Laser Cut Soldering Air Purifier
Introduction: Laser Cut Soldering Air Purifier
I have always wanted to have a small air purifier around when I am soldering electronics.
When I found a guide from Make magazine that showed how to make a portable fume extractor I knew that I wanted to build it for myself!
However I did not like the tin case. I do however have access to a lasercutter. And therefore I wanted to make an acrylic case using the cutter. I found the closing mechanism and hinges from Adafruits Raspberry Pi case appealing and therefore I have used those to secure the front. Links to both the guide from Make and Adafruits Pi case can be found below.
I have later made a workshop where we build this and wanted a guide to use in the workshop. This instructable is made for use in that workshop.
This instructable is VERY MUCH a work in progress, as I will try to update it every time I work on a workshop. So if you find any errors or have any idears for improvements let me know.
Make Magazine guide:
Adafruit Pi case:
Step 1: Tools and Materials
For this project you will need:
1x 4 x 4 cm fan:
2x metal grills:
1x barrel plug:
2x 9v battery clip:
1x Variable step down:
1x slide switch:
Some carbon filter (we will cut this into smaller pieces later):
1x 3mm cast acrylic sheet (minimum 16 x 21 cm)
4x 3mm x 10 mm bolt (I used 16 mm instead but 10 would be better)
4x 3mm x 16 mm bolt (I used 230 here but 10 would be better)
8x 3mm nut
Wire in different colors
Shrinking tube or insolating tape
Hot glue or acrylic glue
Nail polish
Stanley Knife
Access to a lasercutter
Soldering Iron
Hot glue gun
Step 2: Lasercutting the Parts
Cut the acrylic sheet into the pieces for the case using a laser cutter
I have included an illustrator file containing the template for the case.
Because this has been changed so many times there are some problems with the case, like small gaps and skewnesses. Hopefully I will find the time, sometimes in the near future, to correct this. In the meantime if you do any corrections please consider sending me the changed template.
Step 3: Add the Barrel Plug and Slide Switch
Add the barrel plug and the slide switch into the different holes. Use pliers if necessary.
Remember to solder the wires onto the switch so it fits with the on off markings in the acrylic. The correct position of the wires can be seen in the pictures.
After this solder wires onto the slider and the switch as shown in the pictures. I have used only black wire for the switch as this will later be used to complete the ground connection.
Step 4: Assembly and Gluing the Parts Together
Assemble the parts as shown in the pictures. Starting from the back, adding the bottom, then the partitioning walls on the inside and, as the last piece, the top with the slider.
It might be a good idea to run the wires for the battery clips through the small holes in the inside walls before you glue the parts together. It makes the whole assembly a lot easier
Glue the parts together from the inside using either a special glue made for acrylic or hot glue. The choice of glue depends on the transparency of your acrylic. If the acrylic is transparent the hot glue will be very obvious.
As my version is made from non transparent acrylic I ended up just using hot glue. This also alows the case to dry faster.
If you use hot glue a tool for smearing out the glue comes in handy. I used the bottom part of a table spoon for this. Be aware that there is not much space for the glue, so try and make the lines of glues as thin as possible.
Step 5: Assemble the Battery Clips
Put the battery clips in series by connecting the black wire from one of the clips with the red wire from the other. Tangle the wires around each other and complete the connection by covering the exposed area of both wires with solder.
Remember to cover the exposed part of the connection with shrinking tube or insulation tape.
Step 6: Connect the Battery Clips and the Barrel Plug and the Step Down Converter
Strip the remaining wires from the battery clips and the barrel plug.
Connect the wires from the barrel plug and the batteri clips in parallel to the step down converter. Remember to connect the black wires to minus and the red wires to plus.
Step 7: Set the Drop Down Converter
Please be very carefull and read the whole step before you continue. I have seen a lot of people breaking the step down because they get impatient and turns the screw to much.
As we have used a variable drop down converter we need to set the output to be stable at 12 v. If you want more suction you might consider setting the dropdown to above 12 v. However this will use more power so the batteries will die faster. Also it might not be good for the fan, so do this at your own risk :)
Start by connecting the battery clips to two 9v batteries. Put your probes from your multimeter on the output from the drop down. Use a screwdriver to turn the screw on the potentiometer on the drop down converter. BE VERY CAREFULL WHEN YOU DO THIS. IT MAY TAKE SOME TIME FROM YOU TURN THE SCREW TO THE VALKUE ON THE DISPLAY CHANGES.
Turn the screw until the display from the multimeter shows that the drop down delivers around 12v.
A helping hand from a friend is handy here.
Secure the screw with hot glue or nail polish.
I normally prefer nail polish as this makes your able to move the screw later again if you want to. But I did not have any nail polish around so i used hot glue instead.
Step 8: Connect Fan and Drop Down
Connect the red wire from the fan to the plus side of the output from the drop down converter. Solder the wire.
Connect one wire from the switch to the minus side of the drop down. Connect the other wire from the switch with the black wire from the fan.
Cover the whole drop down with shrinking tube.
Put the drop down and fan into the case as shown in the picture.
Step 9: Cut the Carbon Filter
Cut the carbon filter into squares that measure 40 x 40 mm
Step 10: Asssemble With Bolts
Put the nuts into the holes in the fan. Hold the fan grill in front of the case and put the long bolts through the grill and front into the nuts. Screw the bolts in completely using a screwdriver.
Secure the other grill to the back plate using the 4 short bolts and the remaining nuts
Step 11: Enjoy
Install the carbon filter by placing one square in the middle of the fan as shown in the picture
Enjoy tour finished soldering fan.
If you build this, or gets inspired by this to do another build, please consider to send me the pictures :)
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Duvall, Electronics other doesn't contain lead anymore. It's silver based.
    And I have taken a graduate-level course in industrial hygiene which covers filtration and air sampling. You would have to know the size of the particles being generated by the soldering iron to know what size filter would be appropriate. Given the small size, you would need a very small pool filter which would require quite a bit of suction power. Not sure this would even do the job. It likely just distribute the metal fumes throughout the room so you don't see it
    My voice recognition failed me. It should have typed electronic solder doesn't contain lead anymore. If you are soldering with lead-based solder, you need a professional filtration device, or something at least to remove the metal fumes from your work space. Like a hood, but I don't believe you're allowed to vent led directly into the air.
    If you work with lead soldier on a regular basis, you should be familiar with it. You should wash your hands after handling it. Should do it in an area where children don't have access because they are way more susceptible to lead toxicity. And the fumes will settle on surfaces.
    Lastly, why not get a good fitting niosh approved respirator that is rated N-99. Far more convenient and probably more effective for this
    Hello thank you for the input.
    Can you recommend any affordable filters that will handle this type of work?
    Well the project is made for a lab environment where the alternative is that the students (including me) dont use any air filtration at all. So the idea was to try and make our own. To get people using them they also need to be affordable and fancy.
    I'm not sure a respirator works for us, as it is not a lab environment in the sense of an electronics or engineering lab, but an electronic design lab. Design as in industrial design, or interaction design. So people there do other work than working on electronics. We cannot have everybody wearing masks around the building all the time.
    I have attached some images of my table last year. So you get a sence of which kind of lab I am talking about ;)
    When dealing with a neurotoxin such as lead, probably isn't good enough in my book. As I said, the potential presence of lead from soldier should be assessed by a certified industrial hygienist. And the temperature is high enough to melt the lead. There have to be some fumes produced from it.
    I'm not familiar with any adverse effects from flux, but it's possible. I would assume that it's an organic, therefore particle filtration would not be very efficient. Ventilation issues could be thoroughly assessed by a certified industrial hygienist.
    There are experts in the field of engineering known as industrial hygienists. I'm a position. I know that led is bad, and doesn't only affect those directly working with it. People take it home with them. People around the person producing lead fumes will inhale it. It's especially bad with pregnant women and children. Especially pregnant women who do not yet know that they are pregnant which is potentially every College female.
    If you are working with lead, someone at the University will be able to assess the situation and determine if there is a true Hazard to students. Using a hood like they use in chemistry Labs would decrease the exposure in the room , but may not be sufficient under OSHA regulations. Substituting a non lead solder takes care of the problem.
    I'm just afraid that using a filter of the type that you made we'll take this other smell out of the air, the organic component which is afsorbed by carbon filter, but will only spread the fumes (metal fumes) around the building.
    So to sum up, I'm not an expert in ventilation or filtration but industrial hygienist are. You are right to suspect that soldering may present a health hazard, if it contains LEAD. An industrial hygienist could help with your problem, as it is not unique to your lab. Lead is too serious to MacGyver a solution.
    verry nice indeed,i wil consider it to make it.
    Good looking case mate. How much suction are you getting? The quoted 4.2 cfm on that fan isn't that impressive.
    Well as I write i the guide you can give the fan more input than 12v :)
    If you set the drop down to 12v the filter needs to be within 10-15 cm from the soldering iron to suck all the fumes in.
    This is a very sleek design! More appealing than most cobbled together DIY devices. Considered using a wall plug to save on battery cost? (If you'd made a wall plug I would have likely asked about batteries.)
