The inspiration for this project came from Kipkay who posted a similar version (PROTECT YOUR HOME WITH LASER BEAMS) After looking at the comments from his instructable, I found that many people where having trouble getting it to work and thought there were some limitations to it, so here I am, posting my version of the laser beam alarm system which I built for my year 12 final in Systems Engineering. (Which made it to the short listings for the TOP DESIGNS EXEBITION.)
Once your finished looking, please give it an honest rating, thank you!
My version is different in the following ways; I have a solar panel to recharge the battery which powers the laser, a current regulator to control current flow to the battery, a different LDR (Light Dependent Resistor) circuit, and a relay circuit so that the alarm stays on once the laser beam is broken.
Remove these ads by
Signing UpStep 1: Parts That You Will Need
Laser and rechargeable battery unit:- Solar Cell capable of anywhere between 6-12 Volts
- A Laser pointer which you can pull apart (I used a cheapo red one but it would be really cool if you had the money for a green one)
- LM317T current regulator chip
- Appropriate resistor for LM317T (will be explained later)
- A 3 Volt rechargeable Battery (I got mine from an old cordless phone)(the battery doesnt need to be three volts, that just what my laser needed, choose a battery that is appropriate to your laser)
- Some switches
- Soldering equipment
- Adjustable flexi arm for aiming the laser (optional but worth it)
- Hot Glue
- Shrink Wrap
- Small Project Box
- Crimp Connector
LDR and Alarm unit:- LDR
- 10K (10,000 Ohms), Variable Resistor
- 10K (10,000 Ohms), resistor
- NPN transistor (I used a 2N3904 type but any should work)
- LED (I used Green)
- 510 Ohm resistor
- A Small Reed Relay (I used a 5 Volt DC one)
- 2K2 (2,200 Ohm) resistor
- 120 Ohm resistor
- Buzzer 6-12 Volts will work
- A Second Transistor ( thank you to collard41 who clarified that this is infact a NPN transistor)
- Some Switches
- Two 9 volt batteries
It looks like a lot and seems hard but it really isnt, I will guide you step by step and as best I can.
Visit Our Store »
Go Pro Today »
Over all I reckon you've done an excellent job. But as I said earlier, unless you either have no alternative, or you are a whiz on creating regulated power step down transformers, then DO NOT screw with your household AC circuit by building a perfectly good fire source. It's just not worth it, and your insurance company will probably throw a fit. SLA's even small level Amp Hour batteries will do the job and if your solar panel provides enough power to charge the battery to full capacity during day light, and the battery has a high enough rating to cope with running the laser constantly then you will have accomplished the job. One thing you could do is utilise some fast pulse code modulation on the laser, and providing a delay circuit on the receiving LDR so you save an amount of battery power but do not trip the circuit. During the off cycle that the PCM creates. Food for thought, but a brilliant first crack, and I am very envious of your attempt. I made a similar circuit back around 1985 when I programmed my ATARI 800XL to do the very same job utilising some BASIC programming and a cannibalised Infra Red remote control.
i know its been a long time
i have finally completed the project
its so cool
ok my question is
did you use a special software to design the circuits
if you have please tell me about it
cheers
akinich
will do!
about the transistors, they should be the same both are NPN. if you google seach the code on the transistor (e.g 2N3904) you will be able to find a circuit diagram of that type of transistor. a NPN will have an arrow that points out (picture of circuit diagram) this is also a good way to find out wich pin is the emmitor. make sure you have the transistors in the right way. on most the middle pin is the BASE, the pin with the arrow on it (mentioned above) is the EMMITOR, and the remaining one is the COLLECTOR.
Pls reply as ASAP,,, tnx in advance
http://robokits.co.in/shop/index.php?main_page=product_info&cPath=14_61&products_id=204
or this one ?
you can easily adapt my design to run off 12v mains power (using an adaptor) and just change the resistor values
My Led Goes on when there is light,and off when dark.
I will try to get it right,but do u have any suggestions so that I can modify something else and live with this shortcoming of mine ?
i think i put a note about this near the section with the diagram of the LDR circuit.
I am not able to think of anything that will invert this effect.
What if I use any Hex Inverter Gate like maybe the 7404 and inverter the 1-0 ?
Any help?
Good job as a first major project though.
Chris
^_^
-Jenriel (philippines)
Student"
My shop vendor says he cannot sell components without proper name,the police has prevented them from doing so.
Also I have included pictures of my final design...
I also used a separate sensor unit for added ease of laser positioning.
thanks for the comment and feedback,
cheers
Also, do you think If i took a regular 9 volt ac adapter and hooked up to the battery clips (both at the same time, in a parallels circuit, that it would work, b/c my batteries always runnout after a couple of hours of running, or couple minute of alarm activation.
I will post it up when finished.
u can tell its my first large-ish project cos the circuit board is just a mess of wires haha. if i were to make it again i would make it alot neater and clean looking. thanks for the positive comment!! ifyou end up making this and need a hand just shoot me a message and il do my best to help.
Just curious... had you given any thought to also making the alarm unit work off of a renewable energy source?
And more over, how can a transistor be in ON position, if its collector terminals are OPEN...? You said that the LED keeps the transistor ON. But I really couldn't get the logic in it... Please can you explain me that.....? I am eagerly waiting for your reply....! Please.........
Cheers!
also remember that the relay is what touches the two contacts together from the alarm circuit, so when the laser is removed the relay turns off which opens the contacts but this should still leave the alarm on, but it doesn’t so there is a problem with the alarm circuit. Instead of fiddling around with shining the laser on the LDR to test it, put the circuit back to the breadboard and test it by just getting two pieces of wire for the contacts and touch them together, when you touch the contacts together and the alarm turns on thats good, but when you open the contacts and the alarm stays on then it works perfectly and you can plug in the relay and the rest of the circuit.
if u need any more help im happy to help!
not too sure about whaat your saying with the relay "ditch in the coils..."??
you have a very big problem if the alarm is going off even if you haven’t touched the two contacts together, the alarm isnt meant to sound until the contacts are touched, if this is your problem it has something to do with the transistor, try switching it around or getting a new one!
let me know if you need any help,
cheers!!
if the LED still stays lit then you have a problem with the transiter you are useing, make sure it is NPN, try turning it around, it might be broken so replace it...
if this doesnt work, take a picture of the bread board with all the connections on it and il see if its wiered up correctly.
also what power supply are you using, is it a 9v battery? also try useing the optional second 10K resister (normal one, non-variable) i didnt use it and it worked fine but you may find that you might need to.
cheers
oh and the reed relay that i used is a 5v DC low amp type, it looks like a small cylender with thin metal legs sticking out, you can see it in this link, mine was green: http://www.instructables.com/file/FN5A2OSFQ6DX8IY/
you can also see my 10K variable resister in the above link (small blue and whight box with a white screw on top, does yours look like mine??
cheers!
I’m not sure about your relay, did a quick Google search and it needs at least 5v and 1A to trigger, if you r getting these values and above in your circuit then it will work, large mechanical relays like your needs more power compared to small reed relays...
with the alarm circuit on its own, so...when you touched the two contacts the LED came on??? If it did then well done, that circuit works!!! (Make sure that the LED stays on after you open the contacts, this is the whole point of this circuit!) with the alarm not turning on, make sure that it is the right polarity (+,-), make sure it is connected in parallel with the LED (very important) what type of alarm is it, it might be too powerful for the circuit/broken/if it’s a piezo buzzer it might not work/make sure it is a DC buzzer not an AC buzzer.
I hope this info helps you out, if you are still having problems feel free to message me, I’m happy to help,
cheers!!
let me know how u go with it!
cheers!!
People of Instructubles and Revhead! Please Help!
I'm building your circuit as my science project and am having some trouble.
I am able to get the ldr part of the circuit to work, and the buzzer ciircuit if I move the transistor (NPN the same one as in the ldr) up one so that the alarm activates only if the two conductors are connected together, becuase if I wire to your schematic, the alarm won't turn off. but when I connect the relay, the circuit wont work.
I really need your help becuase I need to be done by friday (4/23/10), so I need help asap!
I am using 2% tollerance resistors at 1/4 watt.
The relay is a reed rlay rated at .5a at 125vac with a coil resistance of 250 ohms and a nominal current of 20mA.
Please help ASAP!
I am acutually using a SPST - 12VDC Reed Relay Rated at .5 A at 125VAC with a coil resistance of 1050 ohms, and a nominal current of 11 mA!
I fixed the relay issue but am unable to get the alarm to stay on when someone crosses the beam.
Note:
I have made one modification to the schematic that revhead gave me, i wired the npn transistor differently because the alarm wouldn't turn off when i built just the alarm portion.
PLEASE HELP!!!!!!!!!
the only thing that I discovered from experience from messing around with this circuit is to leave the LED's in the circuit, DO NOT remove them because they act as diodes keeping the current flow in 1 direction.
The other problem is probably the transistor (faulty/damaged I went through 3 trying to get mine to work) or your power supply is two low/high for the components you are using
very sorry if I couldn’t help in time, let me know how your science project goes,
cheers
thanks for the reply and for the advice, but i already got it to work cuz i just added another relay and changed the transistor position, there wasn't any issue with the transistor, just that your schematics for the buzzer part of the alarm system don't really make sense, because when i hooked it up according to your schematics, the buzzer wouldn't shut off because it was a complete circuit, i will later post the schematic i made for my "redesign" that works for me.
but thanks anyway.
Cheers!
Yes, by putting a electrolytic capacitor in paralell with the buzzer
can you please tell us how to connect the 2 schematics you draw 1 is with LRD and 1 is with buzzer or alarm on this part i'm so verry confused. thank's
and the relay pins parallel to the led in the lrd circuit
another question
can the transistor in the alarm circuit be the same one as the one in the LDR circuit because i got another one of that? and it is not working properly
thanks akinich
always put female on live coponents (solar panel)
and male conectors on power needing coponents (charger)
but everyone make fail in their life me too i did some fail XD
what I suggest is you do is scrap everything after the relay from my circuit and use the relay as your switch, just replace the nerf dart gun switch with the relay. If your nerf gun doesn’t have a power supply then you would need to connect a power supply in series with the relay and the nerf gun. Hope this helps. If you need any help or get confused just message me and I’ll try to help.
http://www.instructables.com/id/LASER-Tripped-Wire-Alarm-Circuit/
I think most 1 mW red lasers run on 3-3.5 volts. If you added more voltage you could make the beam brighter but it will probably break the laser very quickly. You can however adjust the focus of the laser to make the dot smaller, or more spread out. If you look at the front of the laser (were the beam comes out) there will be a small groove in it, so that you can put a small screw driver in there. When you twist it, it will adjust the beam. This should allow you to have some control over the laser dot.
You could use any laser you like, the more powerful/brighter the better. In Australia the highest laser rating that is legal is 5mW. This restriction also applies to green lasers which seem to be very popular. If you are interested in online buying you can visit this web site:
http://www.dealextreme.com/details.dx/sku.91
This is where I brought a cheap green laser. It isn’t the best quality but it is a huge improvement to the red laser pointer which you and I used.
Hope this helps. If you have any questions I’m happy to help you out.
CHEERS!!
if you are interested in motor control you should check out his Instructable for motor speed control:
http://www.instructables.com/id/Simple-and-dirty-Pulse-Width-Modulation-PWM-Wi/
I am currently making a Laser Spirograph using three of these PMW (Pulse Width Modulation) motor control circuits. it is very easy to follow and works great. I'm new with motors as well and making this PWM circuit has taught me alot, and I'm sure you will also learn alot.
Cheers!!
