3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Cut Magnetic Poetry
Here is a brief overview on how to use scrap magnet sheeting, a laser cutter and Corel draw to make magnetic poetry.
Magnet sheeting may be made of PVC and cutting it in this manner may produce small amounts of extremely toxic chlorine gas. I am not sure. You do this at your own risk.
Step 1Go make your word file.
Measure your scrap magnetic sheeting.
Open Corel Draw and make a text block the size of your scrap magnetic sheeting. My scrap sheeting was 3.5" x 24" and as such I wrote enough semi-random words to fill that space.
The text should be of transparent fill with a 1 pixel black outline.
For a better example download the attached work-file below.
16 comments
Feb 25, 2008. 5:11 AMstasterisk says:
Man....
so this is the first thing I tried to do with a laser cutter, but instead of just doing it, I called up a bunch of companies and read a lot of MSDS-es.
Yeah, they said, the magnetic sheet is fine, but don't touch that vinyl. The PVC quickly lets out all the 'C'. Plus, it should be pretty easy to use a vinyl cutter for this? Or waterjet them instead like I did?
Aug 14, 2009. 8:41 PMcowe says:
if you're ventilating well, the ONLY things that are toxic to the laser head are vinyl and pvc. i cut & etch many different kinds of wood/paper/acrylic/plastic/glass/food/etc. pretty much daily, and all's well, with a decent (well-maintained) filtration system. :)
Mar 24, 2009. 6:46 AMThe_Roadie says:
For those that want a slightly safer way to create something similar, try these magnetic sheets from Avery:
http://www.avery.com/avery/en_us/Products/Crafts-%26-Scrapbooking/Magnet-Sheets/Magnet-Sheets_03270.htm?N=0&Ns=&refchannel=c042fd03ab30a110VgnVCM1000002118140aRCRD
Not a cool as laser cut, but you can print in color.
Mar 17, 2009. 3:39 PMMegaMaker says:
If you have a poem like this that is 5-7 lines (each line is 4 words), using 10 verbs, 8 nouns, and some other words that I can't remember, you will have a French Poem known as a Da Da poem. Although the words are usally ramdomly found in newspapets, magazines, ect. Lol.
Feb 25, 2008. 5:13 AMstasterisk says:
Why didn't you use the lasercutter to cut up the words?
Aug 13, 2007. 2:24 AMSabina says:
Over at luminocode.com/magnets you can make and test magnet sets to see how they work out before you actually start making them.
Apr 10, 2007. 8:53 PMWeissensteinburg says:
I really want a laser cutter...
Apr 10, 2007. 11:02 PMFrenchCrawler says:
I'd be happy even if I could only afford this
Apr 10, 2007. 9:04 PMWeissensteinburg says:
Think santa might get generous this year?
Apr 10, 2007. 9:36 PMWeissensteinburg says:
What about Hanukkah harry AND Santa? They could split the tab. I really have no idea where to find someone around here with one...and the age thing doesn't help either..15 in just about 2 more months
Apr 11, 2007. 5:47 PMT3h_Muffinator says:
They could also buy all the lotto tickets with their magical powers... That way they're guaranteed to win!
Apr 11, 2007. 3:02 PMjoejoerowley says:
Maybe a long term CD.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2350
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
