Laser Cutter- CUTTING Bumblebee
1,759
25
19
Published
Introduction: Laser Cutter- CUTTING Bumblebee
About: Laser professor
Every kid want to a fun toy-Bumblebee is definitely the best choice!
Step 1: Required Items
Material:3mm plywood
Laser head:standerd head
Thunder laser used: Machine:Nova35 80watt
Step 2: Setting Parameters:
Processing Mode:Cutting
speed:45mm/s
Cutting power:55%
You can draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your machine.
Step 3: Start Cutting
Place the plywood on the work table of the machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Step 4: Assemble
When the machine is finished, take out the parts of Darth Vader Fighters and put them aside
Step 5: Finished the ​bumblebee
Show time
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    Fantastic project. Could you also send me the cut file(s).
    Thank you!
    19 Comments
    Awesome!! Could you please send me the cut file??
    awesome art. Could you please send the cut file?
    very nice work ^_^ ,
    But unfortunately, I couldn't find the .dxf file.
    I don't know how to upload the file, I uploaded it clearly, but I don't know why I couldn't find it, I can send it to you if you need it.
    Please send me a .dxf or .eps file too. If you can't upload it here, just publish this great bumblebee on thingiverse.com an add a link.
    Hi,thank you for your advise,I will try,I have sent the file for you,please check it,thank you.
    hi friend, can you sent me the cut files? thanks in advance
    Hi,thank you for your fancy,I have sent the file for you,please check it,thank you.
    Awesome design! I was also hoping for the cut files. Wondering if you posted it somewhere and I am just missing it. Thanks :)
    Hi,thank you for your fancy,because the Chinese New Year,we just came back to work,I have sent the file for you,please check it,thank you.
    Hi,thank you for your fancy,because the Chinese New Year,we just came back to work,sorry to late reply for you,I have sent the file for you by message,please download it.
    I couldn't find a downloadable laser cutting file?
    i have sent the link for you by private message,please check it
    This is beautiful! Did you design it? It would be cool if you uploaded the cut files to share with anyone that might want to duplicate it. Just a tip! :)
