(By the way? Do you think this is cool? Do you think huge LASERS are cool? Check out this contest that instructables is running right now: http://www.instructables.com/contest/hurricanelasers/ -- Grand prize is a laser exactly like the one we used on this project! My favorite machine in the lab! <3 Enter that contest!)
The effect is really cool, like a lace, except part of the shirt itself. We found that a 5% polyester/95% cotton blend worked best. The polyester seems to melt at the edges of the cuts, sealing them against fraying.
Cotton works as well, but care has to be taken not to fray the edges of the cuts.
See: lace.dxf if you want to cut one of these for yourself!
lace.dxf293 KBStep 1: Gather your materials
We also grabbed a piece of cardboard out of the scrap heap to keep the shirt rigid while we cut it.
Step 2: Cover the collar with something
Our first thought was plywood. The problem with this was that our laser has a "whisker" for zeroing the z-axis. Unfortunately, the whisker travels really close to the material while cutting, and this meant that it would catch on the plywood. NO GOOD!
Instead we decided to cover it with LOTS of tape (5 layers) and hope it worked.
It did. If your laser has room for it, do plywood, otherwise tape will work.
(You can see the tape in step 4. We forgot to take a photo of it, OOPS! In it's place, please enjoy this photo of me operating a bandsaw. This was for the piece of plywood we didn't end up using.)
Step 3: Tape the edges of the shirt
Step 4: Load the laser cutter
Our settings were:
Speed: 50mm/s
Power: 16watts
This seemed to work really well! Our 5 layers of tape also protected the collar! Hooray!
Step 5: The result
Oops! This was because we started the cut at much too high of a power!
Visit Our Store »
Go Pro Today »
Would you contact me at lori.venturi@gmail.com
I need to make some object with laser cut and want to have an estimation
thanks
Loredana
hope this make sense,,
trying to get as much use from the laser as possible, the cutouts will also have their ends melted..
you guys made a fantastic 't'
Beautiful project!
To keep the Cotton from raveling would take something like Fray-Chek, a liquid that fuses the edge. Try not to use too much as it can show. Alternatively, you can outline the cuts with 3D fabric paint, which will also effectively seal the edge.
Denim: The traditional pigment for Denim is indigo-based and only lays on top of the fiber rather than soaking INTO the fiber like most dyes - this is the reason for the lovely fade you get on denim in all the wear spots because the dye is literally rubbed off the fabric. When you blast it with the laser just right you remove the dye molecules and leave the cotton (or most of it), which leaves the fabric 'tattoo'.
Besides the T-shirt fabrics, most quality silks will fuse when laser cut, you can remove the pile from velvet but leave the background fabric, and you can do the same with polyester Moleskin and many faux suedes.
http://www.flickr.com/photos/dhawktx/4045062595/in/set-72157623905104905/
and the same design on a soft leather (really too soft, it drew up in places due to the heat of the laser)
I had not thought of velvet before... nice idea... it should work... I'll have to try that!
Thanks for the tip!
Jerry
We're also not cutting any metal in this, just fabric o.O
Therefore, aluminum foil can be shaped and cut with scissors to become a block for any area you do not want cut. I use this method when I engrave on a laptop computer or an iPOD to cover any areas that I don't want to chance damage to.
You said: "Towards the top right, unfortunately, we cut the collar a bit :(."
This was to prevent that error.
You said: "Instead we decided to cover it with LOTS of tape (5 layers) and hope it worked."
I was offering a proven method that works every time... to assist you.
Also... I re-read the Instructable... but I didn't see where you mentioned the use of the Stitch Witchery to bond the fibers to prevent it from coming apart. If you did mention that... sorry... i missed it.
Jerry
Btw, to anybody reading these comments, I'd be really wary of putting aluminum foil in the laser. "Not running at 100%" is a meaningless safety precaution; 80% of a 150watt tube and 80% of a 40watt tube are not the same thing.
#3 is a great tip, though. We'll have to try that this weekend!
Rad design, I love it!
I guess lasering on cloth is actually really common in production. You can stack many layers of cloth on top of each other, then laser cut them instead of using shears.
We did a t-shirt during a laser class/experiment last year. I dont know the material but we put the t on a sheet of melamine board and cut w/75%speed 40% power 1200Hz on an 40watt Epilog Helix. Results were pretty good ...
http://www.flickr.com/photos/mauimakers/6044894766/in/set-72157627312292063/
Source diagram for that shirt was Garrett Lisi's E8 Theory of Everything (http://garrettlisi.com/)
Our is an "XYZ Technology" "Exlas" or something like that. It's a commonly re-branded machine out of China.
It's an 80watt tube, and I cut it at 16watts, meaning 20% power. If you have a 40watt, that would be 40% power.
