loading
This machine is designed to make the laser engrave in wood and opaque plastic, having an Arduino and the GRBL as machine automation basis. The machine axis are just the X and Y axis, which move a laser with power 1w 445nm, and this article aims to provide everything you need to make, without waiving of mechanical and electronic knowledge.
With around 170 euros can make one.
My portuguese blog: www.logicamecatronica.com (like my blog on facebook please)
Step 1: Materials
You will need some material for your machine, in which I produced a list of required material. You will need tools.
Bill of materials:
1x Arduino Uno
1x Motor Jaw Shaft Coupler 5x5mm
1x Laser 1w 445nm (you can choose another, but i recommend max 3w on this cnc)
1x CNC Shield v3.1
1x Laser driver 12v
2x stepper motors Nema 17
1x power supply 12v 5A
1x laser diode 1w 445 nm 5.6mm
1x heatsink 5.6mm laser diode
3x GT2 Timing Pulleys 20 tooth 3m GT2 Timing belt
1x 12v fan cooler
1x 605ZZ ball bearing
12x Pulley Wheels Roller 695ZZ1x 5.6mm TO18 Laser Diode Case
2x stepper motor driver DRV8825
2x limit switches
1x switch power 3D printed pieces
1x plugin 230v cable
1x USB cable (in future we will use Bluetooth)
M5 Nuts
various length of M5 screwdrivers
flexible cable wire for electronics
1x pair of safety glasses Note: Never look directly into the laser, always wear protective glasses, link these glasses are cheap and effective, look directly at the laser runs the risk of blindness and cataracts. http://www.dragonlasers.com/Laser-Safety-Glasses....
On Rat rig:
5x 500mm V-SLOT 2040 – Black
8x OpenBuilds Universal L Brackets (Single)
1x OpenBuilds Tee Nuts (25 Pack)
5x OpenBuilds Tee Nut (1 Unit)
Step 2: Electronics
The wiring diagram of this machine is very simple, just follow the following schedule (the used resistance is 1k ohms)
Step 3: 3D Printed Pieces
Printed pieces in 3D, you'll need a 3D printer or else order from any website online already printed pieces.
http://www.thingiverse.com/thing:819755
This printed pieces are from another user of insctructables (tobias.sobkowiak)
Step 4: Mounting
With this photos you can mount easily your machine.
Step 5: Software
Necessary software (works only on Windows 7 or higher and requires framework 4), I used the CamBam (is paid) and 3DPsender, made by a developer who also made a laser engraver, call 3DPBurner.
GRBL hex file: https://drive.google.com/file/d/0B5Y1gEmSHMjMS1R4RUhsamV3QXc/view?usp=sharing
Xloader to flash Arduino: http://russemotto.com/xloader/XLoader.zip
how flash and setting of GRBL: https://github.com/grbl/grbl/wiki
3DP Burner Send: https://github.com/villamany/3dpBurner-sender/releases
3DP Burner image2code: https://github.com/villamany/3dpBurner-Image2Gcode/releases
CamBam settings: https://dl.dropboxusercontent.com/u/40132197/CamBam%20settings.docx
Step 6: Results
The expected results of the machine will be these.
Download all files here: https://dl.dropboxusercontent.com/u/40132197/M.%20laser.zip
Thank you and i hope that you enjoy :)
<p>Do i need a bigger resistance for a bigger laser? lets say a 10w laser?</p>
<p>Sir, can I use this part from this site:<br><br>5x 500mm V-SLOT 2040 &ndash; Black<br>http://openbuildspartstore.com/v-slot-linear-rail/<br><br>it's very expensive from rat rig</p>
Great work!! I can't figure out how to get my laser to turn on and off .. same set up as you .. grrr
<p>hi mister, can you send me a photo of your datasheet. I don't understand your links between the cnc board and the laser driver....how I can set the motors and the endstops? can you write me pls? cecchini.dan@gmail.com</p><p>thanks!!</p>
<p>Some time ago I built a Laser Engraver with this GearBest Kit.</p><p>Unfortunately I have not found a software acceptable and easy to use, so I wrote my own.</p><p>My software allows to load a picture and send it to the laser engraver quickly and easily.</p><p>My software is written in a generic way for almost all machines with standard GCode firmawre.</p><p>At the moment the software is WORK IN PROGRESS currently, in ALPHA testing.</p><p>As I needed to modulate the laser power (I have a 5500 mW one) I used GRBL firmware version 0.9 (other versions are ON / OFF, 0.9 is PWM)</p><p>Here the Robot Laser Project page : http://www.robot-eyes.com/en/RobotLaser/</p><p>I will update soon the page (for now very rough).</p><p>Please send an email at robotlaser@robot-eyes.com with your opinion, thanks.</p>
<p>hey, let's say i have a 3d printer and want to replace it's print-head with a laser diode. what i need beside the diode?</p>
<p>Here is my copy of the arduino laser engraver</p>
Love your laser.. have more pics or videos on what it can do? Where did you get the instructions or did you do it on your own? thanks..
Its based on the instructable these comments were posted to.<br>I dont have instructable detailed pictures but can email STL files if interested.<br>
<p>Can you please send them to bruno99sr@yahoo.com.br ?</p>
<p>send them please to bestbuy315@gmail.com</p>
<p>Well done! I recommend a dual motor to don't skip steps.</p>
<p>You can cut acrylic?</p>
<p>You can/t cut acrylic with a diode laser you will need a CO2 laser</p>
<p>hello, where did you buy your laser diode ? can you give me the website please ?</p><p>thank you , great job</p>
<p>hi awsome instuctable ,but i cant find the bearings you used ,can you share alink </p>
Hi<br>Can you explain the need of the resistor between the TTL lines? <br><br>Thanks!
<p>Do you mind to inform the stepper motor torque ? Congrats awesome project</p>
<p>Why is there a resistor between the positive and negative TTL lines? Won't that short it?</p>
With these parts maybe?
<p>Nope. You need a mirror system for the big laser. The fact that you ask means: stay away from that device. And don't forget to print a warning: &quot;Do not stare into the laser with the leftover eye!&quot;</p>
Lol, fair enough
<p>If I have cut acrylic what is the wattage of the laser(minium) should I use? If anyone could point out to reliable international shipping source(s),it will be really helpfull :)</p>
It used to cut cardboard?
Hi, could this be modified so that it could cut? Brilliant instructable! Thanks
Nice work!<br>Thanks to share.
<p>Thanks :)</p>
<p>Thanks :)</p>
<p>Complimenti, che velocita in mm/min usi? come fai a eseguire la scala di grigi?</p><p>Grazie</p>
<p>Very nice work. Do you have a link for: Pulley Wheels Roller 695ZZ</p>
<p>Hi thanks, credits for you! </p><p>http://www.ebay.com/itm/12pcs-HR-0523-7-5-Furniture-Plastic-Ball-Door-Pulley-Roller-Wheels-695zz-Bearing-/221982161419?hash=item33af2afa0b:g:QW8AAOSwA4dWJzEm </p>
<p>Hmm, doesn&acute;t ship to Germany.</p>
<p>Same pulley from Hong Kong, ships to Germany</p><p><a href="http://www.ebay.co.uk/itm/10pcs-Miniature-Metal-Shield-Pulley-Wheels-Roller-695ZZ-5x23x7-5mm-Ball-Bearings-/231591101773?hash=item35ebe7c54d:g:rn8AAOSwBahVepBa" rel="nofollow">http://www.ebay.co.uk/itm/10pcs-Miniature-Metal-Sh...</a></p>
<p>THX</p>
<p>really? :/ that's bad</p>
<p>Thank you ...^_______^</p>
Hey, <br><br>To which size did you cut the v slots? Does it actually matter or can I choose the size? <br><br>(PS: I think you forgot to mension the rod for the x-axis) <br><br>I'm definitely going to build this! Thanks for your Instructable.
<p>You can choose the size, i bought 5x 500mm 2040 on Ratrig Portugal, they ships to UE. No i don't forgot, 5x V-SLOT 2040 &ndash; Black ;)</p>
<p>I think you misunderstood :) with rod I mean something like this (found in tobias.sobkowiak's instruction):</p><p>http://www.ebay.de/itm/181470570665?_trksid=p2057872.m2749.l2649&amp;ssPageName=STRK%3AMEBIDX%3AIT</p>
<p>That looks awesome! What is the head's top speed?</p><p>Have a great day! :-)</p>
<p>i'm in tests right now, when i finish i will post :) </p>
<p>The link to 3DP Burner are wrong, it point to Xloader</p>
<p>sorry, i don't know why it happens... it's fixed now.</p>
<p>I have been looking for something exactly like this.</p><p>Thanks so much.</p>
<p>Thank you, try :) any problem ask</p>
<p>Now, the next obvious step - replace laser with a sun. Have to solve intensity control somehow...</p>
<p>You can control in software (0-255) and with hardware on potentiometer.</p>
<p>Hello<br>Thank you for the inst. Could you please fix the &quot;https://dl.dropboxusercontent.com/u/40132197/M.%2&quot; link? :D</p>
<p>Hi :D thank you :) it's fixed</p>
<p>Still is not correct.</p><p>CamBam settings: https://dl.dropboxusercontent.com/u/40132197/CamB...</p>
About This Instructable
74,859views
1,172favorites
More by Macinblack20:Build Your Electronic Lab With 400€ Geeetech M201 - Mix Your Prints!! Laser engraver 2.5w A5
Add instructable to:
