3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Large portable wood gasifier stove
Step 5Inner burn pot air holes
This is the tricky part. Get ready to do some stainless drilling!
Mark holes first with a sharpie marker or metal punch.
If marked with sharpie marker just go slow with drill at first. Make sure the drill is biting into the metal, then go full speed and punch the hole quickly. Too slow and the bit will never make it through. The stainless gets heated by the bit and odd things happen. You have a "window of opportunity" of just a few seconds. DeWalt bits make it pretty easy. I was able to get into a fast hole punching motion easily.
Refer to the pics for the hole configuration. These are CRITICAL.
Lower holes are in the most optimal configuration ( I believe). The stagger allows for a nice secondary burn when the pellets get low.
The top "afterburner" holes are offset somewhat to give a little "swirl" to the burning gases.
Single holes can work fine too. Larger holes work well also. They are very hard to drill in stainless though. Some more work and testing on top hole configuration is needed.
IMPORTANT NOTE:
See the 4 screws spaced evenly in the pot below the top air holes?
These center the inner burn pot inside the outer 6 quart pot. Makes things line up perfect when you drop the small pot into the larger one. You will see these screws better in the next step.
It's just a little trick to save time and ease alignment. You can cut the sharp heads off with Dremel if you like.
1 comment
Jan 23, 2010. 7:57 PMLCsDad says:
Could you drill a boat-load of little holes in the bottom of the inner burn pot instead of around the sides?  Might get air to the center of the woodpile... but might also get clogged up?  Lemme know if you've tried.
Thanks for the very good instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:KoffeeKommando(Reality Based Engineering)
Sharing the wealth...
