Laser Etching Macintosh Powerbooks.
 by saul
Featured
The appropriate files, laser settings, and methodology for putting your tattoo on your powerbook.
as this was boing boing ed a few weeks back i thought i'd show how it is done...
Step 1: Select your artwork.
any bmp, jpg, tif, dxf will do. basically any vector or pixel (bitmap) based artwork. the higher res you can do the better. i like vector because it is scale independent.
Step 2: Lay out artwork in template file.
You can find here the template files (illustrator CS and illustrator 8 versions) where you can lay out your own artwork. stay out of the apple and the red zones and you will be safe. the apple is plastic (don't laser here) and the red border is the radius at edge of laptop.
You can see here the example of my kite file (dxf original) overlayed to fill fully the page and look a little like an engineer's drawing spec...
Step 3: Determine raster / vector style of work.
the wave is a cool tif or rasterable image. this means the laser treats pixels as pixels and goes side to side as it builds the image.
the kite is vector meaning the laser follows the path of each individual line and therefore much finer detail can be produced.
Step 4: Set laser speeds and feeds appropriately.
I use an epilog mini: http://www.epiloglaser.com/mini24_overview.htm
the nice result setting is 50%speed, 100%power for a bitmap image, 20%speed, 100% power for a vector image.
1-40 of 74Next »
Fog says: Sep 10, 2006. 1:09 PM
is there a way that i can do this on a laptop, with a plastic case? thx:)
tewmten in reply to FogSep 15, 2006. 5:30 AM
Wouldn't the laser melt the plastic..?
Tableleg in reply to tewmtenSep 27, 2006. 4:59 PM
No. The types of lasers used for this work are pulsed (aka there are a bunch of high powered pulses instead of a low powered constant beam coming out of the XY scan head). At those power densities, you're ablating (the common word I think would be vaporizing) whatever the beam is focused on making for very precise details.
thepelton in reply to TablelegAug 6, 2009. 3:32 PM
You can only laser engrave approved varieties of plastic. Engraving PVC, for example, would void the warranty on your Epilog.
Mindmapper1 in reply to thepeltonMay 14, 2013. 5:29 AM
Engraving or cutting PVC is very dangerous due to the chlorine gas which can be produced. Not only might it damage the laser cutter but it will damage YOU if you inhale.
Thundertydus in reply to TablelegApr 6, 2009. 7:35 PM
Where would i find a laser capable of etching onto about 20/30 gauge steel? Im making a replica of Arbiter's armpeice from Halo 2-3
jeshaw3242 in reply to TablelegMar 18, 2009. 7:27 PM
hey lasers are fun we have a high powered pulse laser :D in my wood shop class it's very detailed indeed.
jongscx in reply to TablelegDec 11, 2006. 1:22 PM
yeah... I think that technically, you could even laser-etch into skin... it would hurt like all hell, but it's possible.
Derin in reply to jongscxFeb 14, 2009. 5:51 AM
Tetranitrate did that.
tailortrik says: Feb 8, 2010. 10:17 PM
 I would really like to do this.
My school requires a MSDS (material Safety data sheet)  for using any new material with the Laser cutter.
I am trying to figure out what kind of aluminum they use and just find manufacture and a sheet for that.. Any hints?
Mindmapper1 in reply to tailortrikMay 14, 2013. 5:28 AM
why not just etch a polycarbonate shell and then you dont deface the 'puter?
ste3ve says: Jun 30, 2006. 6:02 PM
Any idea where in the SF Bay Area a mere mortal could have this done for a reasonable price?
sbaumgarten1 in reply to ste3veAug 15, 2011. 3:02 PM
Check out Tech Shop (techshop.ws). You could buy a daily membership and engrave it yourself for cheap.
mpandersen says: Feb 24, 2011. 1:28 PM
I am interested in making a laser etching attachment for my (work in progress) 3-Axis CNC machine. My Brother-in-Law dropped his XBox and donated the remains for this project. I have several questions pertaining to this project :
1) Will the Class 3B laser enclosed within the XBox DVD-ROM drive have sufficient power to etch commonly available materials ?
2) What is the Milli-Wattage of this laser ?
3) What is the Wave-Length of this laser ?
4) Since I like looking at my surroundings, what class of Safety Glasses should I purchase. Are there any other pertainent issues I've overlooked ?
Thanks, Mark
P.S. : I'm conducting this experiment under strictly controlled conditions :
Door Locked (I have the only key !!!), and with No Visitors, No Phone, and ZERO Distractions. As I'm in my forties, I have learned a few things in my life, like I only have ONE, and I LIKE it !!!
smcorson says: Jan 29, 2008. 4:25 PM
For those in the Los Angeles area, check out www.deviceninesix.com. DeviceNineSix has been up and running for about nine months now. We've etched a ton of ipods, laptops and phones in that time (not to mention some truly unique requests like shoes). We are filling both individual and corporate orders. Check out our website or email us at info@deviceninesix.com. Cheers!
CamWaite in reply to smcorsonNov 16, 2009. 11:13 AM
 ummm.... your link goes to an adult dating site?
shadleyhax in reply to CamWaiteNov 10, 2010. 11:15 AM
doesn't anymore. it goes to a craft type site. safe link now.
CamWaite in reply to shadleyhaxNov 10, 2010. 2:10 PM
Ah good good, just so we got that cleared up...
patwr2g says: Feb 23, 2006. 1:35 AM
does this process effect apples warranty in any way?
Tenkoi in reply to patwr2gMay 9, 2010. 10:51 AM
Yes, it totally voids the warranty, as you are "defacing" the laptop
gugnheim says: Oct 14, 2009. 9:06 PM
I too have access to an Epilog Laser.  Looking to start doingwork.  Very fun item, done lots of iPod work so far.
aneel says: Nov 9, 2008. 10:43 PM
Have you tried etching one of the new Aluminum unibody MacBook Pros? Any thoughts about how much of a margin to leave for the curvature of the edge? It looks like they're more smoothly curved than the old models. What happens if you overlap the curved part of the surface? Does the laser not focus properly?
LeftSquareBracket in reply to aneelAug 6, 2009. 1:29 PM
I would imagine the laser might not focus properly. Especially with the previous generations of MacBook Pros with the 90 degree fillet. The oblique angle could wreak havoc with the etching. The new ones, however, might not be too bad... most etchers do have to deal with objects of different thicknesses, and the edges on the new ones don't drop that much until you hit the vertical face. So I guess my bet would be that it does, but not egregiously.
thepelton in reply to aneelApr 8, 2009. 10:29 AM
Aluminum would only work if laser etched through paint, or the beam would be reflected back and cause damage.
LeftSquareBracket in reply to thepeltonAug 6, 2009. 1:24 PM
Um... I highly doubt that would happen. The Powerbook in the 'ible is aluminum with no paint. perhaps there is a risk with aluminum that is polished to a mirror finish (like the second-gen iPod touch), but even those have been laser-etched (maybe covered with painter's tape first...?).
incidentist says: Feb 21, 2006. 12:03 AM
Thanks to SquidLabs for letting me borrow their laser to surrealize my laptop. I used the open-source Inkscape program to make the duo-tone rendering of the Magritte painting. I spent a long time trying to trace it manually before I discovered the "trace bitmap" command, which did an amazing job. I was worried about having the laser etch so close to the apple logo, but that turned out to be a non-problem. Just create the image using a template the same size as your powerbook, and make sure to do a test run on some cardboard to avoid a singed logo.
thepelton in reply to incidentistApr 8, 2009. 10:33 AM
That's a neat picture. Reminds me of a painting by Rene Magritte.
wes_711 in reply to incidentistFeb 21, 2007. 7:30 PM
That looks soooooo soooo awsome .....excellent idea to i would have never thought to do that (know its a painting)
cyenobite says: Dec 19, 2005. 5:28 PM
good how to, but is there any advice for those of us who don't have access to a laser? Are there places that would do this if you called or just walked in? What would be the cost of doing something like this? Thanks Cyen
thepelton in reply to cyenobiteApr 8, 2009. 10:31 AM
I would do it for a fee myself.
thepelton in reply to thepeltonApr 8, 2009. 10:32 AM
I am in Colorado Springs, Colorado. donaldpelton@gmail.com 719-634-0817
istyle in reply to cyenobiteApr 12, 2007. 7:39 PM
For those in the Los Angeles area, a new store is opening on Melrose Ave, that'll etch an image (from a library or customized) to any equipment. Check them out at www.istylecustom.com. for pricing info and location.
Mail order service will be available soon.
technology tattoo in reply to cyenobiteMar 1, 2007. 11:32 AM
Hey, I don't know where you're located, but if you're in the minneapolis/st paul area, there is a new company that specializes in mac etching, called technology tattoo. . I don't know if they have a web site up yet, but you can call at 612.435.2113 peace!
paulplaysguitar says: May 3, 2008. 8:57 AM
I have a black macbook (13.3 inches). Any chance you have a template for that?
chuck981996 in reply to paulplaysguitarSep 29, 2008. 8:21 PM
Macbook is plastic, can't do it on that.
paulplaysguitar in reply to chuck981996Sep 29, 2008. 9:07 PM
Well... I did it at the Make fair months ago and it turned out pretty well...
chuck981996 in reply to paulplaysguitarOct 1, 2008. 12:03 AM
My mistake, a few hours after I posted that comment I discovered you could do it on plastic.
paulplaysguitar in reply to chuck981996Oct 1, 2008. 4:25 AM
Don't worry about it. I was worried myself when I did it. I didn't actually know if it would work until the machine got done. Phew...
paulm says: May 16, 2008. 9:36 PM
You are a tech designer aren't you I recgonize your "kite" vector drawing from tech design class
joejoerowley says: May 1, 2008. 7:52 PM
Very Cool! Do you mind if I use one of your images? Thanks
1-40 of 74Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
