Step 105-min Laser Ball
Maybe you've got a laser pointer and tennis ball but not all the other goodies, well don't fret, you can still have yourself a Laser ball in a matter of minutes. This is a min-Instructable on how to build a basic Laser Ball from a laser pointer, some AAA batteries, a bit of wire, copper tape, electrical tape, and of course a tennis ball.
Tools:
- Pliers
- Soldering iron
- Hobby knife
- Remove the laser module from the pointer with two pliers by using a twisting motion
- Unscrew cap and housing
- Remove the switch
- Solder switch leads together (you could also just tape the switch down)
- Solder some wire to small pieces of copper tape
- Attach the other ends of the wire to the V+ and V- leads on the laser module
- Use a longer strip of copper tape to connect the V+ and V- terminals on the two batteries
- Cut a hole for the laser into the tennis ball
- Cut a slit for the battery pack into the tennis ball
- Thread the laser leads through the tennis ball
- Connect the copper tape to the open battery terminals and use electrical tape to make a small battery pack
- Tuck the battery pack into the tennis ball
- Shine on!
comment
Add Comment
LeoneLabs (author)
says:
Add Comment
