Step 7Preparing the AixiZ housing...
iImage Information
Remove the label from the AixiZ housing and unscrew the housing leaving a top and bottom portion of the housing. Inside the top housing is the original (5mw) laser diode that has to be removed. I used the bottom of an X-Acto knife and with a couple of sharp taps, the original diode will come out. It will likely be destroyed doing this but I have been successful in removing them before but using a very small screwdriver and tapping around the diode until it is freed up.
what is the Aixiz housing and could there be an alternative to it
if so what would be the next step.
http://www.laserpointerforums.com/forums/YaBB.pl?num=1219161671
