loading
Step 3: Extract the DVD Laser Diode
After removing all of the screws from the DVD burner, remove the cover and the DVD drawer. This will expose the laser carriage assembly.
<p>Here is another picture of other lasers in action. The laser was defective and required shipping of another type of laser.</p>
<p>I have bought a 250 mw red 650 nm high powered laser and I have built other types of near UV lasers for experiements with living friendly bacteria.</p>
<p>A little off topic but I have a 50 mw 532 nm green laser that I tried to convert into at least a 100 to 150 mw burning laser. Unfortunely I could get the mountings between the laser to be removed without possibly damaging the laser.</p>
<p>I bought myself a 3V 650nm red laser diode to build a cutter to cut polystyrene sheet 25 mm thick. I assembeled it in a flashlight but I dont seem to get it to cut the polystyrene. Where is my mistake?</p>
<p>Hey!</p><p>I don't know exactly what could be wrong but perhaps polystyrene needs a higher temperature to burn :/ a.k.a a more powerful laser</p><p>Good luck!!</p>
<p>what is a driver circuit</p>
<p>There is Google, Google it...</p>
<p>can this work with a cd player???????????????</p>
<p>Hi NathanielE, no this will not work with a cd player, because the light emission from a CD player in infrared light. </p>
<p>Well, CO2 lasers still have infrared light in the multiwatt range</p>
<p>i just took a laser diode out of a broken playstation 2 but it's powered by a ribbon cable, no wires anywhere. anyone know how i could use it?</p>
Nice!But I want to ask something.What is the laser's range?
ok.... i have a dilemma. i spent $40 on a dvd burner, and i took it apart. i found the carriage where the diode has to be. inside the carriage there were several mirrors/prisms/whatever, and they led to two different holes, where i assumed the diodes would be. (there was no other place they could be!) but instead of finding some normal laser diodes, i found these strange rectangular ones with four pins on the back. they definitely won't fit in the aixiz housing... what should i do? are these really the diodes, or should i continue looking? i have completely dissected this burner, but to no avail...
<p>Mine look similar because I got a DVD/CD burner/player (It did all of the above so i'm lucky) from an old laptop. 1 is the dvd (red) and 1 is the CD (IR, looks like nothing is happening or pinkish). What I did was using a AA (1.5v), test each pin to see which one is + and which one is - . You have to try every combination so be happy it's only 4 pins and not 8, 12, or 16 pins. I found that 1 L.A.S.E.R. turned on and was red while the other looked like it didn't work. Camera's can &quot;see&quot; IR (that's how night vision works) so I labeled each pin 1-4, turned off the lights and started using my laptop camera and screen recorder (Screencast-O-Matic). Each time I tested a connection, I would call out both pin numbers and which one was positive/negative. Finally I looked at the recording and found my + and - terminals. Now, you might be ready to reply to me saying that this doesn't help your case at all... well, it was from a laptop so the laptop cooling fan is connected to a heat sink to cool the laptop faster. You can find a spot for the L.A.S.E.R. to fit in or cut a square/hole into the side of the heat sink for it to fit. This was done with a drill press and a strong bit. If you don't have access to this stuff you can probably find an old desktop computer tower that holds heat sinks, a CD/DVD player/burner, access for USB and other ports, RAM, ROM, and many other components. It doesn't have to work as long as you can get it cheap/free. Otherwise you can go on eBay and search for heat sinks because people that take apart electronics will try to sell parts that they don't need or want. I took apart 2 laptops, 2 Wi-Fi routers, an old digital camera (a monster in size by today's standard, it used floppy disks to save stuff!) and a big boom box. I want to make a EMP/taser thing,and some other cool tings that might even be able to be used by my Arduino. Anyway, I hope I helped at least a little.</p>
<p>&quot;<b>Light Amplification by Stimulated Emission of Radiation</b>&quot;</p><p>LASER</p>
<p>Kipkay, I'm a big fan of your tutorials! I've been wanting to try this for awhile and I just now found an old dvd burner that still has a good diode I can use. After messing around with this and perfecting the technique, I want to buy one of those 2 watt blue laser diodes and REALLY make something cool!</p><p>Anyways, my question is this: How long would a 9 volt battery power a typical red dvd burner laser? I don't know the current the diode is supposed to take yet, so I can't do the math, but I'm wondering if I should just use one 9 volt at first or if I should hook up 2 in parallel. Also, There was a glass lens in the dvd drive, should I try to incorporate that? Or should I just use the adjustable lens that came in the Aixiz housing? The one in the Aixiz housing doesn't appear to be made of glass.. I think it is plastic and I have no idea if the laser will melt it or not.</p><p>Thanks!!</p>
<p>make me one i live in millwood dr in nashville tn my zipcode is 37217</p>
<p>I had found out the LD. I desoldered it from the board. But laser is glued into the whole thing. How to get it out. The one I had opened is samsung cd r/w 52X read, 32X rewrite, 52X writeable</p>
I connected, directly, the positive and negative pins of the laser in 3 AA batteries (4,5V). It turned on for a few seconds, and now it don't turn on with 3V (2AA batteries). Is it broken? :/
Probably, yes.
can i make a module or can i put laser in other stuff or i need to have aixiz alser module
about how much power does it have? <br>like can it pop some balloons or light a match?
http://www.ebay.com/itm/200mW-650nm-Laser-Diode-Kip-Kay-project-suitable-/180479555252?pt=LH_DefaultDomain_0&amp;hash=item2a056b76b4 <br> <br>200mW 650nm Laser Diode Kip Kay project suitable <br> <br>haha look its you
on estimated time how long do you think this will take <br>
cool!!!!!! <br>can you make an iron man plum laser with a blu ray laser that can burn ?
Whats the range of the laser?
I was really intrigued by this Instructable. Thank you. I have taken to heart all the cautionary comments, too, so I may not try to build it for myself since it requires enough safety precautions to make it NOT a fun toy to play with; more like a dangerous power tool. The need to put the laser diode into the housing from a low powered laser was not fully explained. But I have deduced from later comments that the reason for the extra housing is: 1) to act as a heat sink for the diode during operation. And 2) The housing includes optics--lenses to focus the laser light to a dot, or a linear ray. I wonder if an alternative source of focusing lenses could be suggested. I am aware that often the primary difference between a good and a cheap laser device is the lenses used. I presume that with only a single wavelength of light, cheaper lenses can be used since there is no worry about chromatic distortion, but still there are cheap lenses and then there are cheaper lenses. The Instructable is sketchy also about the details of the hookup of the laser housing/electronic connections and the flashlight housing. Perhaps this section could be more detailed with closeup photographs. The same needs to be said about the regulator--how would this be fit into the flashlight housing? Is the regulator more for regulating voltage or limiting current? And how does one know where to set it? I suppose one could calibrate it with a multitester and mark the potentiometer for reference. BTW, could a simple resister or pot be used to regulate the current at least, without the rest of that circuit? Just wondering. Apply Ohm's law. It would really be good to research the optimal voltage and current of the diode used to be certain not to shorten its life--perhaps with that knowledge and Ohm's law a simple resister would be all you would need to regulate the current with a a prescribed number of cells powering it. I want to remind people that there is a much more powerful "Laser" that is available for free and requires no batteries. All you need is a mirror and a magnifier. And sunlight. Yes, you guessed it: reflect the sun with the mirror and it really is like a solar powered laser--visible for miles! (Not bad if you are signaling a search plane while lost in the wilderness.) The magnifier is all you need to burn wood or start a fire with the sun as well. Very simple, and obvious, of course, but we forget that when the word "laser" is mentioned, and we conjure up visions of Star Trek or Star Wars. Obviously the same precautions need to be observed with your high powered laser as when using a magnifier with sunlight--as every kid has learned early on when the light starts to burn the skin and he stops as once. The difference here is the fact that the laser beam focuses that energy much farther away from the source than a simple lens does, and the heating of distant objects may not cause as immediate a realization on the part of the aimer. Also the potential of scattered light off of unexpected reflectors doing harm is also introduced, since the longer focusing distance makes it a much more dangerous thing. For instance, shining it through a window perpendicular to the beam will reflect back a large percentage right to the aimer, or bounce it in other unintended places. I would caution against aiming it out windows or at metal or glass or liquids, or plastic bags even. Anything reflective can bounce it in unexpected ways. I learned from this Instructable the fact that DVD burners use visible wavelengths unlike CD readers which are IR. How about CD burners? What do they use? And the new Blue Ray DVD burners: do they have more energy output per mW? Certainly the ability to see the ray you are aiming is a safety feature, making IR or UV lasers less desirable. Thank you again for a truly interesting and informative Instructable.
- Yes the Aixiz housing includes the optics necessary to focus the laser into a beam.<br/>- I don't know if the driver is more for regulating voltage or limiting current, but I do know that you can buy drivers for laser diodes online, or you can make one. The trick for making one is to make it small enough to fit it in the host you want it in (like a flashlight. As for setting the driver to work well with the diode, I don't know how to do that yet, but www.laserpointerforums.com is a great source for all of that information.<br/>- Blu-ray diodes are about 405nm, which is violet/near UV. Some blu-ray lasers are more/less visible depending on the exact wavelength, which may be off by a few nm. Their power is generally around 100-150mW, where some of the red DVD burner diodes can go up to 200-300mW.<br/>-Another housing you can use is the Meredith module which can be bought here: <a rel="nofollow" href="http://www.mi-lasers.com/cgi-bin/shopper.cgi?search=action&amp;keywords=diode_optics">http://www.mi-lasers.com/cgi-bin/shopper.cgi?search=action&amp;keywords=diode_optics</a> . According to what I have read on laserpointerforums.com, those have better quality optics that produce more powerful lasers.<br/><br/>Please don't quote me on all that; I'm trying to help, but I'm not entirely sure of the accuracy of those statements.<br/>
I've updated that Meredith-instruments site by the way (I'm their web designer type guy), that link will no longer work. Try this one instead: <a href="http://www.mi-lasers.com/diode-lasers/modules-systems" rel="nofollow">http://www.mi-lasers.com/diode-lasers/modules-systems</a>
It didn't look like he used the driver just the housing. Whats your take on that?
Well, if I remember correctly, the laser community called out kipkay for not using a driver. While it is possible for it to work without one, the longevity will be reduced, and it still may not work at all. The laser community practically considers the driver an essential part.
I saw the driver that is in the laser housing and its pretty small. I guess it might fit under the lid of the minimag that has the two holes to plug the bulb in?
blu-ray laser diodes work great but the diode from a casio x something projector is the best and you can buy one off e-bay for less then $50. i dont know the casio full name but when you are looking up the item you will see plenty of the right name and model.
thats long
geez, that's one long post! :-)
killjoy...jk :]
what would happen if you used 2 watts
That is what I'm doing for my Senior Project, creating a computer controlled laser engraver/cutter. First of all, you need a bigger heatsink. Second you will need to use a different driver setup and you will actually need to make 2 and wire them in parallel because the LM317 can only handle a max of 1.5A and a 2W laser is 1.8A. I found this website very helpful <br> <br>http://www.rog8811.com/laserdriver.htm
can you use the same driver in the aixiz housing with the new diode?
if you cant use the same chip can you use a resistor
Can you use the same chip from the Aixiz housing when you put the DVD burner diode in the housing
Can i use 4.5 volt ?
NO! that will blow the diode in an instant!
I had an old dvd burner diode that I hooked a 9volt battery up to. Did I just burn it out? I also only got an intermittent 'faint' glow when I tried it.
Yes, it is burnt out. When testing lasers, start out with 3 volts.
Hi Kipkay,<br><br>I was wondering if we don't need a driver circuit between the diode and the batteries. You are using two AA-batteries, that's 3V. Wouldn't that be too much for a diode of 250mW? Connecing it directly to the batteries might fail in giving a constant current, so I guess a driver would do better. Or am I very wrong now?<br><br>You can also mail me at ramon_jansen_92@hotmail.com.
Hey kipkay, I was wondering if this really works or its a fake video..because i have alot of friends that know alot about heat lasers and i asked them about this and they said that it would blow the diode. Are they right?
It's real. You see the module the laser is in? It acts like a heat sink and will distribute the heat out so you can use it for a little while. Now for long burns I'm not sure if it would last. My rig I place the housing in a block of metal that fit in one of my flashlights and it worked out perfectly.
About This Instructable
1,799,615views
1,791favorites
Bio: Tinkerer, hackster and prankster. Hit me up on Facebook: https://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
More by Kipkay:The Garage Door Alert! Amazing Way to Test Batteries! Mighty Mini Fog Maker
Add instructable to:
