Laser Engraved Wood Sign
726
7
Published
Introduction: Laser Engraved Wood Sign
i've always wanted to put up a sign in the shed at home that says its my work shop so my mum would know that well that its my work shop
Step 1: Step 1: Materials
first i had to found wood to make the sign, so i looked around at work and found a wooden pallet i checked to see
if the pallet was good enough to use, which i was and stripped the pallet and ended up useing three peaces of
wood planks
Step 2: Step 2: Measuring
once i was satisfied with the planks of wood i measured
all the planks of wood the two peaces and the two supporting peaces
once i got the ruff measurements i marked it with a pensil ready to cut
Step 3: Step 3: Cutting
once i got the ruff measurements i jumped on the band saw and cut were i marked with the pensil and did that to both the supporting peaces and main peaces
after it was cut i went on the disc sander and made them exactly the right size
Step 4: Step 4: Nailing It Together
once all the peaces were messured and cut
i proseded with putting it together
i got eight peaces of nails, i put the two peaces of main planks and put the parallel to each other
and made sure the were exactly the same size
once they were i put the supporting peaces on the back of it
p put four on one peaces and for on the other so the peace once i did i got a puncture and pushed the nails in further and covered it with puddy
Step 5: Step 5: Sanding
once it was together i need to sane it
so i got a peaces of 80 sand paper and 180 than 200 just to make it smooth
Step 6: Step 6: Jack Plan
i noticed the face of the plank wasn't flat and that would make it hard to lazer cut the sign of so i got the jack plan
and shaved the face so it would became flat which took about 20 solid minutes
Step 7: Step 7: Dafont
i now needed to found the font that i wanted to put of my sign
so went to a wepsite call dafont
i looked under country western
i lookedn at all of than and than i found one the i liked
i saved the front and went of illustrator and wrote what i wanted to say
Step 8: Step 8: Illustrator
once i got the font that i wanted i
made up a template similar to the wooden sign
once i did that put my font on the template and made it so it lined up ready to laser cut onto the wooden sign
Step 9: Step 9: Laser Cutting
once the template ready to go
i got a thin peaces of wood and tested if it would come out okay
Step 10: Step 10: for Real
once i knew it was good to go and it wpuld come out good
i put my wooden sign in the laser cutter and waited
once it was done i lacerd it to make it look good
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    I need this exact sign for my workshop. Nicely done!!
    Awesome. A sign like this would make the perfect birthday present for friend of mine. Thanks or sharing the idea.
