Introduction: Laser Cut Crate
Picture of Laser Cut Crate
Here is a guide in how to make a weathered looking wooden crate on a laser cutter. The good thing about it, is that it has a more solid bottom, than most lasercut boxes that use box joints.
Step 1: Cut and Glue
Picture of Cut and Glue
Using the lasercutter, cut the parts from the PDF or Illustrator file. Then glue it together.
Step 2: Clamp and Drye
Picture of Clamp and Drye
Clamp it together and then let it set, afterwards it looks like the image om the right.
Step 3: Weather Using a Blowtorch
Picture of Weather Using a Blowtorch
By burning it with a blowtorch it will get a weathered look, afterwards i lightly sanded away the charred bits.
Step 4: Coating It With Bees Wax
Picture of Coating It With Bees Wax
By coating it with bees wax, the natural colors of the wood really pops. It also makes it feel less drye.
Step 5: Clean
Picture of Clean
After coating it, i thoroughly cleaned it with a papertowel.
I like the weathered look you got using the blow torch. Nice job!
Thanks :D
jmmccarty (author)2014-03-10
Looks nice, I like the finish as well. Did you use 1/4in (5mm) plywood?
Da3da1u5 (author)jmmccarty2014-03-11
I used 3.4 mm plywood :)
Da3da1u5 (author)Da3da1u52014-03-11
Well that's what my caliper said :)
About This Instructable
1,447views
16favorites
License:
More by Da3da1u5:Laser Cut Pivoting BoxLaser Cut Cryptex - Puzzle BoxGame of Thrones Beer Coasters
Add instructable to:
