Step 3Choosing the Correct Resistor to Work with your LM317T
Ok, a rechargeable battery hooked up to a solar panel will always recharge as long as the solar panel is producing more voltage than what the value of the battery is. For example my 3.6 Volt battery will recharge as long as the voltage is 4 volts and above. My solar panel produced a healthy 10 Volts so that is good; I dont need to worry about not having enough voltage. What I do need to be careful about is current.
Lots of current will charge the battery very quickly but will cause overheating and will kill your battery quickly. Too little current and your battery will charge extremely slow or not at all.
A general rule of thumb is that the optimum flow of current that you should try to maintain is 10% of the batteries current output. For example my battery was 850mA/H (850 milliamps per hour). So, 10% of 850 is...850/10=85. In this case the magic number is 85mA. We want our solar panel to produce an output of no more than 85mA per hour. To do this we need to choose a resistor which will work with the LM317T chip that will give us that control level. To do that we need this table:
Look at the fourth image for the table. You may need to view it at full size to see it clearly.
What you do is find your magic 10% current value and match it up with the closest current value on the table (bottom row) then look at the value above it and that will give you a resistor value. It is this resistor value that will give you the current flow that you need. In my case the closest value on the table that matched up with mine was 83.3mA. Above that is 15 Ohms. That is how I obtained the value for my resistor. You may get the same or you may get a different one, it all depends on the battery that you use. If you need any help with this just message me or leave a comment and I will reply asap.
8
comments
Add Comment
Add Comment
