this stove is very high. A very rough estimate might be 30-40,000 BTU. Don't quote me on that though. It can boil 5 gallons of water in 30 minutes. I've also mounted it under a 30 gallon gas water heater. After an hour and a half of runtime the water inside reached 150 deg. F
The stove will run for 1 hour without "in flight refueling". Wood pellets are the preferred fuel but literally anything "woody" can be burned in the stove. This stove burns material from the top down.
If burning wood scraps like 2x4 and pallet chunks, pack the wood in tight and cover with a layer of wood pellets. The top layer of pellets will create the initial layer of coals you need for nice combustion.
Much more can be said about stove operation. I will document some of this as I go on. Once you build the stove and run a few times on wood pellets, the operation becomes more obvious. When operated correctly there should be NO SMOKE emitted.
There are somewhat dangerous fumes produced by this size stove so don't use it indoors. Treat this device like a literal "campfire in a can".
TLUD stoves such as this are very safe in operation for the most part. The top ring of the burn pot gets incredibly hot (230 deg. +) but the sides stay cool (100 deg. or so) for the rest of the burn.
My stove uses a regular common computer fan for air supply. A centrifugal blower style fan is preferred but an axial fan can be used successfully if you make a straight duct and attach to the outer pot. Blower fans can be found surplus or can also be found in some Dell tower computers.
Improvise and adapt!
Now on to the plans........
Step 1: Gather tools and parts
Tools needed:
- Dremel tool with fiberglass cutoff wheel
- Corded or cordless drill
- DeWalt 1/8 or 9/64th titanium drill bit
Components needed:
- 12 quart aluminum stock pot (buy quality restaurant grade with thick lid)
- 4 quart stainless steam table pot with "inset" top (Libertyware IP04 or Vollrath?)
- 6 quart stainless steam table pot bain marie(Libertyware BM06 or Vollrath ?)
- 12 sheet metal screws (pref. stainless)
Libertyware website w/part numbers:
http://www.libertywareusa.com/products/i/ip04.aspx
http://www.libertywareusa.com/products/b/bm06.aspx
Optional (if you can't cut the main hole perfect):
- wood stove cement
- high temperature RTV sealant
- Thermo Steel high heat putty
Optional tools for cutting main holes:
- Makita die grinder GD0601
http://www.toolbarn.com/makita-gd0601.html?ref=base
- Clesco M-3 wheel mandrel set (Holder for 3" stainless cutting discs. Can be used with Makita or  corded drill)
http://www.drillspot.com/products/62526/Clesco_M-3_Screw_Type_Cut_Off_Wheel_Mandrel
- 3" fiberglass cut off wheels (Any brand with these specs will do. 3/8" center hole preferred)
http://www.lehighvalleyabrasives.com/servlet/the-99/3%22-X-1-fdsh-16%22thk.-X/Detail
These pots should be bought from a real restaurant supply store (or come from a restaurant).
I used Libertyware (Indian made), but Vollrath (USA) should work also. The Vollrath "inset" 4  quart is shaped differently I believe. Test fit before buying.
The burn pots are stainless, this is the only durable way to go. Use DeWalt or equivalent drill bit that is capable of drilling stainless. The point angle of the drill bit really matters. A Rigid brand cryo cobalt bit did NOTHING. It literally melted trying to drill the thin stainless. DeWalt titanium went through like drilling butter. It was a night and day difference. Will give part number of drill bit later. It's common at any Home Depot.
thexmark says: Sep 15, 2010. 9:10 AM
Thanks for the instructable. I plan on having a go at this in the next couple weeks. I have the stock pot with lid and am ordering the other SS pots. Could you shed some light on how exactly to cut the hold in the lid for the 6inch pot? What is the best method to start the cut and then to actually make the round cut? What tool(s)?
KoffeeKommando (author) in reply to thexmarkSep 15, 2010. 11:44 AM
Ok, first you need to use something to draw the hole. The hole needs to be the exact diameter of the 6 quart pot sides. Not the lip on top of course.
You can measure the bottom of the pot diameter, then use a circle drawing tool to mark the hole.
I had an MSR 4 quart (I think) stainless camping cook pot. It happened to be the exact size. You see this in the first pic. I just set it on top and traced around it.
Next step is cutting the hole. I used a dremel with reinforced fiberglass cutoff wheel. Pic 2 of this step. Dremel and fiberglass cutting wheels are available at Wal Mart/Home Depot etc.
You hold the dremel just like in pic 2, then let the spinning wheel "sink" into the lid. Move the dremel in a circular path along your marked line (hold with both hands very steady). Think of it like a "can opener" action with you moving, not the can.
Of course make sure the pot/lid is held down to the workbench securely. I did mine freehand but you have to have some skill with a dremel. And wear eye/face protection. The fiberglass wheels disintegrate easily while cutting. Stainless metal shards will also fly everywhere. Don't breathe any of the dust in.
Hope this helps clarify!
thexmark in reply to KoffeeKommandoSep 15, 2010. 12:26 PM
KK
Thanks for the detailed reply. I have a clear idea of what to do now.
One quick note, you mention stainless metal shards but the stock pot you and I are using is actually aluminum, correct?
Thanks,
tXm
KoffeeKommando (author) says: Sep 16, 2010. 8:18 AM
Yes, the stock pot is aluminum. I was just fixated on my memory of stainless flying in my face from cutting the hole in the bottom of the 6 quart pot ;)
In both cases you have to watch out. Cutting with any fiberglass cutting wheel is messy and somewhat dangerous.
Oh, cutting the hole in the bottom of the 6 quart pot is done the same way.
I made it square cause I ran out of small cutting discs. All I had was a corded drill with mandrel and 3" cutting disc. The corded drill was not high rpm enough to cleanly do the circle. I just did straight lines instead.
I'll update the main instructable with some alternate cutting tool info. Will show a Makita die grinder and the mandrel that holds 3" cutting discs.
thexmark says: Sep 21, 2010. 11:42 AM
I've got similar fans laying around. Looking at the image of the mounted fan, did you insert the short output duct into the out pot until the fan sat flush? And, if so, how did you secure the fan to the outer pot and did it withstand the heat after several burns?
-tXm
KoffeeKommando (author) in reply to thexmarkSep 21, 2010. 12:00 PM
Yes, the output duct is just slipped in. Then I put two short screws into the duct part (inside the pot) to keep the fan from popping back out.
I cut the duct opening very tight. It holds the fan pretty tight all by itself.
The fan does just fine. Not hot at all. This is due to the double burn pot configuration. The outer burn pot keeps the heat concentrated on the inner pot for the most part. The large outer pot only reaches around 100 deg down near the bottom. This is the beauty of the multi pot solution.
KoffeeKommando (author) says: Sep 21, 2010. 12:11 PM
Automotive header/exhaust manifold tape would be a great addition to the 6 quart pot:
http://www.summitracing.com/parts/THE-11002/
It would keep the heat contained in the burn area. The entire stove would probably be cooler on the outside surfaces.
thexmark says: Sep 21, 2010. 12:17 PM
I've also seen "concentrator" lids used to focus flame/heat output. Would you recommend one for this gasifier or have you tried using one?
KoffeeKommando (author) in reply to thexmarkSep 21, 2010. 12:35 PM
I played around with different odd concentrators and got wildly different things to happen. This Instructable was mainly for people to just get something up and running right off the bat.
Experiment away though!
If you come up with something that works, I'll add it to the Instructable with credit.
stoveman88 says: Mar 20, 2012. 12:03 AM
Based off of this idea, I made this bushbuddy style stove. I also use a double wall as well but no fan. Same idea...I made mine the size of a roll of toilet paper.
KoffeeKommando (author) in reply to stoveman88Mar 20, 2012. 7:33 AM
Very nice! Looks like a stainless vacuum mug?
stoveman88 in reply to KoffeeKommandoMar 21, 2012. 1:53 AM
You can check out an explanation of the stove and see it working here: http://www.youtube.com/user/solostove
jemor143 says: Aug 26, 2011. 8:45 AM
Tought I'd share some pics of my stove. Made with a 22 oz coffee can (6,5’’ x 5’’) and a 5" x 4,25" can for the burn pot. For use with twigs ans scraps I'll extend the burn pot to 6'' X 4,25". For the same burn time, twigs take a lot more space than wood pellets. The 5 volt fan is power here by a home made solar battery: the Mighty minty boost (see the Instructables by Honus).
I bend the top holes in order to have a nice swirling flame; I think it helps mixing the wood gas and the hot air and concentrates the flame in the center. It melted my aluminum pot stand right away!
Once started, it boils 2 cups of water in less than 3 minutes.
KoffeeKommando (author) in reply to jemor143Aug 26, 2011. 9:09 AM
And there you have it!
Now we just have to make a simple shroud for the fan to keep rain off.
Use metal wall studs from Home Depot to do ducts and boxes etc.
One stud can make tons of experimental ducts.
Cut with a good pair of tin snips. WalMart has yellow/black handled Stanley brand for cheap. They have serrated edges that helps the blades grab the metal.
I do like your aluminum box tubing as the duct.
What exact size is it?
Can you take a pic of the fan label up close?
And the air duct exit on the fan....
jemor143 in reply to KoffeeKommandoFeb 22, 2012. 8:05 AM
It's the same fan you can see on my previous post (5v x 0,15A). The ouput of air is enough for the size of the stove.
I can't take picture right now (forgot the stove at camp for the winter), but the duct is made with 1" square aluminium tubing (1/16 thick). For now, it's just tape to the fan with electrical tape. I'll glue them together with something more tough and durable, maybe some Sugru. I insert the duct in a 1" x 1" hole on the side of stove. The fan and the duct can be stored in the burning pot when not in use.
Speaking of Sugru, I think I'll put some spot of this stuff on the side of the stove, so I can manipulate it when hot, without a separate handle. Tried it on my pot handle, and it works great as a heatproof coating.
I might also try to make the connection between the air duct and the stove really air tight with this stuff. But it's not really necessary.
jemor143 says: Aug 19, 2011. 8:45 AM
I thought of a fast and easy way for controlling the air flow in this type of stove, where a blower is mounted on the side. (Did'nt find an electronic speed controller for 5v blower yet... They all have 12v input.)
You could add an air duct between the blower and the side of the stove, where a slot would allow a door to partially close the duct at will. See the small sketch.
KoffeeKommando (author) in reply to jemor143Aug 19, 2011. 11:31 AM
You could also do a center pivot. Like a stovepipe damper.
The flap can fit really shoddy, cause you only need to slow the flow of air a little.
jemor143 in reply to KoffeeKommandoAug 19, 2011. 11:52 AM
Of course! Right on.
jemor143 says: Aug 19, 2011. 11:03 AM
I have a question regarding material for a potstand. I'm planning to make a pot stand like the one below. I only have aluminium strips laying around. KK talks about really high temperature on top... It may be a stupid question; would the aluminium be able to sustain the heat?
KoffeeKommando (author) in reply to jemor143Aug 19, 2011. 11:33 AM
Possibly. Just try it.
On my big stove? No. I used some heavy expanded metal as a grate while boiling 5 gal of water. It melted the steel and made it droop in a huge circle below the giant water pot.
KoffeeKommando (author) in reply to KoffeeKommandoAug 19, 2011. 11:34 AM
Oh...the expanded metal grate was 8" *above* the top of the stove.
That's an amazing amount of heat.
jemor143 says: Aug 18, 2011. 10:15 AM
I found and idea for the burn pot on another forum; http://www.randonner-leger.org/forum/viewtopic.php?id=351&p=3
It's in french, but the pictures are enough to understand.
The guy use a double wall stainless mug. There are a few 20 oz mug out there that would be fine for my need. I'd prefer a bigger stainless wine bucket, that is also double wall (about 4" x 9"). It's rugged, and all you have to do is drill holes and make a potstand. It's a bit more expensive than tin can, but will last way longer!
That's my next project!
KoffeeKommando (author) in reply to jemor143Aug 18, 2011. 10:55 AM
Yes, that's a great idea.
Here is something you need to do.
The inner burn pot needs holes around the bottom. Drill these by sticking a 1/8" drill bit *through* the outer bottom holes in your picture.
Then make a cowling to enclose the bottom holes and provide fan air into them.
It does not have to be airtight. It can be a base "unit" with circular hole that the pot shown above can slide down into. This can also protect the fan, making it rainproof. Would also provide a more stable base for the "pot"
Also his top holes are too large. A double row of 1/8" are all that is needed.
Actually all holes in the pot pictured can be round. Square is just extra dumb work.
Let me see if I can do a quick illustration in a bit. It's easy and would be worlds better than what he did.
jemor143 in reply to KoffeeKommandoAug 18, 2011. 11:19 AM
I totally agree. My previous stove had too much holes at the top (and too big) for the secondary burn. 1/8 seems enough. According to the various design I saw on the web, it's better to have 20 smal holes than 10 big ones. My favorite fan-assisted stove is this one, (the smaller version): http://www.woodgascampstove.com/ It only have a few tiny holes in the bottom of the pot burner (see picture), to slow down the first burn. the creator call this stage pyrolysis, the secondary burn at the top being the combustion)
Thanks for the idea. To drill the inner holes at the bottom, I was going to drill through the outer bottom, then block the outer holes with JB Weld. I'd drill a bigger hole to serve as an air intake for the blower, just like you did in your instructable.
I figure I'll be able to drill the top holes from the inside, drilling at an angle. You have experience with stainless: what do you think?
KoffeeKommando (author) in reply to jemor143Aug 18, 2011. 11:33 AM
JB Weld and all that stuff does not stick to stainless.
Stainless is very hard to drill. The drill tip has to be the correct angle.
DeWalt 1/8" gold titanium bits go through like butter.
That's what I used to do this instructable.
A Rigid 3/16" cryo treated bit literally melted in 20 sec.
It glowed cherry red and almost didn't make it through the stainless.
Illustration coming up...
KoffeeKommando (author) in reply to KoffeeKommandoAug 18, 2011. 12:23 PM
Here is the idea...
And when not in use, the base can store the batteries and solar panels you have. Just stick them inside the round hole.
The fan and stainless gasifier part have standoffs in bottom so water getting inside does not go in fan (and gasifier heat stays off the bottom of box).
KoffeeKommando (author) in reply to KoffeeKommandoAug 18, 2011. 11:59 AM
(removed by author or community request)
jemor143 in reply to KoffeeKommandoAug 18, 2011. 12:21 PM
Thanks! Nice sketch!
I'll consider building the base. Would be really heavy duty, and solve the weather problem (I'm in Canada... where weather often is a problem.)
KoffeeKommando (author) in reply to jemor143Aug 18, 2011. 12:31 PM
The box could be made from thin birch plywood. Make it in octagon shape (round off corners). Then waterproof the birch with rubbed oil coating?
Glue the box together with wood glue and also use tiny nails.
It should withstand the heat.
Bottom pot standoffs could be stainless screws with the tips ground flat.
Or stainless machine screws. Just predrill tight holes.
KoffeeKommando (author) in reply to KoffeeKommandoAug 18, 2011. 12:34 PM
Or...spray the box with duplicolor truck bed liner spray in a can. Its a waterproof thick vinyl coating when dry:
http://duplicolor.com/products/truckBedCoating/
KoffeeKommando (author) in reply to jemor143Aug 18, 2011. 12:24 PM
I redid the pic...
Plus, the stove wont sink into snow easily.
KoffeeKommando (author) in reply to KoffeeKommandoAug 18, 2011. 12:11 PM
Might want to mount fan vertical on the side of box, then drill holes to outside as air intake. Put some holes right at the bottom so they can be drain holes as well while the stove is in operation.
KoffeeKommando (author) in reply to KoffeeKommandoAug 18, 2011. 12:08 PM
Now...all our talk is for DIY people using old computer fans etc...
This is the winner in commercial stoves:
http://www.biolitestove.com/CampStove.html
It's self powered. The TEG inside powers the fan and can charge a cell phone too. No batteries or solar. The custom fan is the only moving part.
jemor143 in reply to KoffeeKommandoAug 18, 2011. 12:22 PM
I agree, the Biolite is the way to go. Correct me if I'm wrong, but I think we'll have to wait until next spring to buy it?
KoffeeKommando (author) in reply to jemor143Aug 18, 2011. 12:23 PM
Yes, it's at the link.
jemor143 says: Aug 17, 2011. 12:05 PM
Love what you did with the fan. I was inspired by your design, and solved my "problem".
Here is the setup iI settled for:
- a 5V blower fan
- two solar panel in parallel (1,715W) that can directly power the fan in sunlight.
- a 4 AA (NIMH) battery pack, that can be recharge by the solar panel.
On the picture, the fan is only powered by the solar panels, and it runs full speed. I'll be able to save batteries when it's sunny. Moreover, you can easily control the speed of the fan by covering/uncovering the panels!
KoffeeKommando (author) in reply to jemor143Aug 17, 2011. 3:39 PM
Cool! I like the USB plugs.
What is the model/part number of the fan?
Would like to see how many CFM it is.
jemor143 in reply to KoffeeKommandoAug 17, 2011. 5:16 PM
That's why I chose the 5V model, it allows more flexibility with the power.
It's a 5V x 0,15A and measures 50mm x 15 mm. It was listed as 15 cfm. Seems like enough power for the size of my stove, whick is a bit smaller than your. Anyway, I will try a bigger one: 5V/0,18A; 75 x 25 mm.
KoffeeKommando (author) in reply to jemor143Aug 17, 2011. 5:24 PM
Here is a big fan for $18 with USB end:
http://amzn.com/B005AKCNBY
KoffeeKommando (author) in reply to jemor143Aug 17, 2011. 5:22 PM
Where are you located?
Where did you buy those specific models of fan?
They sound about right CFM wise.
My 24 v fan runs very slow. It's not a blast furnace thing.
I have a 5v USB adapter for 12v cig. lighter socket. I could run 5v easily too.
There are also 12v laptop power supplies with an accessory 5v USB receptacle on them. I'm going to hook one to a Ryobi cordless tool batt pack. Having a USB jack is bonus.
jemor143 in reply to KoffeeKommandoAug 17, 2011. 5:54 PM
By the way, I had to solder the USB jacks myself...
KoffeeKommando (author) in reply to jemor143Aug 17, 2011. 6:00 PM
I figured that ;)
That large 5v Amazon fan looks good. It has accessory mounting holes all over it.
It would be perfect to mount a rain cover for the fan.
That's going to be my next addon. I want the big gasifier to be all weather.
jemor143 in reply to KoffeeKommandoAug 17, 2011. 6:08 PM
The rain! I never tought to protect the fan...! Keep us posted on that cover.
KoffeeKommando (author) in reply to jemor143Aug 17, 2011. 6:12 PM
Yeah, anytime I see wiring and the like I immediately think waterproofing.
I'm from NY. It rained all the time there.
And of course it's going to be rainy cold when using a gasifier outdoors.
You could use duct tape and folded tinfoil...or thin sheet metal cut to fit.
Each fan is going to be different.
jemor143 in reply to KoffeeKommandoAug 17, 2011. 5:43 PM
I bought the fan on ebay; search the words 5v blower fan; you'll find the CFM you need. They're not expensive.
Around the camp, I'll use a 12V power pack with an USB adapter. On the trail, I'll use the pack with 4 NIMH batteries (4,8V); it last for about 8 hours.
jconway1 says: Jul 26, 2011. 4:33 PM
Why do you need a fan? ... what is the problem with holes drilled at the perimeter of the base? ... please advise!
jconway1 says: Jul 26, 2011. 4:24 PM
Just a suggestion for lid cutting tech, I think this instructable is superb.
Why not clamp or "jig" a fixed hold for your dremel, like a reversed (upside-down) circular saw (to hold it in place as shown in your photo). Drill a 6mm hole in the centre of your pot lid and sit it on a pencil (or somesuch) as a compass point, then rotate and cut. Almost "Score" the lid first and then adjust. Cut mm by mm lifting the lid (evenly) to the blade after each full revolution.
That way you will get a beautiful and even cut. The only thing that I would look out for is the wear on the blade. This is because, although the front tip does the cutting - it's the REAR of the blade face that gives you the shape - thus as it wears down your diameter will change.
Give it a go though, you can always buff it if you need it SUPER-perfect eh ;)
Good luck guys, I want to give this instructable a go myself so I'll post you some photo's soon too.
Cheers.
jemor143 says: Jun 22, 2011. 11:40 AM
Nice work!
I've been working on one of those, and I thought I'd share my thoughts.
The stoves : After a few tries, I settled for this: a 23 oz coffee can (6,5’’h x 5’’d) and a one liter can for the inside. You can go smaller than this (ex : with a quart paint can for the outside and a 20 oz can inside), but for what I know it doesn't contain enough wood to be really practical. The 23 oz coffe can is small enough to carry it in a backpack. The only problem is the rust: Any suggestion for a good paint for the outside?
I’ve try a wood gas stove without a fan (a homemade bushbuddy), but got too much smoke for the taste of my girlfriend. Maybe the air intakes were’nt big enough.
Anyway, I will try a 5V computer fan (50mm x 15mm). I didn’t try it yet, but the numbers seems right. For the same size and current, the blower type (see the picture) seems to outputs way more airflow than the blade type. Moreover, the airflow seems to be easier to harness. Since it's only 5v, you can power the stove in the field with a battery pack (4 rechargables AA= 4,8V), that should give you a few hours of autonomy. I’ve tried a 12v fan, but the 9v batterie didn’t last an hour. The 12 v seems the right choice around the house or the car, but on the trail, I’d rather carry fuel than a 12 volt battery! According to the specs, the 5v does’nt blow a lot less than the 12v. Anyway, I might upgrade to a 5v 70mm x 30mm. After all, my goal is not to melt metal with this thing, just boil some water on the trail.
Also, if you install a USB male Jack to the fan, you'll be able to plug the stove in almost any USB outlet! Including the MightyMinty Boost(see the instructable by Honus)! Heck, with a good sunlight, you might even try to power the fan directly from a solar panel! You only need 5V x 0,15A =0,75W! (Am I right?) There’s a lot of cheap and small panel out there that will do the job. Anyway, this is all theory. Anyone has experimented with a 5V fan? Any suggestions?
The other problem is the connection between the blower and the stove. I want to save some weight, and more important, time and trouble. A good way to join the blower to the stove would be a 3'' silicone coupler; that is readily available and can withstand up to 500F. All you have to do is glue the tube to the blower, and insert the tube in a close-fitting hole at the base of the outside can, and take it out once your done. This way, the blower will be isolate from the heat. One would be able to store the blower and the battery pack inside the stove for transport. Any thoughts on the tubing or duct? I know some people built duct from scratch..
Hope I’ll be able to try this soon!
jemor143 in reply to jemor143Jun 23, 2011. 10:04 AM
Anyone with a good idea for a speed control on the motor?
KoffeeKommando (author) in reply to jemor143Jun 23, 2011. 10:23 AM
http://www.directron.com/speedcontrol.html
Start here....
oldestgeek says: Oct 15, 2010. 4:42 AM
Great Instructable! Do you think using a plasma cutter to "pop" the small holes in the pots will work? how about using smaller holes, just many more of them? I am sure that a plasma cutter will greatly simplify the cutting of lids. How easy is it to scale your design down to a smaller size if needed? I have around 50+ of the DELL style fans, and operating them at 12 volts they REALLY move some air.
DELETED_kage_no_akiri in reply to oldestgeekDec 2, 2010. 1:58 AM
jemor143 in reply to DELETED_kage_no_akiriJun 22, 2011. 12:49 PM
"but i found charcoal briquets dont throw off as much heat as i thought it would"
Maybe because the briquet have already been "gasified", kinda like the char cloth...
sokra says: Mar 10, 2011. 9:55 AM
This looks like a forge rather than a gasifier.
KoffeeKommando (author) in reply to sokraApr 25, 2011. 8:00 AM
Yes, it's a gasifier. Watch my video:
http://www.youtube.com/watch?v=Kb5tWYn4-cA
And look into the different designs out there. Read some of the research papers.
keif999 says: Mar 12, 2011. 4:33 AM
Hi Folks, Does anyone produce these for sale as the ones ive found online are made of thinner metals?
any help would be great,
K
Raydoom says: Oct 19, 2010. 4:01 AM
if you bump up the fan size like almost somthing out of a hair dryer or leaf blower (leaf blower is probs abit to much for somthing of this size) you should be able to acheve a hotter flame , but you may need more holes or bigger holes to take the stronger airflow. Mabe if you had a welder you could use a washing machine barrell ( lots of small holes ) inside a big drum, might be alot of fuel getting burnt but the heat would be amasing.
anny way its a pretty sweet build probly usefull if you go camping were there are fire bans making it almost impossable to get caught (no smoke)
steveb says: Oct 12, 2010. 12:38 PM
Great instructable, I'm definitely going to build something inspired by this and bioenergylists.org.
Regarding adding the combustible fluid, do you think pouring it into the main vessel would mean some of it would drip down and ignite the pellets in the middle?
I've read elsewhere a small amount of pellets should be soaked separately then added to the top, so the burn pattern is strictly top-down.
dawoj says: Sep 26, 2010. 2:10 AM
good effort. Petlier device might work
likewho says: Sep 22, 2010. 2:29 PM
I find it much easier to convert waste heat to electricity using a thermoelectric generator (TEG) module. I’ve tried standard peltier modules for power generation with limited success and very short service life. They cannot hold up to the higher temperatures necessary for good power generation performance. I found a terrific supplier with both standard temperature and high temperature TEG modules designed specifically for power generation. They sell a lot of devices on eBay and you can also buy from them direct. The company is Thermal Enterprises and here is are links to a couple of their eBay items.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310148993913&ssPageName=STRK:MESELX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310209561834&ssPageName=STRK:MESELX:IT
macrumpton says: Mar 11, 2010. 3:44 PM
Very nice job.
I wonder if you could attach a peltier device to have the heat generate the power to run the fan? or you could use a thermopile like the Stovetec rocket stove.
There seem to be a lot of similarities between rocket stoves and wood gas stoves, or is that just my imagination?
nutsandbolts_64 in reply to macrumptonApr 14, 2010. 7:20 PM
Sorry, but the Peltier thing works in reverse. You input electricity and it generates heat. Just call it a thermoelectric generator.
beehard44 in reply to nutsandbolts_64Sep 11, 2010. 1:11 AM
It works both ways, i guess i can generate a lot of energy from that here in the philippines XD
nutsandbolts_64 in reply to beehard44Sep 12, 2010. 1:20 AM
*ehem* talking about effects, not the device.
macrumpton in reply to nutsandbolts_64Apr 15, 2010. 6:02 AM
nutsandbolts_64 in reply to macrumptonApr 15, 2010. 8:26 AM
Peltier and Seebeck are 2 different things, but they're under thermoelectric so let's just call it thermoelectric.
KoffeeKommando (author) in reply to macrumptonMar 11, 2010. 7:04 PM
The Biolite Ethos stove uses a TEG module to run a fan. it's a very tiny fan though.
A TEG/peltier unit big enough to run a computer fan is $$$$$$.
Better to use 8 AA rechargeable/solar panel charger combo.
Or like I did..use a jumper pack and a larger solar panel. You can then supply power for a household/camp.
Rocket stoves are weird old school. This is more like science. You have to build one to see this.
macrumpton in reply to KoffeeKommandoMar 12, 2010. 7:10 AM
Actually according to their site Biolite is designing a rocket stove.
There are several fan/forced air  stoves around, but they all seem to be electric. I was wondering if someone has ever tried doing a thermoacoustic or stirling fan for these stoves. How much air does the fan need to move?
KoffeeKommando (author) in reply to macrumptonMar 12, 2010. 10:38 AM
Biolite's first "product" was a small gasifier. They are teaming up with the creators of the rocket stove to make a new "proper" rocket stove with a fan. That said, a rocket stove is still inefficient. You cannot burn pellets or biomass scraps in a rocket stove. And you have to manually push the wood into the stove as it burns. Bogus.
You need to be able to power a computer fan. Start your calculations there.
20-40 CFM is ballpark. Energy varies by fan unit. Go look up some specs.
Biolite is making custom low power fans with optimized flow paths so they don't need to use big TEG modules. As the power requirements go up, so does the need for a more $$$$$ thermo power generating unit.
Don't wonder about it...buy some parts and MAKE an Instructible!
jolshefsky says: Aug 11, 2010. 10:18 AM
Correct me if I'm wrong, but the stove will theoretically work with just the two inner pots.  The innermost pot is the burn pot (obviously), and the middle pot directs the airflow to the upper and lower air holes of the burn pot.  I assume the outer pot acts as an insulator to keep the middle pot hot so hot air is fed into the burn pot.
I'm working on collecting the pots from thrift stores and trash piles (nothing like living a half-mile from a college in an student-centric neighborhood) so it's a bit more slow going.  I also don't get to be as specific about dimensions.  I have a very sturdy inner pot although I think it's a little small for the job -- nonetheless, it'll work.  I have an eye on a couple more larger pots but we'll see.
KoffeeKommando (author) in reply to jolshefskyAug 13, 2010. 3:26 PM
You are correct. If you only use two pots the fan will melt from the intense heat (unless you take measures to avoid this). Having the large outer pot keeps the fan safe. It's a nice tight package if you build it like I did. I didn't want crazy dangling tubes coming off the thing. The 3 pot setup is pretty elegant as solutions go. The parts list is a suggestion only. If your town has a restaurant supply, it will probably have the exact pots. I tried looking for random pots and it took way too long in my area. I wanted to make this instructable immediately useful to the largest group of people. Get to a store and git er' done!
French_horn47 says: Jul 7, 2010. 10:51 AM
Could you put up a diagram of what the pots look like nestled together? Thanks!!
KoffeeKommando (author) in reply to French_horn47Jul 9, 2010. 11:24 AM
Please refer to Step 6 pictures. It's just the top ring, big pot, smaller pot inside. This pot assembly just drops into the BIG outside pot with handles. There is a few inches airspace inside the bottom of the big outside pot. The top assembly does not touch the bottom.
mspaeth says: May 30, 2010. 9:19 PM
What is the functional difference between the gasifiers with fans and those without? Some say you don't need a fan. Are those with fans more efficient?
I thought woodgas camp stoves were the most efficient stoves but StoveTec Rocket Stoves claims their stove design is the most efficient.
What do you think?
macrumpton says: May 30, 2010. 8:45 AM
I remember seeing years ago that early forges were built on top of a hill with a long tunnel going up the side of the hill. A small fire at the bottom of the tunnel got the air moving up the tunnel to the main fire at the top. Some of the more ambitious ones had several fires and inlets at intervals going up the hill.
I wonder if you could do without the stove fan if you had a taller stove with the fire near the bottom? Then the draft of the air going up the chimney would suck the air in like a fan.
KoffeeKommando (author) in reply to macrumptonMay 30, 2010. 8:23 PM
Natural draft stoves have been created. Some work fairly well indoors.
http://www.bioenergylists.org/andersontludconstruction
See the problems with them?:
http://www.bioenergylists.org/content/testing-andersons-tl
Forced air fan stoves rule. They work in any wind conditions. Mine does not go out even in crazy wind outdoors with NO windbreaks.
sodasound says: Feb 7, 2010. 2:02 PM
Hey, ditto on the completion-backwards-principle. I'm following a list of these designs now. This one looks good.
KoffeeKommando (author) in reply to sodasoundFeb 7, 2010. 3:19 PM
Yeah, I did a lot of homework on it. It's a really big burner for crazy jobs.
I use it to run a 30 gallon water heater. 1hr burn (1 pot full) of pellets gets you over 100 degrees in the tank. Another half burn and the water is up to 150 deg.
Never tried a two hour burn. Water might be too hot to use.
Video coming up in the future showing this.
LCsDad says: Jan 23, 2010. 7:57 PM
Could you drill a boat-load of little holes in the bottom of the inner burn pot instead of around the sides?  Might get air to the center of the woodpile... but might also get clogged up?  Lemme know if you've tried.
Thanks for the very good instructable!
KoffeeKommando (author) in reply to LCsDadJan 24, 2010. 9:36 AM
It's REALLY hard to drill holes in the stainless. The drill bit might die before you even finish.
The burn goes along fine even with those small side holes. Only a tiny bit of ash is left once it's done. You could do about 4 one hour burns before needing to clean the pot out.
Plus, with only side holes, the inside of the stove stays clean.
I think most of the commercial TLUD type stoves have a solid bottom too.
Going to try less holes again on the next burn pot I build. I just did a small stove from a paint can and a 1 1/4 quart stainless pot. It burned for a solid hour with only 7 of the 1/8" holes on the bottom of the burn pot.
Vulcanator says: Jan 16, 2010. 12:02 PM
So Cool...
gawel in reply to VulcanatorJan 18, 2010. 3:30 AM
So Hot
KoffeeKommando (author) in reply to VulcanatorJan 16, 2010. 5:57 PM
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
