Thanks to SquidLabs for letting me borrow their laser to surrealize my laptop. I used the open-source Inkscape program to make the duo-tone rendering of the Magritte painting. I spent a long time trying to trace it manually before I discovered the "trace bitmap" command, which did an amazing job. I was worried about having the laser etch so close to the apple logo, but that turned out to be a non-problem. Just create the image using a template the same size as your powerbook, and make sure to do a test run on some cardboard to avoid a singed logo.
good how to, but is there any advice for those of us who don't have access to a laser? Are there places that would do this if you called or just walked in? What would be the cost of doing something like this? Thanks Cyen
For those in the Los Angeles area, a new store is opening on Melrose Ave, that'll etch an image (from a library or customized) to any equipment. Check them out at www.istylecustom.com. for pricing info and location.
Hey, I don't know where you're located, but if you're in the minneapolis/st paul area, there is a new company that specializes in mac etching, called technology tattoo. . I don't know if they have a web site up yet, but you can call at 612.435.2113 peace!
I used a LaserPro Explorer II machine at 80% speed and 50% power. it sounds like there is a large range over which it will work fine. i also accidently cut into the apple logo and it was fine. no worries. Howard
Thanks for the templates! For those of use who don't have access to a laser I found this vendor online: etchamac.com. Haven't tried them so use at your own risk.
etchamacbook.comI saw that a company http://www.etchamacbook.com seems to be a little less expensive. Just have some artwork ready for them. They did my laptop and it looks great!
Hi- I just met with an Epilog laser rep and asked about using the laser on plastics. He said it was really dangerous to laser anything with PVC in it, because the fumes are incredibly corrosive and destroy the laser machine, and it releases extremely harmful vapor. I'm totally sad because I wanted to do this to my MacBook, but from research, it SEEMS like the MacBook cases contain PVC, to make them a little more flexible and strong. I don't know this for sure, though. Can anybody else clear up whether the plastic cases for Apple laptops contain PVC?
Hey Hissyfit, PVC when cut with a laser makes the Chlorine atoms in the polyvinyl chloride react with nacent water -H2O in the atmosphere to make H2Cl or Hydrochloric Acid. The amounts are small and is detrimental to the machine over a long period of time but for 1 or 2 jobs a month is worth the risk. Just make sure there is a carbon activated filter at the end of the vacuum pump sucking all the smoke out of the machine to trap all the harmfull chemicals. I would do it , but thats just me and I like to live on the edge.
Hey there, read your article on MAKE. I was wondering where you found the 'plum blossom' artwork that was used in that article? You can email me at misstricky (at) gmail dot com. Thanks so much!
thanks for the tip! I used SquidLabs Epliog Mini at 100% power 100% speed to etch my powerbook with the structure of Taxol (an anti-cancer drug). It looks great. -Dylan
Mail order service will be available soon.
