3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Large portable wood gasifier stove
*New video added at end. Shows the gasifier "between modes".
YouTube channel HERE
*New* video of gasifier operation HERE
*New* MIDGE camp stove build videos:
PART1 - Build
PART2 - Fueling/operating the stove
This is the documentation of my largest gasifier experiment so far.
This unit costs about $50 to make.
After building a MIDGE stove, I wanted to design something with bigger,better performance.
It also needed to be a design that could be copied easily. All parts must be commonly available. Tools should be kept to a minimum.
This gasifier can be built in two quality levels. The prototype is identical to this silver aluminum model but is made from a large popcorn can using no power tools.
The output of this stove is very high. A very rough estimate might be 30-40,000 BTU. Don't quote me on that though. It can boil 5 gallons of water in 30 minutes. I've also mounted it under a 30 gallon gas water heater. After an hour and a half of runtime the water inside reached 150 deg. F
The stove will run for 1 hour without "in flight refueling". Wood pellets are the preferred fuel but literally anything "woody" can be burned in the stove. This stove burns material from the top down.
If burning wood scraps like 2x4 and pallet chunks, pack the wood in tight and cover with a layer of wood pellets. The top layer of pellets will create the initial layer of coals you need for nice combustion.
Much more can be said about stove operation. I will document some of this as I go on. Once you build the stove and run a few times on wood pellets, the operation becomes more obvious. When operated correctly there should be NO SMOKE emitted.
There are somewhat dangerous fumes produced by this size stove so don't use it indoors. Treat this device like a literal "campfire in a can".
TLUD stoves such as this are very safe in operation for the most part. The top ring of the burn pot gets incredibly hot (230 deg. +) but the sides stay cool (100 deg. or so) for the rest of the burn.
My stove uses a regular common computer fan for air supply. A centrifugal blower style fan is preferred but an axial fan can be used successfully if you make a straight duct and attach to the outer pot. Blower fans can be found surplus or can also be found in some Dell tower computers.
Improvise and adapt!
Now on to the plans........
Step 1Gather tools and parts
Tools needed:
- Dremel tool with fiberglass cutoff wheel
- Corded or cordless drill
- DeWalt 1/8 or 9/64th titanium drill bit
Components needed:
- 12 quart aluminum stock pot (buy quality restaurant grade with thick lid)
- 4 quart stainless steam table pot with "inset" top (Libertyware IP04 or Vollrath?)
- 6 quart stainless steam table pot bain marie(Libertyware BM06 or Vollrath ?)
- 12 sheet metal screws (pref. stainless)
Libertyware website w/part numbers:
http://www.libertywareusa.com/products/i/ip04.aspx
http://www.libertywareusa.com/products/b/bm06.aspx
Optional (if you can't cut the main hole perfect):
- wood stove cement
- high temperature RTV sealant
- Thermo Steel high heat putty
Optional tools for cutting main holes:
- Makita die grinder GD0601
http://www.toolbarn.com/makita-gd0601.html?ref=base
- Clesco M-3 wheel mandrel set (Holder for 3" stainless cutting discs. Can be used with Makita or  corded drill)
http://www.drillspot.com/products/62526/Clesco_M-3_Screw_Type_Cut_Off_Wheel_Mandrel
- 3" fiberglass cut off wheels (Any brand with these specs will do. 3/8" center hole preferred)
http://www.lehighvalleyabrasives.com/servlet/the-99/3%22-X-1-fdsh-16%22thk.-X/Detail
These pots should be bought from a real restaurant supply store (or come from a restaurant).
I used Libertyware (Indian made), but Vollrath (USA) should work also. The Vollrath "inset" 4  quart is shaped differently I believe. Test fit before buying.
The burn pots are stainless, this is the only durable way to go. Use DeWalt or equivalent drill bit that is capable of drilling stainless. The point angle of the drill bit really matters. A Rigid brand cryo cobalt bit did NOTHING. It literally melted trying to drill the thin stainless. DeWalt titanium went through like drilling butter. It was a night and day difference. Will give part number of drill bit later. It's common at any Home Depot.
83 comments
1-40 of 83next »
Sep 15, 2010. 9:10 AMthexmark says:
Thanks for the instructable. I plan on having a go at this in the next couple weeks. I have the stock pot with lid and am ordering the other SS pots. Could you shed some light on how exactly to cut the hold in the lid for the 6inch pot? What is the best method to start the cut and then to actually make the round cut? What tool(s)?
Sep 15, 2010. 12:26 PMthexmark says:
KK
Thanks for the detailed reply. I have a clear idea of what to do now.
One quick note, you mention stainless metal shards but the stock pot you and I are using is actually aluminum, correct?
Thanks,
tXm
Sep 21, 2010. 11:42 AMthexmark says:
I've got similar fans laying around. Looking at the image of the mounted fan, did you insert the short output duct into the out pot until the fan sat flush? And, if so, how did you secure the fan to the outer pot and did it withstand the heat after several burns?
-tXm
Sep 21, 2010. 12:17 PMthexmark says:
I've also seen "concentrator" lids used to focus flame/heat output. Would you recommend one for this gasifier or have you tried using one?
Mar 20, 2012. 12:03 AMstoveman88 says:
Based off of this idea, I made this bushbuddy style stove. I also use a double wall as well but no fan. Same idea...I made mine the size of a roll of toilet paper.
Mar 21, 2012. 1:53 AMstoveman88 says:
You can check out an explanation of the stove and see it working here: http://www.youtube.com/user/solostove
Aug 26, 2011. 8:45 AMjemor143 says:
Tought I'd share some pics of my stove. Made with a 22 oz coffee can (6,5’’ x 5’’) and a 5" x 4,25" can for the burn pot. For use with twigs ans scraps I'll extend the burn pot to 6'' X 4,25". For the same burn time, twigs take a lot more space than wood pellets. The 5 volt fan is power here by a home made solar battery: the Mighty minty boost (see the Instructables by Honus).
I bend the top holes in order to have a nice swirling flame; I think it helps mixing the wood gas and the hot air and concentrates the flame in the center. It melted my aluminum pot stand right away!
Once started, it boils 2 cups of water in less than 3 minutes.
Feb 22, 2012. 8:05 AMjemor143 says:
It's the same fan you can see on my previous post (5v x 0,15A). The ouput of air is enough for the size of the stove.
I can't take picture right now (forgot the stove at camp for the winter), but the duct is made with 1" square aluminium tubing (1/16 thick). For now, it's just tape to the fan with electrical tape. I'll glue them together with something more tough and durable, maybe some Sugru. I insert the duct in a 1" x 1" hole on the side of stove. The fan and the duct can be stored in the burning pot when not in use.
Speaking of Sugru, I think I'll put some spot of this stuff on the side of the stove, so I can manipulate it when hot, without a separate handle. Tried it on my pot handle, and it works great as a heatproof coating.
I might also try to make the connection between the air duct and the stove really air tight with this stuff. But it's not really necessary.
Aug 19, 2011. 8:45 AMjemor143 says:
I thought of a fast and easy way for controlling the air flow in this type of stove, where a blower is mounted on the side. (Did'nt find an electronic speed controller for 5v blower yet... They all have 12v input.)
You could add an air duct between the blower and the side of the stove, where a slot would allow a door to partially close the duct at will. See the small sketch.
Aug 19, 2011. 11:52 AMjemor143 says:
Of course! Right on.
Aug 19, 2011. 11:03 AMjemor143 says:
I have a question regarding material for a potstand. I'm planning to make a pot stand like the one below. I only have aluminium strips laying around. KK talks about really high temperature on top... It may be a stupid question; would the aluminium be able to sustain the heat?
Aug 18, 2011. 10:15 AMjemor143 says:
I found and idea for the burn pot on another forum; http://www.randonner-leger.org/forum/viewtopic.php?id=351&p=3
It's in french, but the pictures are enough to understand.
The guy use a double wall stainless mug. There are a few 20 oz mug out there that would be fine for my need. I'd prefer a bigger stainless wine bucket, that is also double wall (about 4" x 9"). It's rugged, and all you have to do is drill holes and make a potstand. It's a bit more expensive than tin can, but will last way longer!
That's my next project!
Aug 18, 2011. 11:19 AMjemor143 says:
I totally agree. My previous stove had too much holes at the top (and too big) for the secondary burn. 1/8 seems enough. According to the various design I saw on the web, it's better to have 20 smal holes than 10 big ones. My favorite fan-assisted stove is this one, (the smaller version): http://www.woodgascampstove.com/ It only have a few tiny holes in the bottom of the pot burner (see picture), to slow down the first burn. the creator call this stage pyrolysis, the secondary burn at the top being the combustion)
Thanks for the idea. To drill the inner holes at the bottom, I was going to drill through the outer bottom, then block the outer holes with JB Weld. I'd drill a bigger hole to serve as an air intake for the blower, just like you did in your instructable.
I figure I'll be able to drill the top holes from the inside, drilling at an angle. You have experience with stainless: what do you think?
Aug 18, 2011. 12:21 PMjemor143 says:
Thanks! Nice sketch!
I'll consider building the base. Would be really heavy duty, and solve the weather problem (I'm in Canada... where weather often is a problem.)
Aug 18, 2011. 12:22 PMjemor143 says:
I agree, the Biolite is the way to go. Correct me if I'm wrong, but I think we'll have to wait until next spring to buy it?
Aug 17, 2011. 12:05 PMjemor143 says:
Love what you did with the fan. I was inspired by your design, and solved my "problem".
Here is the setup iI settled for:
- a 5V blower fan
- two solar panel in parallel (1,715W) that can directly power the fan in sunlight.
- a 4 AA (NIMH) battery pack, that can be recharge by the solar panel.
On the picture, the fan is only powered by the solar panels, and it runs full speed. I'll be able to save batteries when it's sunny. Moreover, you can easily control the speed of the fan by covering/uncovering the panels!
Aug 17, 2011. 5:16 PMjemor143 says:
That's why I chose the 5V model, it allows more flexibility with the power.
It's a 5V x 0,15A and measures 50mm x 15 mm. It was listed as 15 cfm. Seems like enough power for the size of my stove, whick is a bit smaller than your. Anyway, I will try a bigger one: 5V/0,18A; 75 x 25 mm.
1-40 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:KoffeeKommando(Reality Based Engineering)
Sharing the wealth...
