3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Beam Alarm System with Rechargeable Battery for Laser
Step 8How I Put Together The Laser Unit
  • last photo ←
This is how I assembled and presented my laser unit. I found that just sticking the laser on the box made it very difficult to aim it into the LDR of the second unit. So I pulled apart an old torch that I had which used a flexi arm so that you can aim the light around corners. I salvaged the flexi arm and ran all the wires to the laser down the flexi tube, hot glued the laser on the end of the arm, covered the laser in shrink wrap to hide the hot glue, and mounted it on the box.
I think it works much better this way and it adds another degree of advancement. I also used a push on/off switch for the laser; some more switches to charge the laser, and used some crimp connector so that I could make my own sockets for the solar panel. This enabled me to remove the solar panel when I didnt need it any more.
Oh and one last note about this laser unit. Because we are making the solar panel charge the battery with 10% of the batteries capacity, it will take 10 hours to charge from dead in full sun. Which is pretty good?
7 comments
Jul 29, 2011. 11:28 AMcknudstrup says:
One thing you may want to include is a Diode in the Charging circuit from the Solar panel so it does not rob power from the battery at night unless your solr panel already has a diode built into it. Also you really only need one switch from the solar panel tothe circuit on either the positive or negative circuit as either one will cut the power from the solar panel to the rest of the circuit. Its not wrong the way you have it just overly redundant.
Good job as a first major project though.
Chris
Oct 1, 2010. 1:46 PMtomx63 says:
Dude, I've just started studying electronics and I have to say that this is quite impressive and very inspiring. Really awesome work! Thanks!
Oct 4, 2010. 7:48 AMtomx63 says:
Yeah man. Thanks for the offer. I'll almost certainly take you up on that. I want to use this idea to turn on a light for some pre-determined amount of time. Originally I thought PIR motion detector, but I live close to a wooded area and I don't want the light coming on every time some critter gets too close. So the laser is an awesome idea.
Just curious... had you given any thought to also making the alarm unit work off of a renewable energy source?
Nov 24, 2009. 6:37 PMgarrys newman says:
fail!!!!!!!!!!!
always put female on live coponents (solar panel)
and male conectors on power needing coponents (charger)
but everyone make fail in their life   me too i did some fail XD
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:revhead
Love cars, especially late 60's and early 70's American and Australian muscle cars!! I like to make things with my hands no matter what it is, and I love pulling things apart just to see how they work...
more »
