Laser Beam Alarm System with Rechargeable Battery for Laser
Hi Everybody... I'm Revhead, and this is my first instructable so please feel free to give me advise and point out areas in which to improve.
The inspiration for this project came from Kipkay who posted a similar version (PROTECT YOUR HOME WITH LASER BEAMS) After looking at the comments from his instructable, I found that many people where having trouble getting it to work and thought there were some limitations to it, so here I am, posting my version of the laser beam alarm system which I built for my year 12 final in Systems Engineering. (Which made it to the short listings for the TOP DESIGNS EXEBITION.)
Once your finished looking, please give it an honest rating, thank you!
My version is different in the following ways; I have a solar panel to recharge the battery which powers the laser, a current regulator to control current flow to the battery, a different LDR (Light Dependent Resistor) circuit, and a relay circuit so that the alarm stays on once the laser beam is broken.
Step 1Parts That You Will Need
Below you will find a list of materials and components that you will need to construct this instructable, A Laser Beam Alarm System!
Laser and rechargeable battery unit:- Solar Cell capable of anywhere between 6-12 Volts
- A Laser pointer which you can pull apart (I used a cheapo red one but it would be really cool if you had the money for a green one)
- LM317T current regulator chip
- Appropriate resistor for LM317T (will be explained later)
- A 3 Volt rechargeable Battery (I got mine from an old cordless phone)(the battery doesnt need to be three volts, that just what my laser needed, choose a battery that is appropriate to your laser)
- Some switches
- Soldering equipment
- Adjustable flexi arm for aiming the laser (optional but worth it)
- Hot Glue
- Shrink Wrap
- Small Project Box
- Crimp Connector
LDR and Alarm unit:- LDR
- 10K (10,000 Ohms), Variable Resistor
- 10K (10,000 Ohms), resistor
- NPN transistor (I used a 2N3904 type but any should work)
- LED (I used Green)
- 510 Ohm resistor
- A Small Reed Relay (I used a 5 Volt DC one)
- 2K2 (2,200 Ohm) resistor
- 120 Ohm resistor
- Buzzer 6-12 Volts will work
- A Second Transistor ( thank you to collard41 who clarified that this is infact a NPN transistor)
- Some Switches
- Two 9 volt batteries
It looks like a lot and seems hard but it really isnt, I will guide you step by step and as best I can.
143 comments
1-40 of 143next »
Jan 4, 2012. 7:36 PMpjsiwa says:
nice
Nov 30, 2009. 5:14 AMakinich says:
hey its me again
i know its been a long time
i have finally completed the project
its so cool
ok my question is
did you use a special software to design the circuits
if you have please tell me about it
        cheers
        akinich
Sep 12, 2011. 4:52 PMjjayag says:
Use Multisim... a very powerful software,,, we use this at school for simulation,,, just try it...=)
Sep 13, 2011. 2:25 AMakinich says:
hey thanks
will do!
Sep 12, 2011. 5:17 PMjjayag says:
could you please specify the part number of the reed relay??. I really need it for my project.. I've already completed the circuit and is working fine,,, but the alarm wont remain "on" once the path is covered already,,, Actually the reed relay is the one that makes this purpose.,, But according to your design the reed relay must have 6 pins (2 for the input, 2 for the output and 2 for the reset)... Is this the one that you used?
Pls reply as ASAP,,, tnx in advance
Sep 6, 2011. 1:32 PMmayur.phadte says:
Is this relay ok? it's a 12V one. Would it work?
http://robokits.co.in/shop/index.php?main_page=product_info&cPath=14_61&products_id=204
or this one ?
Aug 29, 2011. 2:32 PMmayur.phadte says:
I am getting the exact opposite in step 2.
My Led Goes on when there is light,and off when dark.
I will try to get it right,but do u have any suggestions so that I can modify something else and live with this shortcoming of mine ?
Aug 29, 2011. 2:34 PMmayur.phadte says:
So its just like when ur relay is connected mine isnt and when urs isnt mine is.
I am not able to think of anything that will invert this effect.
What if I use any Hex Inverter Gate like maybe the 7404 and inverter the 1-0 ?
Any help?
Jul 29, 2011. 11:28 AMcknudstrup says:
One thing you may want to include is a Diode in the Charging circuit from the Solar panel so it does not rob power from the battery at night unless your solr panel already has a diode built into it. Also you really only need one switch from the solar panel tothe circuit on either the positive or negative circuit as either one will cut the power from the solar panel to the rest of the circuit. Its not wrong the way you have it just overly redundant.
Good job as a first major project though.
Chris
Apr 17, 2011. 12:43 AMBILALOMARI says:
IT IS VREY GOOD WORKING ....
Mar 11, 2011. 6:46 PMjcatuling says:
wow! awesome.. hahahah I wanna try it even though i'm a newbie in electronics..(I learned electronics on our physics course and having fun with it lol),
^_^
-Jenriel (philippines)
Student"
Mar 7, 2011. 1:45 AMynakamura says:
wow i really appreciate it. can i ask some advice . can you help me make a simple low cost laser alarm? step by step . or can you make some video's ? i hope you can help me . thanks bro. goodluck . im begging you :)
Dec 15, 2010. 3:17 AMmayur.phadte says:
can u name the relay please..!
My shop vendor says he cannot sell components without proper name,the police has prevented them from doing so.
Dec 16, 2010. 3:29 AMmayur.phadte says:
dats it?
Dec 4, 2010. 8:23 PMDigy says:
Here is my schematic of what I used for all those people who unable to keep their alarm going after its been tripped, also does anybody have any ideas on how to wire this up to an ac adapter, cuz it uses a crapload of power, probably because my design uses two relays...
Also I have included pictures of my final design...
I also used a separate sensor unit for added ease of laser positioning.
Alarm Unit Diagram.jpg2010-12-04 22-14-10.438.jpg2010-12-04 22-14-29.792.jpg2010-12-04 22-14-46.484.jpg2010-12-04 22-15-19.022.jpg2010-12-04 22-15-31.781.jpg2010-12-04 22-15-58.524.jpgAlarm Unit Diagram.jpg
Dec 7, 2010. 5:24 PMDigy says:
Cool, glad you like it! I'll post pics of the insides after I get some parts to get a separate battery box with closed circuit alarm because the inside is so cramped with two nine volts, My box is actually a lot smaller than yours, at least it looks like that to me. But, ill give you a quick runnup of how I laid out the components, I basically took a 1" by 2" pcb board that I could break in half if iwanted from radio shak, and put one main circuit on one side, the other main on the other side, and the reed relay in the middle. Let me know if you have anymore questions.
Also, do you think If i took a regular 9 volt ac adapter and hooked up to the battery clips (both at the same time, in a parallels circuit, that it would work, b/c my batteries always runnout after a couple of hours of running, or couple minute of alarm activation.
Dec 11, 2010. 7:39 AMDigy says:
Cool, I'll try that, I think I'll try to make some battery backup box too, and yea I do live in america, but I'm from europe.
Dec 4, 2010. 8:34 PMDigy says:
Also, i am working on a system the that will prevent the power from being cut if it is hooked up to an ac power source, and the ability to add an external alarm and trigger, (expandibility)
I will post it up when finished.
Oct 1, 2010. 1:46 PMtomx63 says:
Dude, I've just started studying electronics and I have to say that this is quite impressive and very inspiring. Really awesome work! Thanks!
Oct 4, 2010. 7:48 AMtomx63 says:
Yeah man. Thanks for the offer. I'll almost certainly take you up on that. I want to use this idea to turn on a light for some pre-determined amount of time. Originally I thought PIR motion detector, but I live close to a wooded area and I don't want the light coming on every time some critter gets too close. So the laser is an awesome idea.
Just curious... had you given any thought to also making the alarm unit work off of a renewable energy source?
May 19, 2010. 8:15 AMDhinesh kumar says:
        My hearty congratulations for you. It is a simple but effective piece of work. I really appreciate that. But, Does it really works...? I mean, Is it possible to connect the BASE of the transistor directly to 9V battery supply through just a 120 ohm resister....?
        And more over, how can a transistor be in ON position, if its collector terminals are OPEN...? You said that the LED keeps the transistor ON. But I really couldn't get the logic in it... Please can you explain me that.....? I am eagerly waiting for your reply....! Please.........
May 19, 2010. 11:32 AMbenzy4iva says:
hi rev,its me again,i have now got the ldr and alarm system(that is i have fixed the relay problem) to be working as it is but my problem again is that the alarm doesnt stay on when the laser is intruded and to make the alarm to stay on you only need to stand in the way of the laser for the number of time you want it to stay on...which i believe thats not how it supposed to work..please help me out.asap
May 5, 2010. 3:44 AMbenzy4iva says:
hi rev,i need some help here,is the led in the ldr unit suppose to go off when i ditch in the coils of the relay...and also am getting the alarm to stay on even when i have not placed the relay yet..pls help asap..
Apr 30, 2010. 12:27 PMbenzy4iva says:
i have got the led on the alarm part to light when i touch the two contacts....my only difficulty now is the choice of relay since icant get that small amp one here....also i wanna know how you connected the relay....
Apr 29, 2010. 1:58 PMbenzy4iva says:
thanks rev ..i got the ldr sorted today..am now lookin forward to sort the relay and alrm unit..thanx once more
Apr 28, 2010. 8:08 AMbenzy4iva says:
yes am using a breadboard,my project supervisor asked me to do the same thing,(that is switching the position of the ldr and the variable resistor) and i did but what i had was the led light stays on whether i cup the ldr or shine light on it...so pls help me out here..also can u give me the exact value and specs of the reed relay you used and also am in Ghana ..west africa...since my supervisor has no time for me i have chosen you as my supervisor...
1-40 of 143next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:revhead
Love cars, especially late 60's and early 70's American and Australian muscle cars!! I like to make things with my hands no matter what it is, and I love pulling things apart just to see how they work...
more »
