The inspiration for this project came from Kipkay who posted a similar version (PROTECT YOUR HOME WITH LASER BEAMS) After looking at the comments from his instructable, I found that many people where having trouble getting it to work and thought there were some limitations to it, so here I am, posting my version of the laser beam alarm system which I built for my year 12 final in Systems Engineering. (Which made it to the short listings for the TOP DESIGNS EXEBITION.)
Once your finished looking, please give it an honest rating, thank you!
My version is different in the following ways; I have a solar panel to recharge the battery which powers the laser, a current regulator to control current flow to the battery, a different LDR (Light Dependent Resistor) circuit, and a relay circuit so that the alarm stays on once the laser beam is broken.
Remove these ads by
Signing UpStep 1Parts That You Will Need
Laser and rechargeable battery unit:- Solar Cell capable of anywhere between 6-12 Volts
- A Laser pointer which you can pull apart (I used a cheapo red one but it would be really cool if you had the money for a green one)
- LM317T current regulator chip
- Appropriate resistor for LM317T (will be explained later)
- A 3 Volt rechargeable Battery (I got mine from an old cordless phone)(the battery doesnt need to be three volts, that just what my laser needed, choose a battery that is appropriate to your laser)
- Some switches
- Soldering equipment
- Adjustable flexi arm for aiming the laser (optional but worth it)
- Hot Glue
- Shrink Wrap
- Small Project Box
- Crimp Connector
LDR and Alarm unit:- LDR
- 10K (10,000 Ohms), Variable Resistor
- 10K (10,000 Ohms), resistor
- NPN transistor (I used a 2N3904 type but any should work)
- LED (I used Green)
- 510 Ohm resistor
- A Small Reed Relay (I used a 5 Volt DC one)
- 2K2 (2,200 Ohm) resistor
- 120 Ohm resistor
- Buzzer 6-12 Volts will work
- A Second Transistor ( thank you to collard41 who clarified that this is infact a NPN transistor)
- Some Switches
- Two 9 volt batteries
It looks like a lot and seems hard but it really isnt, I will guide you step by step and as best I can.
i know its been a long time
i have finally completed the project
its so cool
ok my question is
did you use a special software to design the circuits
if you have please tell me about it
cheers
akinich
will do!
about the transistors, they should be the same both are NPN. if you google seach the code on the transistor (e.g 2N3904) you will be able to find a circuit diagram of that type of transistor. a NPN will have an arrow that points out (picture of circuit diagram) this is also a good way to find out wich pin is the emmitor. make sure you have the transistors in the right way. on most the middle pin is the BASE, the pin with the arrow on it (mentioned above) is the EMMITOR, and the remaining one is the COLLECTOR.
Pls reply as ASAP,,, tnx in advance
http://robokits.co.in/shop/index.php?main_page=product_info&cPath=14_61&products_id=204
or this one ?
you can easily adapt my design to run off 12v mains power (using an adaptor) and just change the resistor values
My Led Goes on when there is light,and off when dark.
I will try to get it right,but do u have any suggestions so that I can modify something else and live with this shortcoming of mine ?
i think i put a note about this near the section with the diagram of the LDR circuit.
I am not able to think of anything that will invert this effect.
What if I use any Hex Inverter Gate like maybe the 7404 and inverter the 1-0 ?
Any help?
Good job as a first major project though.
Chris
^_^
-Jenriel (philippines)
Student"
My shop vendor says he cannot sell components without proper name,the police has prevented them from doing so.
Also I have included pictures of my final design...
I also used a separate sensor unit for added ease of laser positioning.
thanks for the comment and feedback,
cheers
Also, do you think If i took a regular 9 volt ac adapter and hooked up to the battery clips (both at the same time, in a parallels circuit, that it would work, b/c my batteries always runnout after a couple of hours of running, or couple minute of alarm activation.
I will post it up when finished.
u can tell its my first large-ish project cos the circuit board is just a mess of wires haha. if i were to make it again i would make it alot neater and clean looking. thanks for the positive comment!! ifyou end up making this and need a hand just shoot me a message and il do my best to help.
Just curious... had you given any thought to also making the alarm unit work off of a renewable energy source?
And more over, how can a transistor be in ON position, if its collector terminals are OPEN...? You said that the LED keeps the transistor ON. But I really couldn't get the logic in it... Please can you explain me that.....? I am eagerly waiting for your reply....! Please.........
Cheers!
also remember that the relay is what touches the two contacts together from the alarm circuit, so when the laser is removed the relay turns off which opens the contacts but this should still leave the alarm on, but it doesn’t so there is a problem with the alarm circuit. Instead of fiddling around with shining the laser on the LDR to test it, put the circuit back to the breadboard and test it by just getting two pieces of wire for the contacts and touch them together, when you touch the contacts together and the alarm turns on thats good, but when you open the contacts and the alarm stays on then it works perfectly and you can plug in the relay and the rest of the circuit.
if u need any more help im happy to help!
not too sure about whaat your saying with the relay "ditch in the coils..."??
you have a very big problem if the alarm is going off even if you haven’t touched the two contacts together, the alarm isnt meant to sound until the contacts are touched, if this is your problem it has something to do with the transistor, try switching it around or getting a new one!
let me know if you need any help,
cheers!!
