Laser Engraved Playing Cards & Wooden Box
Published
Introduction: Laser Engraved Playing Cards & Wooden Box
About: Trotec Laser Canada provides laser engraving and laser cutting machines for processing a wide variety of materials. Cut, engrave and mark wood, paper, metal, acrylic, leather, stone, plastics and many more. ...
Here's an easy laser cutting project that can be made and then played with your friends!
By Aowlad Hossain and Thanushan Ravendiran
Step 1: Engraving the Cards
Using the illustrator template given (or your own template), set the art-board of your cards the same dimensions as the material you will be using, in this case 20" x 26". For the remaining cards make the art-board smaller and place them in the corner of the board (in Trotec's JobControl Software), to save material. Engrave the cards using 45 power and 100 speed, with 1000 PPI/Hz. For cutting, we used 40 power, 2 speed, 2000 PPI/Hz.
Materials Used: Black Pegasus Cover stock 260m 20x26
Step 2: Cutting the Cards
The key here is to know the right settings to set up the laser according to desired result, determined by power and speed of the laser. For example, if you wanted the designs of the cards to be darker, you could decrease speed or increase power. Also make sure the material is taped down to the bed of the laser, as an uneven surface will result in misshaped designs.
Step 3: Artwork File for the Box
Download the Illustrator (.ai) artwork file attached.
We make all the cut lines as red of 0.10 pt weight (or Hairline) and colour in the objects black for the engraving portion. All colours must be RGB.
The box is made of ¼" thick solid maple wood with the dimension of 3.5" x 2.5" x 1.5".
Step 4: Engraving and Cutting the Wooden Box
We used 55% power and 85% speed on a Trotec 100w Speedy 400 flexx laser with 500 ppi.
Step 5: Assembling the Box
Collect all pieces from the bed of machine, assemble as the interlocking windows match and glue it together.
    • Flowers Challenge
      Flowers Challenge
    • Make it Move Contest
    • Microcontroller Contest
    20 Comments
    Are the cards durable if we use that material? It kind of looks like they would rip after a few shuffles.
    Well they don't have the standard plastic coating other cards have so they won't last as long, but they don't rip up quickly they can last for some time.
    My school has a Enterprise class, where we make a business. I am using this idea. Thank you, Trotec!
    Awesome. I'll have to try this out on my schools laser cutter!
    Thank you for inspiration, will certainly try making cards on a laser!
    I think s/he means the cards but
    how much do the least expensive laser cutters cost?
    Are you in Canada? if so please emails us at sales@troteclaser.ca, we can give you a quote on our starter units.
